Mitsubishi Mr. Slim split-system heat pump not blowing hot air
I have a Mitsubishi Mr. Slim split-system heat pump (model MSH09TW). It came with the house when we bought it, and has never worked properly. When in "cool" mode, it blows room-temperature air. In "heat" mode, it doesn't seem to blow any air at all, even though the fan on the outside unit is running. I tried replacing the capacitor, but am not sure what else to do.
SOURCE: Mr.Slim Mitsubishi dual zone system
We had that problem with two units that we just had installed. Both are hooked up to one compressor. After several calls and the service person coming out twice, it turned out that they had two wires mixed up when they did the installation. Once they switched the wires the units ran ok.
BUT...now we are having another problem with the units/compressor not working after losing power in our house. We lose power on a regular basis here. Does anybody know if that means we will constantly need to call the service people to come to get the compressor working again? Or is there anything we can do to reset it? The service person that came today was not very helpful and didn't have a lot of answers for us.
Thanks
Posted on Jul 23, 2008
  • 6 Answers
SOURCE: fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Posted on Feb 16, 2009
SOURCE: Blueway split system wall air conditioning doesn't work properly.
Hi,I have had problems with my Blueway A/C it was very cheap but NASTY,anyway I might be able to help, I made a website with my manual that includes the error codes that I could not find on the net anywhere ,I have also sourced a company in sydney who has spares and have the contact details listed and started a forum that we can help each other out with
Posted on Apr 05, 2009
mcgyver468
  • 710 Answers
SOURCE: Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Posted on Apr 27, 2009
  • 116 Answers
SOURCE: The outside unit on our Ruud heat pump won't turn
first look for red button neer the copper line set if has one push it second inspect thermostat wires for weed eater damage check disconnect for fuses check breaker at main panel pull disconect and remove cover check stat wire connections look at the capacitor if swelled up on top bad if all look ok put disconect in using insulated object manually push in contactor if unit comes on check for 24 volt ac on yellow stat wire to common if none stat wire could be loose at indoor unit or stat bad hope this helps you
Posted on Jun 06, 2009
Why is my Mitsubishi mr slim is blowing black particles into room?
Area where "fresh" air is being pulled in is dirty, filter needs replacement, heat exchanger is old, a seal is old/torn, or mold is shooting out!
http://www.ehow.com/info_12016541_particles-blow-out-fan-air-conditioner.html
May 27, 2014 | MR SLIM Split-ductless: Mitsubishi...
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
Mr.Slim split unit-indoor blower bearing squealing, any easy tips to lube this, or strictly replacement?
All bearings in indoor motor are pre-lubricated. Only solution is to replace the bearings.
Jan 14, 2011 | Mitsubishi MSH09TW Air Conditioner
I have 2 Mitsubishi electric "Mr Slim" type
Have your system checked by a professional.
From what you are describing here it seems as thoug you have a slight leak in the system somewhere and therefore the system is not cooling or heating properly.
Have them check the system... verify the low charge, fine the leak and repair it.
Vacuum and recharge the system...
Then check the operation before you let them out of your sight.
...It can be tough to get some contrators back if you let them go before you check it...espec. if you pay them...:-)
heatman101
Nov 19, 2010 | Mitsubishi Heating & Cooling
Mr. Slim is not blowing out cool air in 1 room, while the other 2 rooms, he's doing fine.
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Sep 08, 2010 | Mitsubishi MSH09TW Air Conditioner
I have a Mitsubishi Mr Slim model MSZ12UN. The
you must see the indoor fan and you must clean it very good as well all the indoor unit.
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Inside fan not running in heat mode
i belive these units may have a cold air prevention sensor in them which wont allow fan ops until the coil reaches temp
Mar 04, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
MR.Slim heater - NO HEAT??
make sure you have freon in your system. they act as a heat pump which does A/c as well s heat. without freon you want have cooling or heat.
Jan 17, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
506 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
