Question about YouTube Videos
Volvo s40 2008 won't start, battery fine, clicking noise
Car starts on full charged battery, After running 30 mins vehicle will not re start. Clicking sound when trying to turn over.
  • 496 Answers
When you get it started take it to autozone or kragen they can wheel a machine out to the car and test the starting system and charging system for free.
Posted on Jan 15, 2013
Volvo v40gdi sometimes won't start but starts fine from cold when trying to start it chokes and struggles if I remove air filter assembly it starts fine,
To troubleshoot the issue, click the link below:
Car Repair Diagram
http://technoanswers.blogspot.com/2013/03/car-repair-diagram.html
HOT/WARM START ISSUE
Its a hot start issue.
Can be related to low fuel pressure or problem with crank sensor.
Also it can be weak battery or starter.
But possibilities are to be inspected to confirm what exactly it is.------
To troubleshoot and confirm the issue,i suggest you refer few solved help links with similar types of problem like yours:------
Click the link below:------
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
Multiple problems on car: Car runs hot, A/C blows hot and car starts surging?
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
Delay starting on Toyota Prius?
http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
Honda car will not start intermittently?
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
Vehicle Starts, Runs and Loses Power
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
Intermittent starting issues on Volvo 760?
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
Car starts and cuts off immediately?
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These details will help.
Thanks.
Mar 14, 2013 | Cars & Trucks
1997 Monte Carlo battery wont stay charged after a jump. The car will warm up then when turned off won't turn over it makes a clicking noise when ignition is terned.
Could be a bad battery, and or alternator, if the alternator does not charge the battery when the vehicle is running your battery will drain causing no start.
Jan 15, 2013 | 1997 Chevrolet Monte Carlo
I have a leak on my radiator and replace it, after this my car won't start! Please help!
Make sure you have a full charge on your battery. Make sure the battery post are clean, and the cables are tight, coat with an anti-corrosion spray. Check you solenoid switch.
Oct 06, 2012 | Volvo S40 Radio Installation Dash Kit
The car was running fine one day then the next day it would not start. We tried jumping it thinking the battery might be dead and it still would niot start. The car has power until we take the jumper...
Sounds like you have a toasted battery or alternator. Have you performed a load test on the battery? Have you tried to charge the battery? First remove the battery and charge it externally from the vehicle. If the battery won't hold a charge, or won't hold a charge of 12 volts, replace it. Once you have the vehicle started, test the operation of the alternator. It should be putting out at least 13 volts back to the battery to keep it charged - if it is putting less than 13 volts or more than 16 volts, replace the alternator.
Nov 01, 2011 | 2005 Chevrolet Malibu
My 2006 volvo s40 won't start and the key (remote) does not work. Had to use regular key to open the door. alarm still on and car won't start.
I had the same problem when my battery went flat and tried to use jumper cables connected to another vehicles battery. I called Volvo and they said I need to disconnect the battery terminal to reset the computer. After re-conecting it the remote control worked again and I was able to jump start the car. Maybe your car's computer went into a similar state.
Aug 20, 2011 | 2006 Volvo S40
My 92 volvo 240 has been sitting outside all summer. i have started it a few times and went to start it today. it won't do anything. what could be the problem and a solution?
"It won't do anything" means that there are no dash lights, no buzzers, nothing?
Any car has very slight electrical drains when it is shut off. For one thing, the clock is running, but there are a number of other tiny loads as well. With a good battery, you should be able to park a car for six months to a year and still start it.
However, if you start the car several times without running it long enough to recharge the battery, or if the drain is larger than it should be due to electrical problems or aftermarket accessories, you can get a failure to start.
Unfortunately, maintanence-free batteries don't tolerate being run completely dead very well, and many owners have unhappily found that draining an older battery once or twice was the last straw that ended their battery's life.
I suggest that you borrow a charger or a set of jumper cables to start the car, and drive it 30 minutes or so to fully charge the battery. If you have more problems, get the battery load tested at a shop that sells batteries to see if it is still OK.
Jul 27, 2011 | 1992 Volvo 240
I just buought a 98 Volvo S70 T5, the car sat for abit, to the point were It had to jump it. to start. ran great for the next 2 hours off and on mybe 7 diffrent starts but it never running for more then...
It could be a number of things:
  • Bad connection or corrosion on battery cables
  • Dead cell in the battery would prevent it from charging fully
  • Bad or worn drive belt would slip, preventing the alternator from fully charging the battery
  • Bad alternator
If the car will run at idle with all accessories turned on, the alternator is good and you should concentrate on the battery and battery cables. If the car won't idle, then the drive belt and/or alternator could be the issue. If the car starts everytime when it's cold and only gives you a problem starting when the engine is hot, the starter could be the issue. A bad starter will often work when it's cold (after sitting a few hours or overnight). When a bad starter gets hot, it takes more and more power to get it to turn over.
Overall, I'd have the electrical system checked out. Most chain auto parts stores (Autozone, Advance Auto) will do a complimentary electrical test for you.
Jul 22, 2011 | 1998 Volvo S70
Clicking noise coming from the engine and a dead battery
That clicking noise is your starter, your battery is dead or severly drained and when you try to start you car, your starter selnoid is trying to turn over, but doesn't have enough juice to get it going, so it's making that clicking noise. If you have a old, dead battery, it is time to replace it, if it's new and only been drained for exmaple leaving headlight on etc... then you can try to jump your camry with a jumper cable through another vehicle. Let it the car run for about 30 min or so to have it charge. You can also take it to autozone, advance auto part and have them charge for free or test it.
Feb 08, 2011 | 2000 Toyota Camry
YouTube Videos Logo
203 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
