Question about Exercise & Fitness
Weslo Momentum Ct 5.0 Ellipitcal broken axle need to know take apart and replace
The wheel in rear which the belt and pedal rotate on the axle
5 Suggested Answers
joboo1
  • 257 Answers
SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Posted on Mar 14, 2009
  • 95 Answers
SOURCE: Need to replace the drive belt on my Weslo Momentum 610 elliptical
Which version of the Momentum 610 do you have? Here is a drive belt for the WLEL14051 and WLEL14052. There are a few slightly different model numbers for the Momentum 610 listed here that do not have drive belts listed in their parts list, so it is possible that the first link works for those two, but I could contact them to make sure.
Posted on May 01, 2012
ercupa190
  • 12223 Answers
SOURCE: Weslo Momentum 7.0EX Elliptical weight lmit
Dear Sir:
You must read your instruction manual, but the promedium is 250lbs for
elliptical machine.
By that reason Read CAREFULLY your instruction manual.
If you do no have go for free download: www. fitness.manualsonline.com
sincerely. God bless you.
Posted on May 04, 2012
ercupa190
  • 12223 Answers
SOURCE: replace belt on weslo g25
see the video and execute with common sense. God bless you
Posted on Sep 17, 2012
How do i replace drive belts
you have to unbolt axle to get enough room to put belt on and it will be hard to get belt on best way get rear wills off ground and slip belt on one side of pulley the roll the belt on by rotating rear wheel that are off the ground both wheels have to be off the ground
Aug 08, 2014 | Mtd Garden
How to remove 2008 rear wheel fatboy
To remove a 2008 Softail rear wheel FIRST block motorcycle underneath the frame so that theweight of the motorcycle is off of the rear wheel, remove saddlebags if equipped, remove the belt guard and the debris deflector from the rear fork, inspect the wheel bearing end play and service the bearings if and as necessary, label the wheel spacers for left or right locationand orientation i.e. fork side or wheel side, remove the rear brake caliper from the caliper mount and support it using an elastic cord or such,For the FXCW/C modelsthe nut retainer will remain in the axle nut and does not need to be removed and if it is removed it must be replaced. For all but FXCW/C remove e-clip, remove the rear axle nut, and for FXCW/C remove the rear axle nut, loosen both axle adjuster screws an equal number of turns to remove tension from drive belt, with a suitable drift or other tool tap the axle towards the right side and remove it, remove the spacers and the caliper mounting bracket, move the wheel forward and slip the belt off of the sprocket, raise the motorcycle to allow enough clearance for removal of the rear wheel and pull the wheel with the belt sprocket from the rear fork.
To install a 2008 Softail rear wheel FIRST apply a light coat of wheel bearing grease to the axle, to the bearing bores and to the bore of the inner sleeve, roll the wheel into place in the rear fork and slide the drive belt over the drive sprocket, position the left bearing spacer between the wheel and the fork, from the right side carefully insert the axle (with its washer for FXCW/C models) through the right rear fork, the short spacer, the rear caliper mounting bracket, the long spacer and into the bearing bore, continue sliding the axle through the wheel hub sleeve, the left side spacer and the left rear of the fork, install the washer, the axle nut, and the retainer, verify correct axle alignment and the check belt deflection, check the wheel bearing end play after tightening the axle nut to the specified torque because excessive end play can adversely affect stability and handling and insufficient end play can cause bearing seizure, tighten the axle nut to 95-105 ft-lbs (128.8-142.5 Nm), install the belt guard and the debris deflector, install the brake caliper and pads, install the saddlebags, if equipped, pump the brake pedal to move the pistons out until they contact both brake pads, verify the piston location against pads, verify the position of the brake pads against the brake disc, rotate the wheel to check for any interference(s) or misalignment(s) and test the brakes for proper operation.
May 12, 2014 | 2004 Harley Davidson FLHTCUI Electra Glide...
Tension to tight on bike won't losen
Step 1:
please follow the instruction and fix it. God bless you.
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Step 2:
LUBRICATION
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess greas
Step 3:
Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use
Jan 04, 2013 | Weslo Pursuit R 3.8 Upright Exerise Bike...
Plenetry gear system is broken in rear axle whats Problem
Remove wheel, remove rear diff cover, remove small bolt that retains spider gear cross shaft in the carrier. Push axle in, remove "c" clip on end of axle and remove axle from housing. Reverse to replace. Only problem you may have is that sometimes small bolt is broken inside carrier. if broken you will need to drill a tiny hole into it and remove with tiny "easy out" or other similar device.
Do not turn carrier when shaft has been removed or spider gears will rotate and fall out!
Sep 12, 2012 | Cars & Trucks
Apr 30, 2012 | Weslo Exercise & Fitness
My weslo momentum 7.0 ex elliptical machine display stopped working. It won't power on even with new batteries.
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of the pedalsto the crank axles.
ernesto cuadramanagua, nicaragua
Mar 07, 2012 | Exercise & Fitness
I have a used Weslo Cadense 927 treadmill. I need to adjust the the tread, it's rubbing the side.
When you purchased the treadmill it came with an allen wrench to assemble the machine. That is the adjustment tool.
Inspect the rear plastic cap (the adjustment bolts are there) make sure it is not damaged. If the plastic is broken, it will need to be replaced. This job is not easy. If it is not broken, adjust the belt as follows..
If the belt is already rubbing, locate the adjustment screw at the back of the treadmill on the side that is rubbing.Adjust that screw tuning it 1/2 turn clockwise. Move the belt manually 3 full rotations.. If it is still rubbing, turn another 1/4 turn. Again move the belt manually 3 rotations. Once the rubbing stops, run the machine slowly and watch the belt from the back of the machine..
Dec 16, 2010 | Cadence Weslo 927 Treadmill Walking Belt
Don't know how adjust belt drive on vrscaw v rod can anyone help 2008 series
MOST HARLEYS IVE SEEN HAVE AN ECCENTRIC ON THE REAR DRIVE AXLE TO MAKE THIS ADJUSTMENT. IF SO, LOOSEN THE AXLE NUT AND ROTATE THE ECCENTRIC TO PROPER TENSION THEN TIGHTEN THE AXLE NUT. RECHECK TENSION AS IT MAY CHANGE DURING TIGHTENING.
Oct 22, 2009 | 2008 Harley Davidson VRSCAW V-Rod
Front cog does not rotate when pedaled
You will have to remove the rear wheel and take it in to a bicycle shop and have the rear cog replaced. The freewheel part inside it has likely broken and will only rotate in both directions. It should rotate to back pedal and then catch as you pedal forward.
Apr 08, 2009 | Freestyle Cycling
Exercise & Fitness Logo
42 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
