Question about Hotpoint Washing Machines
Internal pipe blocked by rug so will not drain
  • Hotpoint Master
  • 17,130 Answers
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jan 15, 2013
Kenmore he2t
fluff may have blocked the filter or jammed the drain pump. you need to check these
May 07, 2014 | Washing Machines
Water Pooling & Freezing
Assuming your fridge has a defrost cycle ( I.e. is a frost free model), you are probably suffering a blocked drain hole or pipe, leading to the top of the condenser or a tray nearby, where the frost water can evaporate.
The pipe can block with food or a mould plug, leading to water retention that freezes and further blocks the drain. the water is produced when a heater switches on in defrost mode and thaws the internal or external ice build up and, with nowhere for it to go it will pool on the bottom and may, when in defrost mode, run out onto the floor.
With frost free fridges/freezers, there is a drain outlet, usually hidden behind a removable panel inside the fridge/freezer compartment or, a drain hole near the bottom. If there is a drain pipe as well, access is usually from the rear base of the machine. The pipe is usually removable and can be cleaned out but prepare for some water to escape. An ice block in the drainage hole can be thawed using a hair dryer BUT GENTLY, so as not to warp the plastic inners of the fridge.
Jan 20, 2014 | Refrigerators
After washing bathroom rugs, my Frigidaire Affinity front loading washer would not drain the water out or refill with water
Often washing things like rugs and matts can cause real problems for the drain pipes on you machine. Have you tried clearing out the drain plug, located at the bottom of the front of the machine? If that doesn't work, the whole drain hose from the drum will be blocked.
thanks
www.recycledrum.com
Jan 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
2004 Gmc Envoy Airconditioner Condensation Is Leaking Into The Floorboard On The Passinger Side Of My Car
Most probably your condensate drain is blocked. Check to see if the usual dripping at the left front tire is continuing or not (after running the A/C and the vehicle is stopped). If not you have a choked drain pipe. The drain hose is located to the left of the engine compartment just below the AC lines coming out of the firewall. There is a rubber tube about 1" diameter and it has a small plastic tube 3/8" coming out from the bottom side of the larger tube. Please take care accessing the tube as there are pipes and tubes really hot in the vicinity. It is always a good idea to wait till the engine has cooled down. The drain tube sometimes gets blocked and causes leaking onto the rug area inside the truck, just pull the small tube out by pulling it down and clean the small/large tube. If there is any water from the AC it will drain out.
Jul 06, 2010 | 2004 GMC Envoy
Water dripping from internal unit of J.B.S. split system air conditioner
Hi
This can be due to three reasons. The water drain pipe is block. Which can be sucked clean with wet/dry vacuum cleaner. The drain pipe behind the unit is not sloping downward away from the unit. Or the coils of the internal could be iced up. If this is the case the unit should be switched of until the ice is completely melted and switch the unit on again. If the copper pipes leaving the the condenser unit outside is starting to freeze up, the unit is short of gas. Call a A/C company to refill the gas and search for possible gas leaks.
Jan 26, 2010 | Heating & Cooling
Bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Jul 27, 2008 | Bosch Refrigerators
WILL NOT SPIN ON HIGH
The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground
Nov 01, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Itis a 'no spin".
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Oct 18, 2006 | Magic Chef CAV2000 Top Load Washer
Itis a 'no spin".It washes, drains, then it rinses, bypass spin to off.
Washing Machines Logo
18 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
