Question about Whirlpool Washing Machines
Whirlpool, model du915qwdb5, serie fg390915, water not coming
  • Whirlpool Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Posted on Jan 15, 2013
Our kenmore 80 series (110.27812692) pooped out on us,... the motor and water pump needed replaced, so we bought a used kenmore 70 series (110.82872820) from a friend,... it works fine, but the control...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer(s):
http://www.searspartsdirect.com/partsdirect/index.action
Enter the model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Check the part numbers for both machines in the "Console" section.
Also see the following Whirl[pool Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Whirlpool top load, washers use one of two different timers. Depending on the timer the knob comes off differently.
For most, by holding the back of the timer shaft with a thin needle nosed pliers, the knob unscrews.
Sep 13, 2010 | Kenmore Washing Machines
Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
Mar 26, 2010 | Kenmore Washing Machines
I have a Whirlpool Imerial Series Side by Side that will not disp
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
Nov 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool Imperial Series refrigerator that has water coming from the bottom- onto the floor. The evaporation pan is nowhere near full. It is not apparent where the water is coming from. Any...
Hi, Dounfd like the defrost drain in the freezer is plugged. Remove the rear panel inside the freezer and locate the drain hole under the evaporator coil.
Once all the ice has been removed, flush the drain with hot water. Some models require an after market drain heater kit. If you will get me a model #, Ican look this up for you.
Vic
Jul 02, 2009 | Refrigerators
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Where can i find schematic diagram of whirlpool refrigerators?
there's no cool air coming into the freezer or refrigerator sections. as soon as it starts there is a clicking sound and it stops. what's the problem? the fan works at the back. i've cleaned all the coils below. thanks
Dec 09, 2008 | Whirlpool GD2SHGX Refrigerator
Washing Machines Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
