Question about Bushnell Instant Replay 8x30 Binocular 5MP Camera Binocular
Battery doesn't light the led
When the on off button is pushed it doesn't respond
Try turning the battery around
Posted on Jan 26, 2009
How do I deactivate my aps57c mobile audiovox alarm
  • Locate the push-button LED switch on the alarm box under the driver's side dash. The small red or black button is used to manually disable the alarm.
  • Put the key in the ignition and turn it to the "on" position. This activates your vehicle's battery, but doesn't start the engine. Press and hold the push-button LED until the LED light stops blinking. Once the LED stops blinking the alarm is disabled until you manually reset the alarm.
  • Start the car. Then, press and release the push-button LED switch once, to reset the alarm.
Apr 01, 2017 | Audiovox Vehicle Parts & Accessories
Tip
How to see if your remote control is actually working
For remotes which use an IR connection you can see if they are transmitting using this trick. An IR type of remote will have one or two LED's on the front end. If it doesn't, than it may be an RF type of remote - this tip will not work for those.
Get some electronic device which can view a live image on a screen. A cell phone camera, digital camera, digital video camera, and (I think) even a web-cam will work. If you're using a digital (still) camera, you don't need to take a picture as long as you see a live image on the screen of whatever the camera is pointing at. Take your remote and find the LED on the front end. There may be one or two. (If there's two, one actually isn't an LED, but that's not too important.) Point the front of the remote at the camera (LED's facing the camera), and press buttons. You should see the LED's light up in the live image. While these LED's normally produce light which the human eye can't see, digital image sensors can, and they change this invisible light to light we can see on the screen. (Cool right?) So, if your remote is working then you'll see the LED light up on the display. (To make sure your camera is actually working as I am suggesting here, find a remote which you know does work and try it.)
The LED should light up for every button pressed. If one button doesn't make the LED glow, you may have a bad button - try pressing it firmly. Buttons can wear out. The image of the LED may appear steady or it may pulse or blink on the viewscreen - this is normal.
If the LED doesn't light up, and you know your camera works like this (you've checked a good remote), try new batteries - that solves most problems. Check the battery contacts in the remote - if they're corroded, (white flaky stuff caked on, looks like dried up salt) - you can clean the contacts with a solution of water and baking soda and a Q-Tip. Use a knife to remove any large chunks. Also, some fine sand paper works too. Both the flat contacts and the springs need to be cleaned. Wash any tools (and hands) with soap and water afterwards. Handle corroded batteries as little as possible - or better yet, use gloves.
If you have good batteries and the contacts are clean, and the LED is not lighting up - it's pooched. Try getting a replacement from the manufacturer (call or email/write them), or use a universal remote.
If you've found this tip helpful, please check the box below. =8o)
#Remote #RemoteControl #IRRemote
on Jul 08, 2014 | Televison & Video
Changed the batteries and now the main screen doesn't show anything. I even did the reset button in the back and changed the batteries again. The sensor works (LED Light blinks). How do I fix this
You said you pushed the reset button a couple of times...is it the one you have to press with a paper clip? you have to hold that button in for five seconds for the reset to take...not sure if you held it in or not...here's two links for the 2-page manual if that doesn't take care of it...
http://westcloxsource.com/usermanuals/70034IM1.pdf page 1
http://westcloxsource.com/usermanuals/70034IM2.pdf page 2
Nov 03, 2012 | Watches
Display light of HP9250C control panel is not working, how do I troubleshoot it.
Building a simple light-emitting diode (LED) light display can be a great project for both children and adults. A simple LED Display Light can be built using
several LED lights, a resistor and a battery. Once the LED lights are soldered together, they can be mounted in virtually any container or mounted to a board
in a pattern of your choosing.
1.Solder the positive (red) lead of the battery holder to one end of the 1K ohm resistor.
2.Attach the free end of the resistor to the positive lead of the LED. The positive lead of the LED is the longer of the two leads. Solder the negative lead
to the positive lead of the next LED. Continue to wire the LEDs, negative to positive
3.Attach the negative (black) lead of the battery holder to one lead of the push-button switch. Solder the other push-button lead to the negative side of the
last LED.
4.Connect the battery to the battery holder. Activate the push-button switch; the LEDs should light up.
5.Disconnect the battery, if needed, to mount the LEDs to your chosen container.
Sep 08, 2011 | HP 9250c Printer
My Sony vaio pcg 3c2l has locked up. The keyboard stopped responding and now the screen is black, but the power light is still on. The power button doesn't respond when I push it. What should I do?
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
May 05, 2011 | Sony Computers & Internet
My dell D810 won't power up. After pushing the power button, one LED light comes on. About 5 seconds later, that LED light goes off. I swapped power adapters and symptoms remain the same. The battery is...
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Feb 18, 2010 | Dell Latitude D810 Notebook
For Zen M: Blue ligth on continuously with new battery
have you tried doing a Software re-set. (Hold the On/Off button in the On position whilst pressing the Reset button). Then try re-charging. The device will take about 10-15mins before it responds if the battery is completely flat.
Jan 22, 2009 | Creative Labs ZEN Vision:M Digital Media...
Viper SST 7701. I replaced the vehicle battery and now the 2007 Saturn Outlook will not start. How do I program the Viper system to allow it to start?
Try to relearn the tach by cranking the car and holding the valet switch(small black push button) until the LED lights solid.The try it again
Nov 26, 2008 | 5900 SST 2-Way Security System / Remote...
Door locks dont operate with remote key fob
Touch Key metal to lock cylinder metal then unlock
Jul 29, 2008 | 2001 BMW 325
Bushnell Instant Replay 8x30 Binocular 5MP Camera Binocular Logo
60 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
