Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
New noise when vac is run
I opened the bottom of the vac to remove the pet hair from the brush roller. The roller slipped out. I got it back in place (not easy.) The roller is turning. I may have it in wrong? Is there an easy way to release the tension on the belt in order to remove the roller for cleaning and then replace it and re-place the belt tension?
    Problem Solver:
  • 6 Answers
Mine was allowing the roller/beater bar to hit the cover as it turned take the cover back off and ensure the beater is in the right place then that the cover is locked in the right place then you can spin it by hand (power cord unplugged of course) and make sure it is clearing everything. BTW, the belt has to be stretched to get the beater bar in place like on most vac.s
Posted on Mar 03, 2009
I have a Lindhaus powerhead MOD.PB12e SN123463. The powerhead turns on and the roller starts turning but after a couple of seconds it starts sounding like something is not letting the roller turn properly...
A common problem is for hair to get wrapped around and forced into the end bearings which causes the motor to work harder or drive belt to slip. Cleaning the hair out can be a short term fix but new bearings might be needed. It's also a good idea to replace the drive belt at the same time as the slipping belt is probably not going to perform well even with new bearings.
Mar 03, 2015 | Lindhaus Vacuums
Belts keep burning and breaking on turbopower 7100
If a roller brush does not rotate freely, the motor shaft spins in one place on the belt until it heats it up and breaks it. Roller brushes can become clogged on the ends, especially with pet hair. The solution is to remove the roller brush completely and inspect onder the endcaps, removing them if necessary to clean them completely. The roller brush should be reinstalled carefully, observing the upward orientation of the arrows on the end caps. Check operation before assuming that the problem has been solved
Mar 24, 2013 | Vacuums
My sd40025 dirt devil ..it is not a upright. it is the follow along, bagless vacuum. has wonderful pick-up but the brush stopped spinning when i was vacumming my rug..i love this vacumm but it is only the...
That's because you got something caught in the brush and it tore the belt (likely) or slipped off the drive portion of the motor (unlikely).
If you look at the bottom where the brush is, there are a bunch of screws to remove the bottom cover usually and can access the belt and motor to run the brush. \
belts are usually 5 to 10.00 get a pack of 2 if possible and don't do heavy rugs or get material caught in the brush lest it will happen again.. typically you can find vacuums in the trash and remove their belts, usually is only 2 or 3 types of belts so get one for free perhaps from trash.
Nov 23, 2017 | Dirt Devil SD40020 Bagged Canister Vacuum
Beater bar belt install
  • 1
    Unplug the vacuum cleaner and turn it upside down, flat on the floor, with the roller brush facing up.
  • 2
    Remove the the bottom cover plate from the vacuum by prying it off gently with a screwdriver blade. Set aside the cover plate.
  • 3
    If the old belt is broke, remove it by pulling the belt from underneath the roller bush. If the belt is not broken but simply worn out, and is still attached, cut it off with scissors.
  • 4
    Remove the roller brush by lifting both ends from the grooved slots in the housing of the vacuum cleaner.
  • 5
    Cut away hair, thread, string and other debris wound around the roller, using the scissors. Tangles on the roller brush are a common reason for belt wear and breakdowns due to the added weight and stress on the roller brush.
  • 6
    Slip the replacement belt over the roller brush and seat the belt in the groove in the center of the roller.
  • 7
    Slide the roller brush back into the grooved mounts on either side of the housing and snap into place.
  • 8
    Pull back on the new belt and slip the loop over the pulley attached to the vacuum motor.
  • 9
    Replace the bottom cover by snapping it back on the housing until it clicks into place.
  • Feb 16, 2011 | Hoover UH70015 Bagless Upright Cyclonic...
    Bin barely fills. Lots of dog hair between brushes and bin, and is now dropping hair balls as it goes around the house
    This is why Roomba recommends a thorough clean of your carpet with a standard vac prior to using your mini vac. Once all heavy debris has been removed, the roomba will maintain that state of clean. If you have that much dog hair, you cant expect such a small roller, brush and dustbin to keep up. sounds like you need the dirt dog instead. It is capable of handling heavier demand areas. Or the
    iRobot Roomba® 562 Pet Series
    Feb 17, 2010 | iRobot 560 Roomba Vacuuming Robot, Black...
    Hoover mach 5 turns off after 10 minutes of use
    I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
    I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
    Another item to check is if your dust filter is not plugged up which is located behind the removable dirt cup. This is the cup that you remove that collects the dust/dirt/hair from your floor. Take the removable dirt cup out by depressing the gold button and then look behind where the dirt cup sits for filter. This can be cleaned out by washing it with soap and water in the sink but make sure you let it dry overnight before placing it back in the machine. This probably causes some of the overheating when not enough clean air is passing through the machine.
    It’s fairly easy to fix.
    Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
    Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
    When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
    I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
    Hopefully you will find this useful.
    Oct 01, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
    My brush will not turn, and the brush control is stuck on "off"
    Jul 05, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
    Brush bar does not turn & makes a loud noise
    You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
    May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Changing the belt
    It is quite easy. Just take off the bottom of the vacuum encasing the roller brush. It should snap off or you may have to unscrew some screws and lift the cover off. Then remove the roller and clean it while you have it out. Now put the new belt on the motor shaft or pulley and slip the brush into the belt. Then replace the roller brush pulling the belt tight. Replace the cover and clean house.
    Apr 03, 2009 | Bissell Upright Vacuum - The Pet Hair...
    Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
    147 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
