Question about Jenn-Air JGW8130A Electric Single Oven
Jenn-Air modle W130 Never before, but now the lock lever will not engage.
#j926499XT The self-clean feature worked since we owned this appliance, now for 22 years when it was new. We still follow the steps required, as printed on the inside of the door, turning the knobs, pushing the "self-clean" button, moving the lever to the right. The BAKE light comes on, the the CLEAN light does not and no cleaning happens. Answers?
  • 1314 Answers
SOURCE: Jenn-Air Oven - Model W46 - Door Lock Lever came loose
you have to turn the breaker off then pull the oven out from the wall till you can get the top off the motor is at the front you will see how it goes
Posted on Jan 30, 2008
  • 1214 Answers
SOURCE: Jenn-Air elec oven finished self cleaning, door locked,F3 error
Go here to get the manual -
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10176680.pdf
Posted on Jan 22, 2009
  • 949 Answers
SOURCE: (90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
Posted on May 13, 2010
  • 1796 Answers
SOURCE: I have a jenn-air range
Hi!!
In order to give you a better answer, please provide the range's model #. In the mean time, unplug range from wall outlet for 5 min. to reset the PCB module, reconnect it back up and try locking the door first and select the settings later.
Posted on Dec 12, 2010
jturcotte
  • 8836 Answers
SOURCE: Jenn-Air Self clean convection oven. Can I get a
Hi, there are several Jenn-Air manuals at appliancedigest.com. You will have to do a free registration to download. Here are the links. Cannot guarantee the right one without model number.
http://appliancedigest.com/index.php?/files/file/482-16010312-jenn-air-electric-wall-oven-service-manual/
http://appliancedigest.com/index.php?/files/file/481-16009722-jenn-air-and-magic-chef-wall-oven-service-manual/
http://appliancedigest.com/index.php?/files/file/479-16022514-maytag-jenn-air-gas-wall-oven-service-manual/
Posted on Dec 25, 2010
Have a wall mounted Jenn-air oven. Have used self-cleaning feature before. Followed step by step instructions to the end including locking the door and pushing "Enter". Went to bead expecting to wake
This is a general answer and not specific. The oven thinks is still in the cleaning mode. If it has one, push the clean button again. Set the oven to a regular bake cycle.
Dec 15, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
We used the self cleaning option and now we cannot get the oven door open. The lever is stuck in lock mode. Can you give suggestion?
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock.
IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature)
Thank you and thanks for using fixya
Sep 29, 2010 | Jenn-Air JGW8130A Electric Single Oven
My oven will not unlock.
Either unplug or turn the off off at the breaker. It may clear the problem. This happens a lot after clean cycles. Sometimes the electronics fry due to high heat, so try not to use self clean very often.
If this doesn't work, leave comments with your oven model and type of lock if you know. The instructions for opening a stuck lock depend on which type of lock you have: solenoid controlled buzz when setting or unlocking and have an arm you move to engage the lock. Heat sensitive locks have an lever you move to lock and un-lock, but don't make noises. Motorized locks don't have handles or levers, and lock by themselves. Thanks for your question, I hope the first instruction helps.
May 08, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Model SVE 47600 - oven door remains locked after self cleaning
Called an appliance repair serviceman....after checking it out...turned out to be a sensor that actually burned up (first time using cleaning feature!!). The oven got so hot it actually burned the wiring going to this sensor. Pretty scary! The repairman said he doesn't trust the self cleaning feature...recommended doing it the old fashion way! He's had to repair many ovens due to the lock remaining locked. IF you do use the feature, he said to absolutely remove the racks first because they will slowly warp and you'll end up replacing them due to uneven cooking (i.e. lopsided cakes). It cost me nearly $200.00 to clean my oven! Could have had my entire house cleaned for that amount!!
Jan 27, 2009 | Jenn-Air JJW8430D Electric Double Oven
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jenn Aire lock for self clean in locked position
The LOCK INDICATOR light must be OFF. This can take up to one hour!!!
Do NOT force the door.
Leave the SELECTION and TEMPERATURE knob alone. The Temperature knob MUST be set to CLEAN
Indicator Light OFF, knobs set to CLEAN - OPEN the slide lever.
Lever open, set the knobs to OFF and away you go
Oct 26, 2008 | Jenn-Air Ovens
Oven door locked - jenn air
My Jenn-Air double oven locked after a clean cycle. My model (JJW8630) has a series of slots cut in the top of the door. Take a piece of stiff wire, coat hanger, and bend a right angle about 1/2 inch at the end, feed the wire into the 3rd or 4th slot from the center on the right hand side. Turn the wire so that the bent piece is on the top and push the wire so it engages the lever which latches the door shut, it is spring loaded and moves easily.
Once the door was opened, I removed the temperature sensor, held by 2 screws, from the top of the oven and eased the wire out to get to the connector. The faulty sensor was reading 4.2 k, at room temperature it should be just over 1k, while waiting for a new sensor to arrive I stuck in a 1k resistor, ex Radio Shack, so the fan stops running and the door latch can be retracted by closing the oven door, or press the switch on the top right of the door opening.
My replacement part was ordered on line for less than 1/2 the official quoted price.
Hope this helps.
Jul 18, 2008 | Jenn-Air JJW8430D Electric Double Oven
Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JGW8130A Electric Single Oven Logo
43 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
