Question about Fujitsu Computers & Internet
How to restore fujitsu lifebook c series
What key is needed to be pressed at boot up in order to restore?I am trying to restore a lifebook c series Laptop
  • 564 Answers
If you have the recovery partition on the hard drive you should be able to access it by pressing F9 continuously when you start the laptop.
Posted on Jan 15, 2013
pagebor
  • 2785 Answers
SOURCE: LAPTOP MANUAL
have you check the manufacture website
Posted on Jul 23, 2008
Geekman
  • 32281 Answers
SOURCE: Display of the Laptop is not coming at all
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 15, 2009
Geekman
  • 32281 Answers
SOURCE: My notebook (Fujitsu Lifebook S6000 series) screen
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Jun 04, 2009
Brandonmxb
  • 115 Answers
SOURCE: thermal sensor error on fujitsu
Don't worry. I'm sure it will be fine, as long as it's not over heating or smoking. lol. But seriously, you should be able to disable that error in Bios under one of those options. If you are still having problems contact customer support for help.
Thanks,
Brandonmxb
Posted on Dec 09, 2009
drifterK
  • 4924 Answers
SOURCE: Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Posted on Jan 30, 2010
Factory restore
1. Turn on or reboot your system. When the Fujitsu logo appears, press the [F12] key.
2. From the Boot Menu, that appears, check whether the <Recovery and Utility> option is present.
If it is not present, it means that the utility must be used from the disc.
Proceed to "Running Recovery and Utility from the Bootable Disc" , if <Recovery and Utility> is unavailable.
http://support.fujitsupc.com/CS/Portal/s...
Dec 22, 2013 | Fujitsu LifeBook AH530 NoteBook
Fujitsu LIFEBOOK A6230 how to factory restore without the cd?
Usually there is a second partition on newer laptops that you can recover with. Look for a startup options when booting or a recovery options key, usually something like F5 or F10, then there will be options to choose from. What operating system are you using? You could possibly use a system restore state from the laptop first being setup.
Sep 18, 2013 | Fujitsu LifeBook A6230 (FPCM33401) PC...
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Where is the ? mark on the p series lifebook?
left of the shift and arrow key andabove the control key you will have to press the shift key to select any key thats above another (/?)hope it helps
Oct 13, 2011 | Fujitsu Siemens Fujitsu LifeBook P Series...
Although I have excellent connectivity when I try to open Internet browser I just get a blank page and Internet cannot connect message. So I want to restore to factory settings and reinstall Vista...
You should go to the BIOS. Make a note of the boot order. Set the first boot device to cdrom.
Once you see a prompt that says press any key to contintue to boot to cd press the Enter Key Once
When you have a prompt that says welcome to windows press R to Repair press F3 to quit and press Enter to create a fresh new copy of windows.
Follow any prompts as required and when you have finished don't forget to change the BIOS boot order, back to as it was.
There you have it, a fresh operating system. All it may need now is the drivers installing and the software re installing.
I hope this is the information that you require.
Nov 20, 2010 | Fujitsu Siemens Lifebook C2230 Notebook
Fujitsu Lifebook N6470 will not boot
Most times these kinda errors are issue with some kinda corrupted driver. Have you tired to boot in to safe mode. To do so shut down the laptop and when you press power to turn it on start tapping F8 key until advanced windows start up shows up.If you cant i would consider taking it back to store where you got it since pressing this button is not supposed to do anything. Most new computers come with Operating System reinstall built in which kinda sucks since some times you just cant get to it like in your case. Restore disk shoud work and you can try making Bios settings back to original since Vista will boot to the CD/DVD drive if it detects media. If this does not work i would not spend too much time on it and would replace it or have it fixed if you have extended warranty. I would also be very careful about posting Product key on any web sites. Hope this helps.
Jan 13, 2010 | Fujitsu LifeBook N6470 Notebook
Hard drive info for Fujitsu T4210
Better late than never. See http://simshsia.wordpress.com/2008/07/15/disassembly-of-the-fujitsu-lifebook-t4200-series-tablet-pc/
I hope this helps. Should you have the original system restore disk ( or copy ), kindly get in touch.
Nov 03, 2009 | Fujitsu Siemens LifeBook T4210 Notebook
Fujitsu Lifebook N3010 boot error
Do you have the original Driver and Application (DAR) CD? If so change your BIOS setting to boot from CD first and boot from the DAR. This will take you to the backup partition DICE (Disk Image Special Addition) on your hard drive. This will allow you to restore your system to the original drive image configuration. You will loose all your data!!!!!!!
Mar 10, 2009 | Fujitsu LifeBook N3010 Notebook
I have a Fujitsu Lifebook P-2040 that I just reformatted. I'm going to install Windows 2K Professional (don't have the restore disks for XP Home). After I reformatted and restarted, nothing happens. There...
Is there any reason for your preference for Win 2K over Win XP Pro? XP Pro would be a better choice over Win 2K.
You may be able to selecting the CD as the alternate boot device by pressing F12 as the laptop is booting up.
I am not familar with BIOS key on your laptop but you can try these keys on a cold boot up (don't use a warm boot up - Ctrl+Alt+Del keys). Try:-
Del
F1
F2
F10
Ctrl+F1 or F2
Alt+F1 or F2
Esc+F1 or F2
Once you get into the BIOS you can change the boot order, set the CD as the first device. You should be able install Windows from the CD.
If these keys don't work go to the Fujitsu WEB site to download the manual, whilst you are there you will also need to download the drivers for your model laptop the Windows version of the devices that are installed on your laptop eg. audio, video, modem, LAN etc. These need to be installed after the Windows installation.
Dec 20, 2008 | Fujitsu LifeBook P2040 Notebook
Computers & Internet Logo
275 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
