Question about Whirlpool Duet Sport WFW8300SW 3.4 cu. ft. Front Load Washer
Leaking from bottom of door - Whirlpool Duet Sport WFW8300SW 3.4 cu. ft. Front Load Washer
  • Whirlpool Master
  • 17,129 Answers
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Posted on Jan 15, 2013
GE model WSXH208F1WW leaks from gap between bottom of door & gasket. Door drags on bottom when you close it. If you push in on bottom of door, it makes contact with seal & stops leaking.
It may be the hinge. Some models can reverse the door swing. Check your manual. If you are able, switch the swing of the door. this may help with the miss aligned door. Good luck!
Oct 12, 2016 | GE Washing Machines
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Kenmore model #16761691 leaking at the bottom of the door. Where is the gasket located? Or is it another problem?
does it leak all the time or did it just start?try running it with nothing in it and see if it leaks,if the dishes were racked wrong the water can get deflected and leak out through the door,also,remove the bottom rack,look at the screws going around the bottom part under the wash arm,if any of those are loose it causes a wave in the dish washer and the water leaks from under the door.if it's leaking from one of the corners the gasket could be bad
Apr 17, 2011 | Kenmore Dishwashers
During wash or rinse cyle, water leaks from the bottom
open the door,check the rubber boot for any holes,ussually that's where it leaks,also wipe the inside of the door,i've found hair and lint stuck on the inside bottom of the door and water leaks out but pull open the rubber boot and run your fingers all around it to check for any holes.you can remove the bottom panel and then run the machine to see where the leak is coming from.
Apr 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
Lg lds5811 leaking in front at bottom left of door. cleaned gasket and door, still leaking. any ideas, thanks
if its leaking down the vent out the bottom of the door when it runs.you need to replace the vent fan ***.the gasket on the vent door is bad.
Feb 24, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher leaks from the bottome of the door
if it leaked everytime then it would be your door gasket.but not everytime it's your door latch not engaging completely everytime.open the door and look and see if you can access the tightening screw for the door latch.probably not but look anyway.if you can then tighten the latch.
Nov 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
I have a Kitchenaid KUDS25SHBL1 dishwasher that is leaking from the bottom of the door. I replaced the main gasket around the body that the door seals against, and it is still leaking.
Have you removed the outer door to check if the leak is coming from inside the door . also check the bottom door seal ? also check the around the soap dispenser as I have had to silicone around them to keep them from leaking before..let me know if this helps at all.
May 11, 2008 | Dishwashers
Whirlpool Duet Sport WFW8300SW 3.4 cu. ft. Front Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
