I unplugged my cable from the back of my tv to try and hook up and Xbox... Well when I plugged the cable cord back in to the television i got a blurry white and black screen
Do you have a game mode on your tv if so push the button
Posted on Jan 15, 2013
This happenned to me before and maybe clean the area with a spray or even you need to get a new cable hookup.....these are quite reasonably priced especially with generic brands....
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Posted on Nov 29, 2008
freetek
  • 5568 Answers
SOURCE: White screen only on Sanyo DP26648
Your reported symptoms are odd in that most failures are related to the primary power supply but that takes down both audio and video.
The backlight is obviously working (white screen) but it is no longer receiving any video information and this points to a failure of the logic (or the output of the power supply that services logic) used to control pixels on the screen.  Some screens have the majority of the control ICs actually mounted on the LCD assembly and because of very close pin distances used on dense ICs, they are often not replaceable by hand since they were installed by robotics.
I would first suspect (and hope for) the logic voltage output of the power supply to be the culprit.
If any of you posters have had a repair done and received any kind of a detailed report (you should), would you be kind enough to post it back as a comment to this original message?
Posted on Jan 16, 2009
freetek
  • 5568 Answers
SOURCE: No power on Westinghouse LTV-46w1 Television
This kind of failure is very common; that is why I suggest that one should keep the old CRT TV, buy a converter and put them both in the garage or basement so they are handy when our s*e*x*y new sets go belly up.
With fair confidence I can say that the main power supply has failed.
If you want to try this on your own, it only will require the removal of a few screws and a flashlight.
- Unplug the set overnight. - Remove the rear housing  - Use some logic and these tips; look for a separate board with larger than average parts on it and seems closer to the power cord than others. This will be the power supply.
Check the board over for something that looks like a part number and record it. If you find more than one, one of them will be the bare board number, the second (sometimes on a sticker instead of printed directly on the board) should be the part number for the assembly.
Search for the Westinghouse service company nearest you and call them with this info. Ask if they repair these or just sell new ones. If it is the latter, don't pitch the old one, continue to look for a repair service that will take it on after you have the new one in place and can watch your favorites again. The new supply will likely cost between $90 - $150 and with a little common sense, most anyone can remove and replace these in the set. Expect any repair to cost about the same as a new supply; US technical labor costs more than Chinese assembly labor.
These supplies can be as reliable as the primitive older type but companies refuse to use the high-grade components necessary to give them a long life so they fail much sooner than the old, less efficient kind known as 'linear' supplies.
Posted on Mar 22, 2009
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
  • 10 Answers
SOURCE: westinghouse LTV30w2 has blank screen and audio
What you have is a darfon V144 board (junk). it's a simple fix if you know how to use some basic tools and a soldering iron. Get an led (i used digikey's PN: L10041-ND) and solder it from pin 10 to pin 16 on the OZ960 chip on the inverter board. If you need the chip layout type "OZ960 pdf" in google. Hope this helps.
Posted on Dec 31, 2009
Vizio Model E470VL, HDMI ports are not functioning properly.
on some TV's the Analog board is where the other cables plug into. I know on a Sanyo I am working it looks like the analog and main digital board are all the same. but they are just hooked together. I bought an analog board for less that $30 from Shop Jimmy.com. The prices might vary according to the make and model of TV. need to be careful and remove the back of the TV . and get the part # directly off the board. BE SURE TO UNPLUG from the wall outlet first. Nearly all the boards carry a charge even when unplugged so be careful.
Nov 18, 2014 | Vizio E470VL 47 in. HD-Ready LCD TV
Tip
How to create a Xbox live ID
<ol> <li><br /> <p>With your xbox turned off unplug the ethernet cable from the back of your Xbox.Next unplug the xbox 360 power cord from the back of the Xbox 360.<br /></li> <li> <p>Unplug ethernet cable<br /> <p> and power cord from the modem. Wait for about 1 minute and then plug ethernet cable back into the modem.Now you need to plug other end of the ethernet cable into the back of the Xbox 360.<br /></li> <li> <p>Plug the modem power cord back into your modem , wait for lights to light up on your modem (this can take up to a minute).The last step is to plug the Xbox power cord into the back of the Xbox, turn it on and you are ready to go<br /></li></ol>
on Dec 06, 2010 | Microsoft Xbox 360 Console
Xbox 360
Match the colors of the cables with the cords and connect...
Mar 16, 2014 | Curtis LCD3235 32" 720p LCD TV LCD3235A /...
My tv has no sound, not when cable is on or my xbox 360 is plugged in.
Try unplugging the power cord from the TV for 10 seconds then plugging it back in. This may reset the TV and resolve the issue.
-G33k
Sep 20, 2011 | Envision Monitors L26W761 26 in. LCD HDTV
How to setup xbox live
Hello there
No problem, in just a few steps you too will be online and ready to go.
Ethernet Cable
With your Xbox 360 turned off unplug the ethernet cable from the back of your Xbox.
Xbox 360 Power Cord
Next unplug the Xbox 360 power cord from the back of the Xbox 360.
Unplug ethernet cable and power cord from the modem. Wait for about 1 minute and then plug ethernet cable back into the modem.
The last step is to plug the Xbox power cord into the back of the Xbox, turn it on and you are ready to go.
Oct 10, 2010 | Microsoft Xbox 360 Console
I am trying for the frist time to hook up my son xbox360! what do i need to do. The hook up is are pluged in tight & my internet is on as you can see" what do i do?
If you are trying to connect to xbox live you should plug in your ethernet cable to the back and than turn on the xbox 360 and select xbox live..
If you are trying to "hook" recieve visuals plug all the cords the xbox came with into the right places and plug the opposite ends correctly into the tv than make sure your cables are on the settings tv not hdtv than find the input your tv must be on to ie: input1 or source
Apr 23, 2010 | Microsoft Xbox Console
Xbox and dish network problem
if you have like a dvd player then try hooking the xbox up to it in the front where the video is for the 3 plugs then try to plug dish network in the back of the dvd where the ant in plug is at then take the cord from the dvd player and plug it in the back of the tv if this dont work let me know
Aug 08, 2009 | Microsoft Xbox 360 Console
How to fix flashing dots xbox 360?
It could be the cable port needs resetting. On the TV unplug the tv and on the xbox disconnect the cord and turn off the xbox and unplug it. Then put the different cord on and plug the 360 back in.
Jul 09, 2009 | Microsoft Xbox 360 Console
Help me
turn your console off unplug the audio/video cable from back of xbox and plug it back in. make sure the white cord is in the hole of your tv and make sure the yellow one is in the yellow on the t.v. (unless your hd). make sure the cables are not loose. and on the plug in the back of your xbox for the audio/video cables is a switch that says hdtv and tv make sure its set to whatever your hooking up.
Mar 26, 2008 | Microsoft Xbox 360 Console
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
