Question about Gateway 7320GZ Notebook
Keyboard on laptop does nothing.
The only thing when i turn on my Gateway 7320 laptop is at the begening BOOT menu press or BIOS settings press Then a sign on toppops up that says American Megatrends, and info about comp, Pri master, Sec master, It sayes CMOS settings wrong ect. Press f1 to run setup . nothing happens when i press any of the keys.
  • Art Ellison
    Art Ellison May 11, 2010
    Can you enter setup by pressing the F1 key?
Gateway W35044LB
  1. Turn on the computer.
  2. After the Gateway BIOS logo appears, repeatedly press the F8 key. The Advanced Boot Options menu opens. If it doesn't the motherboard is most likely bad).
  3. On the Advanced Boot Options screen, use the arrow keys to select Last Known Good Configuration (advanced), and then press the ENTER key.
If that does not work, turn PC off, Do this again, but this time choose 'repair your computer' at the top.
If it still does not work, either your hard drive went bad or Windows is corrupt. Either way Windows must be re-installed.
Feb 01, 2014 | Gateway Computers & Internet
Boot screen
Try these two things:
1. Go to your BIOS setting by pressing F10 immediately after you switch on your notebook, then select your HDD as your First boot drive and then save changes and exit. If it does not works then follow step 2.
2. Reinstall/freshinstall your Windows OS with a windows OS disc.
Jan 17, 2014 | Gateway NV4402u Notebook
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
How do I get my Gateway laptop to boot?
F12 BOOT DIVICE MENU WEN LAPTOP IT TURING ON
Jan 11, 2013 | Gateway Computers & Internet
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Forgot my password want to restore like factory new i have a gateway laptop mt3421
Hi.
  1. Remove all CDs or DVDs from the optical drives.
  2. Turn off the computer, using the normal Windows shut down process.
  3. After the computer is turned off, disconnect all USB devices except the keyboard and mouse. This includes USB devices such as a printer, scanner, removable storage, or camera.
  4. Turn on the computer. After the Gateway BIOS logo appears, repeatedly press the F8 key. The Advanced Boot Options menu opens.
  5. On the Advanced Boot Options screen, use the arrow keys to select Repair your Computer, and then press the ENTER key.
  6. In the System Recovery Options dialog box, select the appropriate keyboard layout, and then click Next.
  7. In the System Recovery Options dialog box, click the down arrow to select a user account that has Administrator rights, then click OK.
    Note: The Administrator account is disabled by default.
  8. In the System Recovery Options window, select Recovery Manager.
  9. In the Gateway Recovery Center window, click Next.
  10. In the Gateway system recovery window, select Full factory recovery.
  11. In the All data will be lost window, select Yes, and then click Next.
  12. The Windows partition is formatted and Windows is installed.
  13. In the Recovery is complete window, click Finish.
  14. In the System Recovery Options window, select Restart.
When the computer restarts you will need to set up the laptop again.
Good luck.
Jun 17, 2011 | Computers & Internet
I have a Gigabyte GA-945GM-S2 motherboard. I want to change the boot menu to boot from the CD. The problem is the up/down arrows won't move the highlight bar from the floppy.
I love using Gigabyte boards in my own Home Theater PCs, so I run across this problem sometimes when I'm setting them up for the first time with a USB keyboard. Pretty sure the problem you're having is the same--the BIOS isn't set to 'recognize' USB keyboards by default, so try the following:
  • Turn it off, and connect an older PS/2 style connecting KB to it;
  • Turn it back on, enter the BIOS, and find the settings page with 'USB Keyboard' in it;
  • Change that setting to BIOS rather than SYSTEM, so next time you boot, it will 'see' your USB KB. Plug in your USB KB before rebooting, then save the settings and reboot the PC again.
  • You can leave the old PS/2 KB plugged in to make sure you can change things, but try your USB keyboard out as well. You should be able to control BIOS settings upon reboot.
Hopefully this was all you needed. If it persists, be aware that some Gigabyte mobos have had BIOS issues galore (eBay is full of Gigabyte BIOS chips).
Feb 26, 2011 | Computers & Internet
Bought a Gateway model M465-E on Ebay only to find out the bios is pass-worded so I cant load Win XP because of The infamous "no hard drive error because of the Sata Driver,and i cant get to the...
I'm sorry but I don't know how to reset your BIOS. But to get around your problem, you should be able to enter the boot menu to boot to the optical drive to install your OS.
In order to access the boot options on this notebook computer, press the F10 key while the Gateway screen is displayed during the startup process. This opens a Boot menu with the option to start the computer to any of the available drives. Use the UP ARROW and DOWN ARROW keys to select a menu option, and then press the ENTER key to start to the selected device.
To "boot" (start) to a CD, DVD, or a floppy disk, the media must be in the drive when starting the computer.
Dec 21, 2010 | Gateway M465-E Notebook
My gateway 2118u netbook will not boot or turn off the screen says: For Atheros PCIE Ethernet Controller v2.0.0.9(05/08/09) Check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable...
Can you access your BIOS when you turn on the computer?
Somewhere in the BIOS you may have inadvertently changed the netbook to boot from the "Network via PXE" instead of from your local hard drive.
To enter the BIOS, you must restart the PC and enter BIOS setup or BIOS features by pressing Delete or another hardware specific key on BIOS screen startup.
From there, you should encounter a series of menus that you can navigate only with the keyboard... not the mouse. With luck, you will find a boot menu option that you can correct.
Make sure you save your choices on exiting and restart your PC. With a little bit of trial and error, you should be able to coax your netbook to boot from its internal driver.
Sep 09, 2010 | Gateway LT2001u Netbook
Gateway boot problem
If it is not seeing the keyboard, you need to get a ps2 keyboard, go into the bios settings, and make sure usb keyboard support is turned on. Alot of times the default is disabled.
If the harddrive has a virus, make sure you reimage it or format it completely before using the unit.
Sep 04, 2008 | Gateway GT5220 PC Desktop
Gateway 7320GZ Notebook Logo
114 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
