Question about Luhr Jensen Grilling
Doesnt burn chips very long - Luhr Jensen Grilling
    Sergeant:
  • 211 Answers
Do you soak your chips prior to use? Then pile the chips on the end are of the coals and let the heat grow to incorporate the soaked chips, place the chips in a cone shaped pile, this will let them smoke from the bottom-up.
Posted on Jan 16, 2013
Studiophile AV20 left speaker doesnt work when connected. its passive, and does function when plugged to another power source. Right speaker cannot support left, or any volume above mid setting, and burns...
Probably NOT a transformer. Most likely in the power amp. Many have a thermal cutout that shuts the thing down when the chip/stick gets to hot. Your description leaves some questions... IF you don't get anything at all out of the left, then look first for a short from the amp to the output jack. This probably has a dual chip amp in it and half that chip may be bad heating up and shutting the whole thing down.
Jan 01, 2011 | M-Audio Avid Maudio 99005226600...
My ignition switch broke replaced with a new one from autozone but the key doesnt have a chip like my old one ..now my car doesnt start do i need a key with a chip?
Yes Get the right key at a GM dealer, take along the car serial number because there are several chip options and they will have to look it up with serial number
Dec 06, 2010 | 1989 Chevrolet Corvette
Burned Power Regulator Chip
Its quite difficult to get the Chip in the open market. Kindly check with Compaq service provider in this regard.
Mar 16, 2010 | Compaq Presario Notebook
I got a burned game and it doesnt play on my xbox 360 what do i need to do to get it to play
You need to have a modchip fitted in your xbox to allow it to play burned games, if yourproficient with a soldering iren you can do it yourself.
you can get the chips here:
http://www.modchipworld.co.uk/store/xbox-mod-chips-c-48.html
they also have diagrams/instructions for doing the mod yourself.
Dec 04, 2009 | Microsoft Xbox 360 Console
No video but sound okay, chnged cables n still
Yes this is nothing to do with a faulty cable in most cases. It is to do with the display chip heating up and burning out, you need to stop the heat build up yourself or send it back in.
Nov 02, 2009 | Microsoft Xbox 360 Console
I have a Lowrance 7200C GPS (marine) unit with a "Navico 041-0680-17 chip. It doesnt show the depth contours, is there an upgrade or do I buy another chip? and if so, what chip will be best for my unit?...
Not showing the Depth Contours usually means it doesnt have that programmed on the chip.
The best Chips Ive ever seen, used or worked with for the Lowrance's are the "Navionics" and Fishing Hot Spots. Both can be obtained from Cabela's...either retail or online. And normally go from 99bucks for last years maps to 199 for this years. Hope this helps.
Oct 15, 2009 | Lowrance Globalmap 7200c Gps 7" Screen...
Can i put wood chips in an aluminium tray and put it on grill without catching fire ive tried before and it doesnt smoke alot the wood chips turn black im i doing it wrong
If you are trying to do this to make a smoker there is an easier way. First soak your chips in water for at least a half an hour. after this put your chips in a piece of aluminum foil, wrap them up and poke a few holes in the foil. Afterwards just put them on yopur coals or on top of the grease shields on a gas grill and cook away. The holes allow the smoke to escape as the chips get hot and smolder. If you don't soak them they just turn black and give little smoke as they burn up rapidly.
Sep 26, 2009 | Computers & Internet
Beeping sound at boot up, screen showing auto save and not booting up
remove the memory chip, clean it, insert it back in the slot again. "be carefull" dont wrongly place the memory chip else it will burn, there r two clips on each end of the slot, and in the middle a separator. hope this will help. if u have a graphic card in it remove it, clean it, and insert it back on the slot. if doesnt work then replace the memory chip or graphic card. now if u have two or three memory chips in the slot, then test one by one. remove all, then place one, then turn on pc see if the display come, by this way u will know if the chips are good or not, then try the others.
Aug 09, 2009 | Dell Inspiron 530s Desktop Computer...
My chipped xbox360 heats up n goes off.i want de harddrive bak on
to do this you would have to have the xbox upside down and thats so the hard drive doesnt crush the core and you dont friggin burn your hand like i did
Aug 04, 2009 | Microsoft Xbox 360 Console
MSI P6N V2 motherboard doesnt work with Core2Duo E8400
ur motherboard goes dead now only one solution have that u must change ur board . coz by overclocking ur motherboard vg chip gone burn and no one can change that chip .thanx enjoy good luck plz vote for my comments
Apr 20, 2009 | Computers & Internet
Grilling Logo
51 people viewed this question
Top Luhr Jensen Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Luhr Jensen Grilling Expert? Answer questions, earn points and help others
