Question about Jeep AM/FM Cassette with CD Changer Controls - Upgrade Swap
Radio wont work at all
I have a 94 jeep cherokee and im in the middle of replacin the old radio and one of thw wires touch another one and sparked.. i tried hookin the new radio up and it didnt work so i tried hookin the old one up and it wont work either...
    Scholar:
  • 116 Answers
Most likely, if the key was NOT on, you blew the memory fuse (Factory wire color pink). Are your dome interior lights out? The fuse is either under dash by feet, or under the hood. Don't worry, I've been installing for over 28 years and I've done it a "few" times :-)
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
NEED HELPPPP with 94 Jeep Wiring
Check out a web site called NAXJA (North American XJ Association) it's a Cherokee forum.
May 21, 2013 | Denso 1994 Jeep Grand Cherokee Laredo 4.0L...
96 Jeep Cherokee WON'T start My daughter's 96 Jeep
did you replace the ECu with a used one or new. if it a used one did you match it to the old.why di you change the ECU.? when you turn the key in the start position does the fuel pump turn on? does it crank? do you know if there is spark if you pull one spark plug wire?
Dec 04, 2012 | Cars & Trucks
Firing order for 94 jeep cherokee. NOT A GRAND CHEROKEE. its a 6 cylinder 2wd. messed up the firing order while replacing spark plugs now im screwed it up. please help
I BELEIVE IT'S 123456 CLOCKWISE,BUT YOU CAN PICK UP A MANUAL AT ANY PARTS FAIRLY CHEAP,MUGHT HELP YOU WITH OTHER REPAIRS.
TIM
Dec 28, 2010 | 1994 Jeep Grand Cherokee
On my 94 cherokee sport the ac blower, turn signals, and radio
could be your ignition switch is bad. it is old ya know
Nov 28, 2017 | 1994 Jeep Cherokee
My 94 jeep cherokee started ran for a minute or 2 and stopped
i would suggest checking to see if you are getting fuel by disconnecting the fuel line at the fuel rail and turn key if no fuel then its either fuel pump or fuel filter. if you get fuel then it would be the spark
Jun 14, 2009 | 1994 Jeep Cherokee Country
I HAVE A 94 JEEP GRAND CHEROKEE PUTTING A PIONEER DEH-1900MP STEREO IN AND WHEN I SHUT IT OFF THE STEREO WONT SAVE THE PRESET STATIONS
the problem is you dont have the battery wire on the radio hooked up to a 12v constant. it sounds like you have to take the battery wire of the radio and hook it up to a wire that stays 12v all the time even when the car is off.
Feb 21, 2009 | 1995 Jeep Grand Cherokee
I am in the middle of replacing my radio with a newer one in my 94 jeep cherokee and one of the wires touch another one and sparked and now neither of radios work when i hook them up
Check your radio fuse.. if it is ok, and the radio does turn on and you have no sound, chances are you either popped your "amp" fuse or worse, popped your factory amp.. let me know what exactly is or isn't working right now.. but make sure you check your fuses...
Jan 23, 2009 | 1994 Jeep Grand Cherokee
94 Jeep Grand Cherokee MY transmission went out
no it wont work.they made too many changes with them about 2 years older and id say yes but no they wont interchange
Dec 31, 2008 | 1994 Jeep Grand Cherokee
94 jeep
Sounds like you have a wire touching metal. Make sure all the Radio wires are capped or tapped.
Dec 18, 2008 | 1994 Jeep Cherokee Country
94 Jeep Cherokee won't start
I believe the green wire is a pulse from the distributor and its a ground signal. I could be wrong since is been a while since i left the jeep dealer...I would take the coil out (2 bolts on most) and take it to autozone. They can test it in minutes for free. Either that or the ignition module but more common is coil.
Aug 06, 2008 | 1994 Jeep Grand Cherokee
Car Audio & Video Logo
116 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
