Region code on LG DH 6220S
I can get to the EEPROM screen but not sure which numbers to change, my screen shows these numbers: f1 00 4d c4 00 69 80 00 00 00 Bought in Colombia (RC=4) and want to watch US DVDs (RC=1). I tried 1d, c1, and 1d-c1 combinations. Do you know what I should try to get to RC=1?
SOURCE: Playing region 1 DVDs in LG DR165 receroder
go to dvd set up then scroll dow to lock then push 0 seven times
Posted on Feb 04, 2008
SOURCE: hack region code for SV2000
I found this info.....it doesn't work for my model SV2000 ( WV806 ) , but it might for yours SV2000 ( WV10D6 )
With the recorder on stop, not on a menu screen. press on remote; CMSKIP-1-2-3. this will take you to a page labeled "F/W VERSION DISP" this will display the current firmware version and model numbers. To exit , press the "RETURN" button. DO NOT PRESS "OK" on remote , pressing "OK" will reset your player settings.
View disk manufacturer information:
with a disk inserted into recorder and stoped, not on a menu screen; press on remote CMSKIP-1-2-3 to go to firmware information screen.press the rigth arrow "->" once. this will display the disk media type and disk manufacturer ID. To exit, press the left arrow "<-" once to go to the firmware display screen, then press the "RETURN" button. DO NOT PRESS "OK" on remote , pressing "OK" will reset your player settings.
Posted on Jul 25, 2008
LachoH
  • 12 Answers
SOURCE: How to unlock code for LG dvd player model DVX183?
Hi, have you tried this? It worked on my LG player.
1. Open DVD tray
2. Press "0000" on the remote.
3. A screen will appear saying NEW REGION CODE displaying the current one.
4. Press "0" for all zones.
5. Press the "select" button on the remote.
6. Close the CD tray.
7. Power off
Posted on Feb 21, 2009
SOURCE: Unlocking the LG HT303su DVD from region2 to region 0
Hi, I could not get it to work using the other ways, Also I am not sure if this might help I am in Australia region 4 and the below worked for me
(1) Make sure there's no disc in the system and turn it off. Turn the system on again and it will display a "no disc" message on your TV.
(2) Use the remote control: press the "PAUSE" button and then key in the code "314159"
(3) Your TV then displays a menu for choosing the desired region. Select "0" to make your unit an all region player.
(4) Press the "PAUSE" button again.
(5) Turn the system off and wait a few moments before restarting.
Posted on Feb 09, 2010
SOURCE: Need multi region hack code pioneer dv-220v-k
There is no need for region hack on this unit. It plays region free and all PAL dvd's out of the box without reprogram.
Posted on Mar 04, 2010
Lg dp132 check region code
1.Switch on the DVD player without any Disc inside
2.The screen should display 'no disc'
3.Eject to open the DVD tray
4.While the tray is open, press the 'STOP' button then hold the 'ENTER' button for 5 seconds
5. A new screen will appear (Regional Management Test Code) which will allow you to change the region code using the up and down arrow keys on the remote control.
6. Change the code to '0' and press the PAUSE key to exit
Dec 30, 2013 | LG Televison & Video
Eeprom reset for LG DVD HT965
You will need to reflash the EPROM to original spec if you can find it.
Sep 17, 2013 | Computers & Internet
This console has been banned for violations of the Terms of Use. To protect the Xbox LIVE service and its members, Microsoft does not provide details about console bans. There is no recourse for Terms of...
You must do the following to get access for free:
requires a virgin xbox that has not been banned (a friend's) and somewhat knowledge about computers.
Banned Xbox Live Fix - New EEPROM ' (Old Tutorial)
To get unbanned you need to purchase a new xbox EEPROM(pal or ntsc). Steps for installing it are listed below. IT WORKS. Just make sure your orginal MS info is correct and your modchip is turned off.
GETTING THE EEPROM FILE FROM THE UNBANNED XBOX
(TO INSTALL YOUR EEPROM, MAKE SURE YOU ARE USING CONFIGMAGIC FINAL* ALL OTHER VERSIONS ARE BUGGY AND WILL CAUSE PROBLEMS. ALSO, DO NOT USE THE SOFTWARE: EEPROMER)
[This is only if you want to backup your original eeprom file]
1. In EvolutionX, do the "Backup" command in the Utilities menu. It will generate files about your Xbox specs.
2. FTP in your Xbox, or use a file manager tool, and in C:Backup, you will find a file called EEPROM.BIN
3. FTP that to your PC HD or remember its location for future reference.
SETTING UP THE FILE FOR CONFIGMAGIC FOR THE BANNED XBOX:
1. Once you have Configmagic loaded onto your HD or on your PC, there will be a directory in it called DATA.
2. Move the EEPROM.BIN file, the new unbanned EEPROM you purchased, into that DATA directory, overwriting the EEPROM.BIN file that is already there.
3. If you are making a Configmagic CD, you can now make the ISO of it and burn it. Xbox HD users, don't worry.
RUNNING CONFIGMAGIC:
1. Load up Configmagic.
2. A warning screen will be shown, press "A" to bypass it.
3. When Configmagic finally loads, it will show your current EEPROM on your Xbox. Make a note of the DVD KIT ZONE and VIDEO AND XBE REGION information. "NTSC, Region 1" for US Xbox gamers "PAL, Region 4" for UK Xbox gamers
4. Select "LOAD XBOX EEPROM" in the menu.
5. Select "UNLOCK HD" in the menu.
6. Load the EEPROM.BIN file in the DATA directory by choosing "LOAD EEPROM FROM .BIN FILE"
7. If you see that the VIDEO AND XBE REGION information is different, you MUST change it. Go into the menu and choose "ON-THE-FLY EDIT EEPROM". Change the VIDEO AND XBE REGION number to the proper information of your former EEPROM.
8. Now, select "UPDATE XBOX EEPROM" in the menu.
9. Your Xbox's EEPROM will now be updated with the file in the DATA directory.10. In the menu, select "LOAD XBOX EEPROM". You will notice your EEPROM is now different! Success.
11. Select "LOCK HD" from the menu.
12. Select "EXIT CONFIGMAGIC" in the menu.
IMPORTANT TIPS:
- If you were using the XBOX DVD KIT to play DVDs, and the Xbox gives an error about region, load up Configmagic and change the DVD KIT ZONE number to the number of your previous EEPROM. UNLOCK the HD, choose "ON-THE-FLY EDIT EEPROM" in the menu and simply change the DVD KIT ZONE number. Then, UPDATE XBOX EEPROM and LOCK HD. Exit Configmagic.
- You can view any Xbox EEPROM using your PC by getting Liveinfo PC program. It will show all the details of an EEPROM.BIN file. You might find it easier to edit any possible changes to your DVD KIT ZONE or VIDEO AND XBE REGION using the program, rather ON-THE-FLY EDIT EEPROM in Configmagic.
- Sometimes, with a PAL EEPROM, your Xbox's time might be wrong or video settings will be different. Go into the MS dash and change the settings to the way you seem fit.
Special Notes:
- If you were banned with your original eeprom, once you replace your eeprom, you will need recover your account. To do this, simply select the account recovery option. Once this is done, you will need to verify some personal information in order to retrieve your account.
Nov 07, 2009 | Microsoft Xbox 360 Console
I have an LG DVD Player/Video Cassette Recorder V271 and I want 2 play an American DVD on it...do you know the unlock code please?
Turn on the unit and open the tray. Press 0000 on the remote to access the DVD region code selector.
Change the EEPRom code to 0 to remove the region lock.
Press Pause to exit the screen and your LG V271 should now be region free.
Sep 13, 2009 | LG V271 DVD Player/VCR
Can not play all dvds on my lg V271 player
Turn on the player and open the tray. Press 0000 on the remote to access the DVD region code selector.
Jun 10, 2009 | Sharp DVRW250 DVD Players
Mar 06, 2009 | Televison & Video
I'm looking to unlock (or change) the regional code on DVD player
1. Power on the player with no disk in the drive.
2. Wait for the "No Disc" message to appear.
3. Press Pause on the Remote.
4. Enter 1, 4, 7, 2,
5. Region 2 EEPROM: 54 52 00 C3 06 55 F0 00
6. Press Pause on the Remote.
Region 1
EEPROM : 55 53 00 41 06 55 60 00
Jan 04, 2009 | LG DP771
Multiregional code for LG V271
Jul 29, 2008 | Televison & Video
Unlock code for LG V271
Jun 11, 2008 | Televison & Video
How can I make my LG Model V271 Multi Regional
Apr 23, 2008 | LG Televison & Video
Televison & Video Logo
Top Televison & Video Experts
