Question about Polaroid V30DMBT-UP2 Television
Mitsubishi WD-55513... That want turn on LCD on front keep blinking tryed to reset TV don't work what next?
  • 2 more comments
  • Tony Clayton
    Tony Clayton Jul 31, 2007
    46 Hitachi model number is 46W500 kept shorting out H.O.T
  • Tony Clayton
    Tony Clayton Aug 10, 2007
    REplace the four caps in the tuner still getting flashing green LED,checked all three 4A 125v fuzeses (I checked for communty on fuzes got it).
    Now when a applly power the the TV set I hear a chirping sound like chirp the nothing.
    Where do I go from here?
    Need help bad Thankyou advance
    techworm
  • Tony Clayton
    Sorry That's for a WS-55513 Mitsubishi tv
  • Tony Clayton
    Tony Clayton Mar 18, 2009
    The problem was in the shutdown circuit H.O.T hor output transistor
Mitsubishi WS-55513 blinking light
Try first unplugging power cord for one hour.
Oct 06, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking Light Problem on Ws-55513
If bad capacitors are the problem then replacing them will involve soldering.
If the problem is something else less visible then fault finding will be difficult without the proper service manual.
http://www.completeservicemanuals.com/mitsubishi/crt-projection-television/ws-55513-service-manual/prod_37.html
This will show the correct disassembly and test procedures.
Good luck.
Oct 20, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Lamp lcd
Make sure lamp door is properly on, there is a sensor on the door.
Sep 19, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Mitsubishi WS-55513 won't power on.
there is an electronic problem inside the tv you shoud go to an authorized service because the power supply to this tv it is in protect mode somehthing hapened inside and need to be repair
Dec 11, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Dec 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Power button is blinking but tv does not work
when my tv does thiss I unplug it, replug it and it works.
Nov 16, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
I can't turn on the TV.
I had the same problem. Unplugged it, reset it, everything. I went to work the next morning and left the light blinking, came home from work and it was off. I turned it on and so far, so good. Just give it some time to reset internally
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Will not reset
4 caps in the standup shielded module get bulges on top--obvious failure. Replace them. Seen it many times
Oct 10, 2006 | Mitsubishi WS-55513 55" Rear Projection...
Polaroid V30DMBT-UP2 Television Logo
113 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
