26 is 40% of what number
Dividing the prevents to get the answer
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
Divide 26 by 0.4 and get 65.
Posted on Jan 15, 2013
What is the ration in simplest form 20 to 15 result
it is a 'ratio' not a 'ration'.
So you want the same smallest number that will go into each of the number 20 and 15? Try dividing them both by 5 and tell me what the answer is?
Jan 22, 2017 | The Office Equipment & Supplies
How many square meters in 90,000 linear feet of 41.3" wide material?
First, we need to determine the number of square units in the Imperial system. We can choose to do the calculation in feet or inches.
Let's do it in inches first. There are 12" in a foot, so we multiply 90,000 by 12 to get 1,080,000 linear inches. Multiplying this by 41.3", we get 44,604,000 square inches. We can convert this to square feet by dividing the number of square feet by the square inches in a square foot. Since a square foot is one foot by one foot, or 12 inches by 12 inches, there are 144 square inches in a square foot. Dividing our previous answer by 144 will give us 309,750 square feet.
Converting to square metres. An inch is defined as 2.54 centimetres ("cm"). Thus, there are 2.54cm x 2.54cm in a square inch or 6.4516cm^2 in a square inch.
Using the 44,604,000 square inches we got above, and multiplying this by 6.4516, we get 287,767,166.4 square cm. There are 100 cm in a metre, so there are 100cm x 100cm in a square metre. So there are 10,000 square centimetres in a square metre. I get 28,776.7 square metres.
There are 3.280839895 feet in a metre. So there are 3.280839895 x 3.280839895, or 10.76391042 square feet in a square metre. Taking 309,750 square feet and dividing by the 10.76391042 we get 28,776.7 square metres.
Good luck.
Paul
Jan 08, 2016 | Office Equipment & Supplies
How does dividing mixed numbers compare with dividing fractions?
This may not be what you want, but I turn the mixed number into a fraction. Say 5 1/2, you multiply the whole number (5) by the denominator for the fraction (2), then add the numerator. So you have 5X2+1. That is the new numerator, it goes over the denominator. This gives you 11/2. To check it divide the numerator by the denominator. 2 into 11 gives you 5 (Rem) 1. 1 is the numerator now and it goes over the denomerator. 5 1/2.
I know it sounds like a lot, but try about ten or so, it becomes 2nd nature. You can make it all into decimal, 5 1/2 becomes 5.5, but now you have to put more numbers into the equation.
This is true. I had a math teacher ask me if he had to cut down a tree so I'd have enough scratch paper.
Jan 26, 2015 | Office Equipment & Supplies
How to calculate mode with caso fx-991ES
MOD simply calculates the remainder that is left over after dividing by the MOD parameter.
For example, 10MOD7 = 3 since you can only divide 7 into 10 once, leaving a remainder of 3.
For larger numbers, eg 389487MOD31 you start by dividing 389487 by 31, which gives 12564.09677 (on the display), however you only want the fractional part so subtract 12564 to give 0.0967741935 . This includes the lower value digits that were previously hidden. Then multiply this result by 31 which gives 2.999999999 on the display. Since the result of a MOD calculation has to be a whole number, the answer needs to be rounded to 3. If the answer doesn't easily round to a whole number, it is likely that you have gone beyond the calculators working capacity.
An alternative method is to take the integer part of the first result (12564) and multiply it by 31 to get 389484, then subtract this from 389487, giving the answer of 3.
Feb 23, 2013 | Casio FX991ES Scientific Calculator
How to find remainder as a solution in CASIO fx991ES
Finding the remainder from a division calculation is often referred to as using the MOD function, though this isn't available directly on the fx-991ES.
To obtain the remainder, for example when dividing 10 by 7, you can only divide 7 into 10 once, leaving a remainder of 3.
For larger numbers, eg when dividing 389487 by 31 (equivalent to 389487MOD31) the division gives an answer of 12564.09677 (on the display), however you only want the fractional part so subtract 12564 to give 0.0967741935 . This includes the lower value digits that were previously hidden. Then multiply this result by 31 which gives 2.999999999 on the display. Since the result of a MOD or remainder calculation involving integers has to be a whole number, the answer needs to be rounded to 3. If the answer doesn't easily round to a whole number, it is likely that you have gone beyond the calculator's working capacity.
An alternative method which avoids the rounding of the fractional part is to take the integer part of the first result (12564) and multiply it by 31 to get 389484, then subtract this from 389487, giving the answer of 3.
Dec 16, 2012 | Casio FX991ES Scientific Calculator
Large factorials ti84
The TI-84 is limited to numbers with at most twelve significant digits.
If you must know the EXACT value of 16!, try this. Calculate 14!. Note the two zeroes at the end. Strip them off by dividing by 100 and remember the two zeroes. Multiply by 15. Strip off the last zero by dividing by 10 and remember that we've now stripped off three zeroes. Multiply by 16. Add the three zeroes at the end to get a fourteen-digit number.
In this particular case the result is exactly what you get by using the FACT function. That's also true for 17!, but it breaks down past that because 18! has more than twelve significant digits.
The whole point of the calculator is to allow you to do calculations with a reasonable degree of accuracy, as opposed to exactly. You'll notice that it can't do a simple operation like dividing 1 by 3 and produce an EXACT answer---only a twelve-digit approximation.
Oct 03, 2012 | Texas Instruments TI84Plus Graphic...
3/8-7/2= how do I get the answer I know the answer but want to know hot to get it
You convert the fractions so they have the same denominator (bottom number) then subtract the numerators (top numbers). 7/2 is the same as 28/8 (8 divided by 2 = 4. 4 times 7 = 28, so the equivalent fraction is 28/8. You can check by dividing 8 into 28 = 3 1/2 = 7/2. So, 3/8 - 28/8 = negative 25/8 or 3 1/8.
Sep 24, 2012 | Cars & Trucks
If there are 623 students and the ratio of girls is 2 to 3 boys. how many girls are there?
The best way to solve this is to develop one or more equations and then solve for the unknown numbers.
I solved this problem twice using different sets of equations to make sure I was right, and here is what I found:
1) I used the equations x + y = 623, and x = (2/3)y. In these equations, x is the number of girls and y is the number of boys.
Substituting the second equation into the first, I get (2/3)y + y = 623.
Adding the left side together I get : (5/3)y = 623.
Dividing both sides by (5/3) I get 373.8.
This means that x (the number of girls) is 249.2.
2) For the second attempt, I developed the equation: 2x+3x=623. Here 2x is the number of girls, and 3x is the number of boys.
Adding the left side I get: 5x = 623.
Dividing both sides by 5 I get: x = 124.6.
This means that the number of girls (2x) is 249.2. Just like in the first method.
But since you can't have a 1/5 of a girl, the answer must be 249 girls.
Nov 19, 2009 | Office Equipment & Supplies
When I divided a problem EX. 3/2 the calculator will not answer in decimal
You are not dividing problems, you are dividing number. This said, there is a simple way to ensure that the results of divisions are displayed in decimal form: It consists in putting a decimal mark (decimal point) at the end one integer (whole number)
ex:
3/2. gives 1.5
3./2 gives 1.5
3./2. gives 1.5
You can also configure your calculator to display all numerical results in decimal format. To do that press [MODE][F2]. Use the down arrow to select the ligne Exact/Approx, then use the right arrow to unfold the menu options 1:Auto
2:Exact
3:Approximate
Select 3:Approximate and press [ENTER]
Hope it helps.
Nov 15, 2009 | Texas Instruments TI-89 Calculator
199 people viewed this question
k24674
