Question about Refrigerators
Refrigirator not enough cold - Refrigerators
    New Friend:
Make sure that your coils in back or on the bottom of the refrigerator are clean. Alot of the times when the coils are dirty, The unit is trying too hard and will not be as efficient.
Posted on Jan 15, 2013
Hotpoint refridgeerator side by side fan not working nor does the compressor?
First thing I'd do is defrost it completely, that means turning it off for a few hours with door open & letting the ice melt, you could be getting a buildup of ice in your freezer jamming the fan before the automatic defrost has time to clear it. Also check that the seals are sealing completely, (that can allow frost to form in freezer), if not use a hair dryer to soften them (gently) & mould them back into line.
Nov 19, 2014 | Hotpoint HSS25GFP Side by Side...
There is problem with our kenmore refrigirator the freezer is working but the refrigirator is not working. the refrigirator is not cold enogh it is going to 60 degree
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Kenmore Refrigerators
My ge refrigirator is getting warm on refrigirator side but freezer side is doing fuine. model #csh25jftaabb send answer to
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 02, 2010 | GE GSH25JFT
I have 2003 E500 Mercedes. A/C upfront is cold , but on the back the hot air is coming out. What should I do?
hi...
this may be because of following reasons.
1.the refrigirant is undercharged. that is the quantity of refrigirant is less. so please charge with more refrigirant
2.there may be some blockage in the duct reaching the back side.but this is in very little chance of this cause.
3.may be small hole in the duct reaching back side.
if you feel my anwers helped you please rate me.
Jul 12, 2010 | 1999 Mercedes-Benz E-Class
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
The fridge is not getting cold enough Whirlpool s20b
maybe,,your frion is not enough to refrigirate ur ref..
Aug 12, 2009 | Refrigerators
Magnetic divider strip is hot. Temperature not cold enough
Yes this is normal. The heat strip is there to prevent moisture from forming around the the door frames. It also is most noticeable if the heat wave is causing your refrigerator to struggle to cool. Cleaning the coil below the refrigerator and making sure good air circulation in that area will help. If you have any questions please let me know and visit my siites. Please rate me if this was helpful, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
http://appliancepartsse.blogspot.com/
Jul 30, 2009 | Whirlpool Refrigerators
The refrigerator temperature is too cold. Everything is freezing.
there is a dial that regulates your temperature, this is inside the refrigirator, look for it and should say cold to coldest, put it in cold or if it has number from 1-5 just put in 3
Jul 09, 2009 | Refrigerators
Whirpool gold
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
