Question about Dakota Watches
Daniel Dakota radio controlled clock hands just keep going.
This radio controlled analog wall clock has worked splendidly for years. Yesterday I put in a new battery. Now the clock appears to be in perpetual sync mode, i.e., the hands move at a rapid rate and never stop. TIA for any ideas, David Copp
  • dhcopp Jan 17, 2013
    Somebody (sorry, I don't remember who) suggested that one of the time zone buttons might be stuck. I manipulated all the buttons. None of them appeared to be stuck but now the clock works fine. Thanks to all for their suggestions -- David Copp
4 Suggested Answers
  • 28 Answers
SOURCE: analog will not sync with digital
I just bought a 4756. Hard to follow that manual.
In the end I used these parts of the manual
Step 1 was to set the correct time zone (off PT or pacific time to ET eastern Time.)
Step 2 was to do a manual receive of the radio time.
Step 3 was to Home all the analog hands so they all pointed to 12. see manual
Step 4 then I hit B button - top right by the 2 and everything spun around to the right time received from the manual received time.
Posted on Feb 11, 2008
  • 5 Answers
SOURCE: Analog hands not moving but digital part works fine.
A Benrus advance is not a Casio PRG-60T Tough Solar Protrek watch. You posted your query in the wrong place.
Posted on Feb 19, 2009
SOURCE: after replacing battery cannot set mo/day/date
I have the same problem. Watch stores are NO help. Does someone have an answer that works?
Posted on Nov 28, 2009
Do I reuse 2 batteries for my Umbro chrono watch?
Normally the Umbro Chronograph watches having analog and digital clock works on single battery. When u put the battery inside ur digital is working fine but some times for analog hands do not move due to the loose button which is used to move the watch hands. So pull it out again and insert it agin gently till tick sound comes and u r good to go.
Let me know if ur watch is working successfully:)
Jan 27, 2017 | The Watches
How to put hands back on battery operated wall clock
put the smallest one on first and the longest one second
Oct 18, 2015 | Watches
I cant fix the analog of my watch pasnew model PLG_1002AD GRADE A QC 6
Ignore the instructions I found its not as easy as they say first you need to sync the digital and analog to do this press all four buttons at once and hold for 3 secs tho sets the digital clock to 12 Now press mode till you see h-s hold reset till h-s flashes hold the start button in the analog will start moving its slow so be patient set analogue to 12 exactly ignore the minutes that have passed press preset the minute hand will automatically adjust once done press mode go to the main watch screen hold preset use mode to select hours minutes date year month etc and start to change the values keep it on 12 not 24 hour clock set the clock and press preset the analog will now automatically adjust to the time once done you can change to 24 hr mode if you wish
Mar 06, 2015 | Watches
My radio controlled watch is exactly half an hour fast according to the hands, but the internal clock appears to be correct. This happened when I tried to adjust the watch to Canadian time
If I understood correctly this watch have a analog watch display ..and it is half an hour forward..but when you set timing or the alarm it behave normal ..and so the internal one is correct ..but just do not display the correct time on the analog one ...If it do not have any means to correct manually the analog watch ..I advice to try to remove all power and stop the indicators at the exact time ...(a sharp hour...) and power it back after the exact time it is forwarded ....This way the analog clock will be stopped..and the internal one will go on and will adjust at the spot by the radio time ..and you will have both timers in correct display ...If it does have buttons or so in the back ..try to correct them by hand ..
Jul 12, 2011 | Watches
Won't tick
instruction manual for radio watch sm2452 required
Jun 20, 2010 | Dakota Watch Company Travel Alarm with...
I have an older large wall clock - model 88100. It is 2 minutes fast. I've replaced the battery but it still runs 2 minutes fast. Always the same amount. Any ideas? With an atomic clock it should be right...
If it is a radio controlled clock and it is consistently out, then the hands need re-setting. I have hand a similar experience with my watch, so I fully understand the problem.
You can adjust the hand settings by pressing the right buttons!
If you have the instructions, then refer to the to adjust the hands. If you do not have the instruction, then go to the makers web site and look for manuals download.
Jan 22, 2010 | Watches
Watches Logo
720 people viewed this question
Top Dakota Watches Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Dakota Watch Expert? Answer questions, earn points and help others
