Question about Orange Amps Orange Terror Bass 500 Amp Head
Amp makes clicking sound
Only Makes repeating clicking sound through the cabinets.
    New Friend:
Probably bad transistors in switching power supply
Posted on Apr 15, 2014
My Mackie HD1531 has a high pitched whistling sound, all other speakers work fine with the same power connection and desk connection. It whistles regardless of whether it has a sound input or not.
Sounds like a problem with the horn amp in that cabinet. This is not a user fixable problem and needs to go to the shop. Here is a link to the Mackie support page where you can find a link to the repair shop list.
Mackie Tech Support
Feb 19, 2015 | Mackie HD1531 3-Way 15" HD Powered PA...
Woofer rattles at low volume...when i turn it up it sounds pretty good...still has bass and highs
May be a couple of things; The first is a resonance in the cabinet, which may not be noticeable at high volumes. If the speaker cabinet was ever dropped,or got cracked from dropping , dry weather,or whatever, there may be certain frequencies that make the cabinet rattle. Try holding the cabinet when it rattles and look for anything loose,from a side wall to a loose foot, or the speaker itself. Tighten up loose items and seal any gaps or cracks On the cabinet.
The other problem could be a partially blown speaker. Test by lightly pushing in on the outsides of the speaker to see if it moves in and out freely. If there is a scratching sound, or it drags slightly , it might be blown. Also,the dust cap or another part of the speaker may be loose. Check that, and reseal if loose. Replace or have reconed if blown.
Nov 02, 2014 | Mackie MR8 ACTIVE STUDIO MONITOR MR-8
How can I service Behringer epa900 speaker
Can't say for sure....there should be a bunch of screws in the back so you can gain access....is this a powered cabinet??...can you dis-connect the present speaker and horn and hook up another just to make a test?? Is the cabinet plastic?? There could be loose screws....Does the cabinet have a recess for a stand??If so, check the retaining screws in that as well....and don't forget to check the grill....
Oct 13, 2014 | Behringer Europort EPA900 Ultra compact...
Frying sound from amp intermittantly
then the problen is in the power amp section after the preamp stage. Contact Crate for your nearest service center.
http://www.crateamps.com/support/index.php
Mar 03, 2014 | Crate Ca6110dg Gunnison 60 Watt Acoustic...
How do you connect a peavey 6505+ amp to a marshall 1960a cabinet?
On the back of your 6505 there are two jacks that are labeled speaker outputs. For mono function, use either one of those outputs and run a SPEAKER cable from your amp to one of the input jacks of your 1960a cabinet. I assume it is a 4X12 cabinet. Either input will work. Make sure you match the ohm selector on your 6505 (right next to the output jack, 4/8/or 16 ohms) to the ohm rating on your 1960 cabinet. It is likely labeled on the plate that houses the input jacks. You should be good to go. NOTE: Never turn your amp on unless it is hooked up to a speaker cabinet and never use instrument cable to hook your amp to your speaker cabinet. Bad for a nice tube amp like yours.
Rock on and hope it helps.
Dec 02, 2013 | Peavey Music
I have recently purchased a Eurolite 6U 19 Rack Mount Amp Case for my Marshall AS-50D combo amp but I need instuctions on how to pack the amp into the case.
When putting amps or ANY heat generating devices into a cabinet, make sure there is FREE airflow around and especially around heat sink fins. Sometimes it is necessary to leave a gap between amps that are stacked in the cabinets.
Jul 31, 2011 | Eurolite 14U 19" Rack Mount Amp Case with...
I have a budda superdrive 30 II amp and have a setting question. I made a 2-12 cabinet to hook to this amp. Each speaker is 4 ohms. They are wired to their own output jack. My amp has 2 outputs for...
You best rewire the cabinet to put the two speakers in series. Wire one speaker plus to minus of the other and bring the other lead, one from each speaker to your jack on the cabinet. The amp output impedance is what is set on the switch... for two 8 ohm speakers you would use both jacks to the two speakers BUT ssince you have 4 ohm speakers the ONLY option is for two in series and set the switch to 8 ohms. The amp is ONLY 30 Watts so don't expect too much sound output... You should get a nice CLEAN sound at a reasonable level. If you drive the amp too hard it will clip and you will get garbage.
Apr 22, 2011 | Budda Superdrive 30 Series II Amp Combo
My boss DD-3 makes a strange tapping sound on all modes. tapping sound gets more frequent when i turn the delay time pot to the right. its like a little tap sound getting into the circuit with the guitar...
Check your power source or battery. The sound is probably due to the internal processor recycling due to watchdog timer. If power is OK, then service will be necessary to repair the problem.
Apr 03, 2011 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Peavey 2600 m series shuts off power when turning up volume after about 30 to 40 seconds of playing and takes about 2 minutes to reset
Sounds like the thermal cutout is sensing over temp. Make sure there is FREE airflow around the unit. If it is in a cabinet, install vent fan(s). This amp will throw out a lot of heat. Make sure cooling fins have airflow. Cables can block the airflow... check for that possibility. Repeated thermal cycles will eventually cause failure of components.
Mar 27, 2011 | Peavey Pv 2600 Power Amplifier
Orange Amps Orange Terror Bass 500 Amp Head Logo
54 people viewed this question
Top Orange Amps Music Experts
Michial Gueffroy
Are you an Orange Amps Music Expert? Answer questions, earn points and help others
