Question about KitchenAid KP26M1X Stand Mixer
Stopped Mixing While Kneading Bread
Hi,  I used my mixer to make bread the other day and it stopped mixing in the middle.  There was also a noticeable smell, sort of like burning, maybe from friction?  Anyway, it will still mix, but now it sounds scary when I turn it on, like if I leave it on, it will cause more problems. Perhaps something is grinding incorrectly?  I have a  KitchenAid stand mixer 575 Watts 6 Qts model no: KP26M1XMR
I would really like to learn how to fix this myself.  Thanks!!
  • 1 more comment
  • libbydmccart Jan 31, 2009
    Nope.  The 1 year ran out last July.
  • libbydmccart Feb 01, 2009
    Yeah, so i took off the cover and all that and when I could see that there was nothing obviously wrong without disassembling more, i got nervous and decided to take it in to get fixed.  I'll post what the problem ends up being once they find it :)
    thanks for your help!
  • Rick Belanger
    Rick Belanger May 11, 2010
    Hi Libby. Is your mixer still under warranty?
  • 135 Answers
Hi again Libby. You're right to be scared about further damage. If you want to fix this machine yourself, stop using the mixer. Go to the Kitchenaid website and download the drawings that match your mixer model Unplug the mixer! Take a screwdriver and remove the silver band from around the head of the unit ( 1 screw). Next remove the four screws that hold the top part of the mixer. Remove that cover, and look for a 'humpy" looking cover at the front of the machine. Examine this transmission cover carefully. If the cover is made of plastic, look for cracks. If you don't find cracks, you'be better off taking it to a repair shop. If you do find cracks in the plastic cover, remove the four screws that secure it. Remove the trans. cover.
You will now see a lot of grease in this exposed transmission. Put on some latex gloves, get a bunch of paper towels and move some of this grease aside so you can lift the worm gear assembly free of the mixer ( see Kitchenaid drawing). Wipe it off and look for damage to the worm (spiral) gear. Look for damage on the other gear of this assembly, inspect the 2 bronze bearings at either end of the shaft. You're looking for cracks in, or pieces missing from the bearings, look for damaged teeth on the gear. Should you find damage at any stage, that part must be replaced. These parts can be ordered from the Kitchenaid website, and will take about a month for them to arrive.
When you order the required parts, insist that the replacement trans. cover be made of metal. When my mixer "blew up", my replacement was a metal one. If your problem dosen't fit the above solution. I can't help you further. If it does, please rate my solution.
Depending how much grease you had to take out to do the inspection, you might have to order a container of grease to replace it. Good luck! ricardok45.
Posted on Jan 31, 2009
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
It just stopped during use and seems completely dead!
Replace the fuse located below the plug inlet on the mixer,(it is a 6.3A Fuse, 250V 5x20MM fuse from Radioshack) you have to remove the outer panel to access it. I did the same thing, it stopped working while I was mixing dough for bread, replaced it, good as new.
Aug 11, 2010 | Jenn-Air Attrezzi JSM900 Stand Mixer
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Jul 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
Jun 07, 2009 | KitchenAid K45SS Classic Stand Mixer
Bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Mar 28, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Pops out of lock under a heavy load
Hi Susan. There is no worse feeling than the feeling you get when you find that you've been seperated from your hard-earned money by a company that markets a product with glowing phrases of what their product can do...And then doesn't deliver on it's promises. Kitchenaid mixers can make short work of bread dough NOT! My Kitchenaid HD Pro (475 watts) self destructed after only 30 uses of making my Sourdough Bread. The problem? A cheap piece of plastic that takes the stresses of two important shafts in the mixer. Cheap, shoddy parts in a mixer you paid top dollar for. Kitchenaid shows no shame in doing so.
What is happening with your mixer as it tries to mix your dough is that the head unit is thrust back and forth and side to side (bucking). Eventually hinges become loose and sloppy. Kitchenaid's behaviour is legal and beyond reproach, so make your next mixer purchase an informed one.
Goto www.consumeraffairs.com and do a search for your Kitchenaid model. You'll notice that you're not alone in your mixer troubles.
I solved my mixer problems by buying a used Hobart 20qt. Commercial mixer (A200) and rebuilt it. When mixing heavy dough you should only use about 60% of the bowl capacity. less, if your mixer is agonizing with the amount of food in the bowl..
You will be able to replace the thumb screw. Be prepared to wait for at least a month for the part to arrive once ordered.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 08, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KSM90 Kitchen Gets stuck in the middle of mixing Bread Dough
Hi
If you decide to get rid of it can you sell the accessories parts?. I have one with no parts.
Thanks,
Barak
baraksch@nana.co.il
Nov 18, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
471 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
