Question about Tablets & eReaders
How do i put my cruz tablet in recovery mode
I need to put my cruz tablet in recovery mode
4 Suggested Answers
SOURCE: my cruz tablet wont work only appears cruz on screen when i power it on.
george,have you gotten a solution yet? mines is doing the same thing
Posted on Dec 07, 2011
SOURCE: when turning n the cruz tablet, the word cruz pops up and goes away. then cruz flashes
Forget all that nonsence you read about puttimg the sd card in the computer. Its easy but it may erase some of your favs. But it work... Take out card, turn off tab. Put card back in, hold power and the up button. You should see it rebooting, yellow words comming across screen. Let it play out, presto... Good as new
Posted on Apr 28, 2012
  • 37 Answers
SOURCE: how to unlock my android cruz
Try the two solutions described by this link
Posted on Nov 29, 2012
How to Reset the Velocity Cruz Tablet?
A.) With the device powered off, press and hold the volume up button (keep holding), then press and hold the power button at the same time. Keep holding both buttons. The Cruz logo will appear, you may then release the buttons. Then the Android robot and software package icons will appear on the screen.
B.) The moment you see the Android robot, you will need to access the System Recovery menu by pressing and holding the Power button, then tap the volume up button once, releasing both. This is in the opposite order of the sequence in Step A.
NOTE: The volume up button on the T408 is toward the power button, while the volume up button on the T410 is away from the power button.
C.)
In the System Recovery menu, use the volume toggle to navigate up and down through the menu and hightlight your selection. Use the power button to activate your selection. Select the option that corresponds to clearing cache and data. Once completed, select the option to reboot your device.
Oct 17, 2016 | Android Tablets & eReaders
Info on a cruz TABLET t301 need to reseT AND NOW IT DONT COME ON
Cruz™ ' Support FAQ
www.cruzreader.com/Cruz_Howto.php
How do I factory reset my Cruz? ... What should I do if my Cruz Reader (R100 Series) will not turn on? ... Why does the headset audio sound strange on my T301? ... How do I connect to the Internet if I don't have Wi-Fi at home? ... through CruzTablet.com or one of our Official Retailers come with a One-year Limited Warranty ...
How to unlock my cruz tablet t301 - Cruz™ Tablets
www.cruzreader.com/Cruz_Model.php
How do I connect to the Internet if I don't have Wi-Fi at home? How do I remove an ... How can I unlock my R100 or T301 if I forgot the pattern? How does storage ...
Amazon.com: Questions And Answers: Cruz won't turn on...what do I do?
www.amazon.com/Cruz-wont-turn-what/.../1?asin...
Amazon.com, Inc.Jun 19, 2011 - Velocity Micro T301 Cruz 7-Inch Android 2.0 Tablet (Black) ... Caity, Idon't know if this will solve your problem, too, but my ... Everything seems to be working just fine now. .... you have to is reset it and hold the power at the same time until comes back hold it for ... Worked perfectly, thanks for sharing the info!
How to Master Reset a Cruz Tablet ' Chron.com
Jan 19, 2016 | Velocity Micro Black Cruz T301 2gb Wi-fi...
Tesoar tablet freezing on tesoar screen
Try this:
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
May 17, 2014 | Velocity Micro Cruz Reader R101 Tablet PC
I forgot my pattern code
You will need to do a factory reset:
  • Power device off.
  • Press and hold down Up Volume and Power Key for 10 seconds and release after seeing the Cruz logo.
  • You will then be brought to the Recovery System screen with a Android robot and an alert triangle on the background
  • Press the Up Volume Key and the Power Key at the same time once (don't hold them down) then the recovery selections will show up.
  • With the Volume keys scroll and select Wipe data/Factory Reset and make your selection with the Power key
  • With the Volume Keys scroll and select Yes to confirm the action and make your selection with the Power Key
  • Select Reboot system now.
Oct 19, 2013 | Velocity Micro Cruz Reader R101 Tablet PC
Pattern unlock
If you can't remember the unlock pattern you will need to do a factory reset:
  • Power device off.
My cruz is frozen in the reboot mode
Turn off it for a while, then start it, it should be fine. If not, contact the supplier for tech help, they should be helpful.
Android 4.0 Tablet PC
Jan 24, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
My Android Cruz Reader R101 starts on the Cruz flash screen, skips then goes back to Cruz flash screen. I have reset it using the reset between the power and External SD card. I also removed the back and...
This sounds similar to something that happened when I tried rooting my android phone. If it's the same thing, that means you will need to go to recovery mode and install an update.zip package that you can find somewhere online for it. It's because the code for what's supposed to happen after that screen is overwritten and it doesn't know where to go.
May 06, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Just bought a cruz reader r101....usb says device not recognized. I am on XP sp3
Before you can communicate with your computer you must run CruzSync from the desktop. There are some driver files that must be sent from cruz to point the way to the reader. After you do this it should connect every time. Some time you will have to pull the USB out and put it back end, especially if the reader or the computer has just woke up from a sleep or hibernation mode. ZumoDrive is the account you must set up when you click or press on CruzSync to make all of this happen. Hope this helps
Jan 02, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Tablets & eReaders Logo
67 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
