I have a RadioShack PRO-2014 50-Channel Programmable Home Police Scanner -- I entered the channels and it is searching but it does not seem to stop at any stations............. Why would that be?
  • Dw2bu2 Jan 28, 2009
    I need the codes for this scaner.i got it for christmas .and cant uses it
  • amandarjones Mar 26, 2009
    i have the same device an it does the same thing hasnt stoped yet.i dont no how to work it,didnt come w/info.
    Sergeant:
    Champion:
  • 259 Answers
Your scanner will only stop if there is activity on the scanner Not sure where you are or what frequencies you put in I only put a few VHF and most of the frequencies I put in are UHF this covers the Repeaters and has a greater coverage Also the other thing I did is put an external antenna up to pick up better Also unsure why this is under PRINTERS
Posted on Jan 23, 2009
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
How do I reprogram the Radio Shack PRO- 2026 Police Scanner
To program a known frequency into the scanner:
- Power the scanner ON.
- Press MANUAL to stop scanning.
- Enter the number of the channel that you wish to program.
- Press PROG.
- Enter the frequency, including decimal point.
- Press ENTER.
The frequency is now programmed into memory. To continue programming, start over with a channel number, or just press PROG to advance to the next channel.
For more details on programming your scanner, follow this link:
http://support.radioshack.com/support_electronics/doc16/16902.htm
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
May 09, 2010 | Radio Communications
How do clear the scanner to re program it
Programming a frequency into a channel clears the previous channel entry, so there's really no need to "clear" the scanner for reprogramming. To eliminate an unwanted frequency, you can either press the LOCKOUT key to prevent the scanner from stopping on a specific channel, or you can "zero" a channel:
1. Press SCAN/MAN to stop
scanning.
2. Use the number keys to enter
the channel number (1-200)
you want to clear.
3. Press PGM. F=C appears.
4. Press 0 then ENT. The
frequency number changes to
000.0000 to indicate the
channel is cleared.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Nov 05, 2009 | Radio Shack Pro-82 Scanner
Have a pro 97 scanner and try couple of computes to program it
You need police scanner programming software and a cable before your computer will talk to your scanner.
Do a google or yahoo search for police scanner software. About $25 and a cable from radioshack for about the same. The disk that comes with the cable will only let your computer recognize the cable not program the scanner.
Good luck. Waste of money in my opinion but it may be easier then manual programming the radio.
Jul 24, 2009 | Radio Shack Pro-97 Handheld Scanner
All channels locked on my radio shack pro-95 scanner
You are pressing the "scan" button in the upper left hand position and getting all channels locked out? Correct?
If you haven't programmed any frequencies the channels will stay locked out. Get your local frequencies by doing a search for police scanner frequencies. Once you have gotten the information for your area press the "PGM" button on the lower right hand side of the key pad. Input your 1st frequency ###.#### then press "ENTER". Press "PGM"key again and enter your 2nd frequency then "ENTER" again. Repeat as often as you wish to enter more frequencies.
Make sure you are entering your frequencies in empty channels unless you want to over write one that you don't want to use any longer. Press "PGM" until you get to an empty channel.
When you are done, (you can stop any time) press the "SCAN" button in the upper left hand position and you are in business. You are supposed to be able to choose which memory position you wish to use but I haven't tried to figure that one out.
If you need the manual for the radio go to radioshack site and do a search for PRO95 and it will come up in PDF format.
Hope this helps. I have owned the pro 95 for maybe 6 or 7 years and after doing a little programming yesterday the thing is much more to my liking. It scanns quicker and scans the channels I wish to listen to.
Jun 08, 2009 | Radio Shack Pro-95 Handheld Scanner
Unlocking channels
first press the manual button so you can go through the channels one by one. Then look for a button that has L/O(lock out) push this once for every channel you have a frequency programmed for it, the channel will probably not unlock if there is no frequecy programmed to it.
per roupe50 above
Dec 25, 2008 | Radio Shack Pro-95 Handheld Scanner
Need to unlock our radioshack pro 2018 200 channel desktop scanner
Easy to use right out of the box!
Explore preset frequencies used for non-trunked police/fire, aircraft, marine, NOAA weather and more. Just attach the antenna, switch it on and touch one of five buttons. With just two keystrokes, you can store a frequency you find in the 200-channel memory for later scanning or monitoring. You can also search for activity in frequency ranges you specify or program known "action" frequencies on the keyboard.
  • 1-touch search lets you find police/fire, HAM radio, marine and 7 NOAA WX frequencies fast
  • Built-in weather receiver sounds an alarm when your NOAA weather station sends an alert
  • 50-frequency search skip locks out undesired frequencies
  • Programmable by computer (requires Scanner PC Programming Kit #20-048)
Aug 06, 2008 | Computers & Internet
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
498 people viewed this question
jasbo
jasbo
