I tried normal but it didn't work so I tried safe mode and it din't work The mouse icon stays there then the computer goes off then I click the mouse and it goes back on the login screen never pop up
  • 27,725 Answers
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
Posted on Jan 15, 2013
  • 244 Answers
SOURCE: Ibm thinkpad t40
Hi tdarrin,
Try to repair your operating system using your current version of windows OP. Possible some destructive program black the windows startup not to continue.
Hope this will be helpful to you. Please let me know if you need more help.
Best Regards,
Philip
Posted on Oct 24, 2007
  • 131 Answers
SOURCE: hp pavillion trying to boot from dos mode
my pc is writting Disk boot failure, insert seystem disk and press enter. pls help.
Posted on Apr 30, 2008
pagebor
  • 2785 Answers
SOURCE: Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Posted on Dec 23, 2008
MrDallasIT
  • 91 Answers
SOURCE: black screen on laptop, will not boot in safe or normal. no back up disk, tried f11 sys recov did not work
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Posted on May 15, 2009
  • 942 Answers
SOURCE: when trying to boot up
Hello
So in that case you need to reinstall the Windows so that it will fix the problem. Some instances of that problem corrupted Operating System it needs a new copy.
Regards
PCmania
Posted on Sep 25, 2009
Starting Windows comes up that passes then all I get is a white mouse on a blank black screen for ever whats the deal?
Try restarting the computer and as soon as it begins to start up click on your " f8 " key repeatedly until a start menu comes up. Click on " safe mode" the computer will try to boot up to a simpler mode of windows. If this is successful you will get windows up with larger icons on a black background. Click on shut down / restart the computer will reboot to normal mode. This is often sufficient to resolve windows start up problems. If safe mode worked but the computer still does not fully start click on three keys at the same time " ctrl alt and delete" when you have the mouse only screen. This should bring up the " task manager" click on " run new task" and enter " explorer.exe" this should bring up your desktop
Feb 11, 2013 | Computers & Internet
Sony vaio all in one touchscreen stopped working
XP and Vista Normal Mode Start your computer as you normally would. Click the "My Computer" icon on your desktop. Go to "C:\ Program Files\Sony\Setting Utility Series." Find and choose the "VCCPointingDevice" folder in the "Setting Utilities Series folder" to open the "Built-in Pointing Device" dialog box. Locate the "Enable" box on the "Built-in Pointing Device" dialog box. Check the box to enable the Vaio touchpad if you wish to use this device. Disable the touchpad if it is interfering with the external mouse. Uncheck the "Enable" box if you have a USB (PS/2) mouse connecting to your Vaio and wish to use that instead of the built-in touchpad. Pick "Yes, I'm Sure" when prompted to activate your choice, then close all the windows. Windows 7 Normal Mode Launch Windows as usual. Go to "Start" > "Control Panel" > "Mouse" > "Pointing Device" to open the Vaio touchpad control center. Uncheck the "Enable" box on the "Pointing Device" window when you wish to use your external mouse. Check the "Enable" box on the "Pointing Device" window when you want to use the Sony Vaio touchpad. Make sure the external mouse is not interfering with the touchpad if you have one connected. If so, unplug the mouse from your computer. Click the "OK" button at the bottom of the "Pointing Device" window. Close all other windows. XP and Vista Safe Mode Restart your computer. Press the F8 key before the Windows welcome screen appears to enter Safe Mode. Click "Start" > "Control Panel" > "Add/Remove Programs." Find and delete all software for mice and pointing devices. Restart your computer in normal Windows mode. Proceed to next step if the problem persists. Restart your computer in Safe Mode. Right click the "My Computer" icon on the desktop. Choose "Properties" on the drop-down list. Pick the "Device Manager" tab in the Properties window. Select the "Other Devices" folder and click on the "+" sign besides it. Delete all the devices under this "+" sign by clicking on the "Remove" button next to each of the items. Restart Windows in Normal Mode. Once Windows is operating, there will be a "New Hardware Wizard" pop-up that will load all the necessary drivers for the touchpad, mouse and other pointing devices. This should fix the corrupt driver for your Vaio touchpad. Windows 7 Safe Mode Reboot your computer and press the F8 key before the Windows welcome screen appears to enter Safe Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Click the touchpad icon. Choose the "Driver" tab and press the "Uninstall" button. Press the "OK" button to confirm. Restart Windows in Normal Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Choose the "Driver" tab and press the "Update" button. Press the "OK" button to fix the touchpad software.
http://esupport.sony.com/perl/swu-list.pl?mdl=PCGFRV26
Feb 08, 2013 | Sony VAIO Computers & Internet
Sony vaio touch screen stopped working
Feb 08, 2013 | Sony VAIO VGC-LV180J 24-Inch All-in-One PC...
TOUCH PAD NOT WORKING
The Sony Vaio laptop is typically sold with a touchpad device installed below the keyboard. The touchpad is for navigating the screen and is used like an external mouse. A touchpad can sometimes malfunction for no apparent reason, but there are ways on troubleshooting the device yourself before asking a technician for help. Start your computer as you normally would. Click the "My Computer" icon on your desktop. Go to "C:\ Program Files\Sony\Setting Utility Series." Find and choose the "VCCPointingDevice" folder in the "Setting Utilities Series folder" to open the "Built-in Pointing Device" dialog box. Locate the "Enable" box on the "Built-in Pointing Device" dialog box. Check the box to enable the Vaio touchpad if you wish to use this device. Disable the touchpad if it is interfering with the external mouse. Uncheck the "Enable" box if you have a USB (PS/2) mouse connecting to your Vaio and wish to use that instead of the built-in touchpad. Pick "Yes, I'm Sure" when prompted to activate your choice, then close all the windows. Windows 7 Normal Mode Launch Windows as usual. Go to "Start" > "Control Panel" > "Mouse" > "Pointing Device" to open the Vaio touchpad control center. Uncheck the "Enable" box on the "Pointing Device" window when you wish to use your external mouse. Check the "Enable" box on the "Pointing Device" window when you want to use the Sony Vaio touchpad. Make sure the external mouse is not interfering with the touchpad if you have one connected. If so, unplug the mouse from your computer. Click the "OK" button at the bottom of the "Pointing Device" window. Close all other windows. b> XP and Vista Safe Mode b> Restart your computer. Press the F8 key before the Windows welcome screen appears to enter Safe Mode. Click "Start" > "Control Panel" > "Add/Remove Programs." Find and delete all software for mice and pointing devices. Restart your computer in normal Windows mode. Proceed to next step if the problem persists. Restart your computer in Safe Mode. Right click the "My Computer" icon on the desktop. Choose "Properties" on the drop-down list. Pick the "Device Manager" tab in the Properties window. Select the "Other Devices" folder and click on the "+" sign besides it. Delete all the devices under this "+" sign by clicking on the "Remove" button next to each of the items. Restart Windows in Normal Mode. Once Windows is operating, there will be a "New Hardware Wizard" pop-up that will load all the necessary drivers for the touchpad, mouse and other pointing devices. This should fix the corrupt driver for your Vaio touchpad. b> Windows 7 Safe Mode b> Reboot your computer and press the F8 key before the Windows welcome screen appears to enter Safe Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Click the touchpad icon. Choose the "Driver" tab and press the "Uninstall" button. Press the "OK" button to confirm. Restart Windows in Normal Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Choose the "Driver" tab and press the "Update" button. Press the "OK" button to fix the touchpad software. Hope this help.
Jan 16, 2013 | Sony Nice Vaio Pcg-81312l Laptop Notebook...
I tried normal but it didn't work so I tried safe mode and it din't work The mouse icon stays there then the computer goes off then I click the mouse and it goes back on but the login screen never pop
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps. if this fails to fix the problem During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution restart back into safe mode you might need to select your operating system to load into safe mode To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Jan 15, 2013 | Computers & Internet
Computer screen goes black and stays black unless in safe mode.
Hi, you are lucky you can access safe mode. now in safe mode, go to device manager by right clicking on my computer icon and selecting manage. then select device manager. select the VGA from the list by the right and right click then select uninstall. restart system , it will boot into normal mode
Oct 15, 2012 | E-Machines eMachines Desktop PC
I got a dell latitude/d8oo out of warranty my mouse goes haywire can someone help me?
Either a virus or infection has hijacked your mouse or it needs to be replaced.
Try booting into safe mode and see if the mouse works.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If it works in safe mode, then turn the computer off and reboot again as if you are going into safe mode, but this time take the Safe Mode With Networking option (this will give you internet connectivity). When it boots up open your internet browser then download and install MalwareBytes, then run a Quick Scan.
Go to www.google.com and in the search box type: "Download cnet Malwarebytes" (without the quotes). Download and install malwarebytes from the sites download.cnet/malwarebytes. When the site opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
If the problem still exists then purchase another keyboard on ebay based on the brand and model of your computer at:
http://www.ebay.com
May 30, 2012 | Computers & Internet
Y my key board & mouse dont work wen i open my cpu
Make sure you have them in the correct ports in the back of the computer. If the end that goes into the back of the computer is round then you have PS2 serial type keyboard and mouse. If it is flat you have usb type mouse and keyboard. If it is round, the keyboard goes into the purple colored port and the mouse goes into the green port. If you put them in or remove them while the computer is on you will have to reboot the computer. They are not plug and play like the usb types.
If they still don't work try booting up in Safe Mode.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If the work in Safe Mode then you probably have a virus or infection that has hijacked the keyboard.
Take the steps above to reboot in Safe Mode, but this time when the safe mode options appear, select Safe Mode With Networking option (this will give you internet connectivity). Open your internet browser when it finishes booting up and download and install MalwareBytes.
May 03, 2012 | Dell OptiPlex GX280 PC Desktop
I can only connect to the internet in safe mode
You didn’t provide a lot of information here, but based on what you are saying, the computer starts up and works in safe mode only and when you try to start it is normal mode it fails. Knowing what happens when *** fails might be really helpful, but that’s okay.
It sounds like a driver issue. One of the drivers has gone bad (become corrupted) and when it tries to load, it fails and brings the whole system down. The trick is to find which one is failing. This is typically listed on the “blue screen of death” when the failure occurs.
The biggest cause of these kinds of failures is the video driver. To fix this start the computer in safe mode and remove the old driver. To do this go into the device manager (right click the My Computer icon and click Manage and then click on the Device Manager link). Click the plus next to the Display adapter properties and remove the old driver.
Obtain a new driver and install it.
See if the system boots.
If you could get me more information on the failure type and what happens, I might be able to lock down a better solution.
Apr 21, 2009 | eMachines W3619 PC Desktop
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
