Question about Indesit W 123 Front Load Washer
When I programme my washing machine the lock light does not come on when the door is closed, therfore it will not start.
Model no IWE 6125
  • Indesit Master
  • 17,130 Answers
Possible that the DOOR lock SWITCH is faulty and so the continuity to the switch and the wiring to the panel must be checked.
If there is no continuity then the switch must be replaced.
Posted on Jan 15, 2013
  • 209 Answers
SOURCE: Washing machine wont do anything
rotating timer knob indicates that there is a fault, obviously, so its a case of going through a checklist, based on info given, check in this order, outlet pump, for open circuit, then heater element for open circuit, then maybe the water valves, you have given little information for me to go on as an engineer, please understand, the more you say the more detail we can give ..... ok cheers with looking for the fault, best of luck and work safe
Posted on Dec 22, 2007
  • 1462 Answers
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Posted on Jul 10, 2008
SOURCE: when i turn my washing
http://www.indesit.co.uk/indesit/_pdf/manuals/19506266501_UK.pdf
Posted on Sep 29, 2008
  • 1044 Answers
SOURCE: How to cancel drying?
Please press the reset switch which should be on the control panel or next to the loading door
Posted on Nov 14, 2009
Testimonial: "it works!! thanks"
  • 569 Answers
SOURCE: when washing iwe get a horrible smell like bad
Is this a newly installed machine?
That smell would normally be associated with drains, indicating that the outlet from the machine to the drain is not correctly fitted with a trap.
Posted on Mar 25, 2010
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
'washing machine miele w1714 lock on Message demo programme how i do unlock?
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
Nov 04, 2012 | Washing Machines
Please help me , with my washing machine Whirlpool AWM 6125 , i have the key symbol on my front desk .
I understand that the 'key' symbol indicates that there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 05, 2011 | Washing Machines
LOADED MY BOSCH CLASSIXX 6 1400 EXPRESS CLOSED THE DOOR THEN TRIED TO PUT IT ON A PROGRAMME AND IT CAME UP -0- AND IT WOULD NOT START NO TIMES WAS COMING UP WHEN I TURNED THE DIAL ONTO A PROGRAMME.PRESSED...
this sounds like a door lock issue if the machine does not detect the door has closed properly you will get the same symptoms, try slamming the door shut (not too hard) if machine starts but then does the same thing next time you use it will need new lock it will have gone out of calibration.
Oct 14, 2009 | Bosch Classixx WFL 2066 Front Load Washer
AEG Lavamat 74800: Door doesn't open, i.e. opens with long delay
Following next link:
How washing machine door lock works how to test interlocks
Replace door lock.
untitled2-rq2y3fnvghvfrpvxa33jafnd-1-0.jpg When the washing programme is started by pressing the START/PAUSE button, the bi-metal PTC (contacts 3-5) is powered by the triac on the PCB (J6-2 connector): after 2 - 4 seconds, this closes the switch (5-4) which powers the electrical components of the appliance (only if the door is closed).
The door interlock prevents aperture of the door while the appliance is in operation.
At the end of the washing programme, the PCB disconnects the interlock from the power supply, but the door remains locked for 1 to 2 minutes (PTC cooling time).
Certain models feature a pilot lamp which lights to indicate that the door is locked. This pilot lamp switches off when the door can be opened.
Dado
Mar 17, 2017 | AEG Lavamat 72640 Front Load Washer
Miele W487WPS Washing Machine
unplug machine, drain water manually by leaving the out let hose down gravity will let the wate out unless its blocked.Close Ire.ps. door should open .reset,and try again
Feb 24, 2008 | Washing Machines
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi Washing machine
when any of the buttons are pressed ERR is displayed.
Jan 24, 2008 | Washing Machines
Indesit W 123 Front Load Washer Logo
216 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
