Question about Denon AVR-2113CI
Denon avr-2113ci hdmi can't change source
Tried switching from different sources and won't change to panasonic blu-ray player , samsung blu-ray player or cable box. it will switch to computer hooked from dvi to hdmi.
  • mike Jan 15, 2013
    It did work for some time and recently stopped. I'm suspicious it is related to copy prohe screen goes black after the handshake.
  • 20 Answers
Can you update the firmware on the amp as this could also affect the connection between the players.
Posted on Dec 09, 2013
Cant get ps4 to pass signal thru avr to projector.
Possible PS4 HDMI Handshake Output Problem - AVS Forum ' Home ...
www.avsforum.com/.../1508885-possible-ps4-hdmi-handshake-output-p...
Dec 31, 2013 - 20 posts - ‎15 authors
Nothing seems to make the PS4 pass a signal through the AVR. .... can output videothrough the Integra, why can't Sony get the HDMI working? PS4 - 3D Playback Not Working :-(
Aug 12, 2014
Run HDMI Directly to TV or A/V Receiver?
Dec 19, 2013
AV receiver problem with Xbox One
Nov 23, 2013
Solution to HDMI @ 1080p receiver/display HDCP ...
Dec 14, 2008
More results from www.avsforum.com
My Denon AVR-X4000 won't output video signal from attached HDMI ...
forum.blu-ray.com > Audio > Receivers
Dec 21, 2015 | Denon AVR-3311CI 7.2 Channel Networking...
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
Denon avr 2113ci signal not coming in from apple tv
If this is a video problem, try different video connections (i.e. HDMI, Component, Composite, S-Video) to isolate the problem
Dec 16, 2014 | Denon AVR2113CI 7.1-Channel 3D Home...
I have a denon avr-x2000 all hdmi ports except the cab/sat are fuzzy. it started with the PS3 on the game port
Plug your ps3 and/or blu-ray directly into the TV and see what it looks like. use different HDMI cables to test them. Once you know that all works then setup your avr-x2000. Does the Denon menus look fuzzy?
Mar 20, 2014 | Denon AVR-X2000 In-Command 7.1 Channel 4K...
After plugging the hdmi cable, we have the sound but no video
Some ideas:
  • Make sure the correct input is selected for your display device.
  • You may need to change the video out setting on your video source device (Blu Ray player, cable box, etc) to turn on the HDMI output port. See the video source's manual.
  • Devices connected to HDMI are sometimes picky about the order they turn on. Try turning off the video source and video device, then turn on the video source, wait a few seconds, then turn on the display. If that doesn't work, try reversing the order that they are turned on. If this is the problem, you can buy a universal remote, like the Harmony, that will start devices in a specified order.
Feb 12, 2012 | Panasonic DMPBD655 Player
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
I'm buying a 1080p blue ray disk player. I have this receiver, will it support 1080p? Thanks: Denon avr-4802.
Hi - If you mean can you run/switch a 1080P video source through the receiver, then the answer is no. It can only switch through the video component connectors on the receiver (1080i) but it's not a problem you can just connect your new BR player directly into the TV (HDMI) and have the audio handled by the receiver. It's a common setup and you're not really losing anything. It's the setup I have.
Enjoy your new great BR experience!!
Regards, Mikeywaf
Mar 02, 2011 | Denon AVR-4802 Receiver
I have a Denon AVR-3808CI A/V receiver, a Samsung HL67A750 DLP TV, a Samsung BD-P1600 Blu-ray player, and a Motorola HDPVR for the cable signal. I have connected the Blu-ray player and HDPVR to the Denon...
You will have to disable one or the other. Most likely the source because not all disk"s will be recorded the same. If a disk was transfered from film to digital poorly, this will show up as a grainy look on your tv, not much you can do about that. I would set your tv the best possible and go with that, also if your tv is capable of 24fps use that setting.tweaktv.com can help you with your tv setting. Use Progressive Mode on you blueray and your dvd also.
Apr 24, 2009 | Denon AVR 3808Ci Receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
Lost picture on my AVR-2807
There is a video select button on the receiver. Press it and it toggles through all of the video sources. Keep pressing it until the display says video=source.
Jul 23, 2008 | Denon AVR-2807 Receiver
Denon AVR-2113CI Logo
152 people viewed this question
Top Denon Televison & Video Experts
Jonathon summesfield
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
