Question about Philips ProScreen 4600 Impact Multimedia Projector
Phillips proscreen 4600 user manual - Philips ProScreen 4600 Impact Multimedia Projector
3 Suggested Answers
SOURCE: how do you get the
there is a door next to the input panel you will see 2 silver screws that you can use a flat head to unscrew once you take those out you will see another 2 screws that you will need to remove as well once that is done there is a flap on the bulb housing with a hinge that you need to pull up then tug on it and it will slide out once you do that you will get the bulb in the housing you will need to take the wires off the bulb one will be a nut the othere will be a torx screw remove those and there will be a metal long piece that is holding the bulb in plaace yppu have to pop that out then the bulb will slide out
Posted on Jan 09, 2009
  • 561 Answers
SOURCE: how to get this to
if you see light immiting then the bulb is ok.
it is probably the input, ensure the input is correctly selected.
eg video or computer.
connect your signal to the back connecor/s
and then on the remote our contol panel select that as your output to the screen.
it may take a while to warm up to get a image on the screen.
also when turning off do not unplug, use the off switch on the remote or control panel so it can
cool the bulb, this helps it last longer. then unplug when the fan has stopped.
I hope this was useful
Posted on May 23, 2011
Convergence phillips proscreen
The adjustment requires disassembling the projector. It's not really something that should be attempted in the field.
Sep 08, 2014 | Philips ProScreen 4750 Impact Multimedia...
How to get this to work I have a proscreen 4600, and when plugged in it comes on - so i assume it works, but have no manual- so don't know how it works. Can you assist me?
May 23, 2011 | Philips ProScreen 4600 Impact Multimedia...
Fan is cutting off, then lamp goes out I think it is overheating
have you checked the air filter and openings for good ventilation
Mar 27, 2011 | Philips ProScreen 4600 Impact Multimedia...
User manual
try the viewsonic manual.
www.aboutprojectors.com/pdf/viewsonic-pj506d-manual.pdf
Feb 23, 2011 | Philips ProScreen 4100 Multimedia...
Replace lamp
You have to buy a new lamp for this model,it can be ordered online at: projectorshop24.co.uk
May 05, 2010 | Philips ProScreen 4600 Impact Multimedia...
We received a donation of the 4600 projector but do not have a manual or power cord. How do we get these?
Internet. You can download an Owners Manual. For the power cord look online also or go to the store and buy one. Electronics shops usually have quite a bit of different kind of cords.
Mar 23, 2009 | Philips ProScreen 4600 Impact Multimedia...
Vertical lines all over image after few minutes turn on
Well i think we have the same problem i with our proscreen 4700 and the only thing i found out so far is that the rca and svideo jack on the projector have gone bad. Tried the data connector and the video was perfect. Tested the rca jack with new cables and another dvd player and it was still mesed up. So it is the hardware that controls the input for the rca and s vidoe jacks but still have not found a way to get the case open to see if some thing can be fixed from the inside.
Oct 13, 2007 | Philips ProScreen 4600 Impact Multimedia...
Help
Your convergence might be out.Go to convergence settings and try the setting and it can be done electronically.
Jan 20, 2007 | Philips ProScreen 4600 Impact Multimedia...
Philips ProScreen 4600 Impact Multimedia Projector Logo
132 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
