Crosley CW6000 Front Load Washer - Washing Machines
  • Official Brand Answer
  • 4,342 Answers
Hello - I will be happy to assist you; however what issue is the unit experiencing? With this information I can help pinpoint you the correct information.
Posted on Jan 15, 2013
  • 105 Answers
SOURCE: Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Posted on Mar 16, 2008
  • 198 Answers
SOURCE: crosley digital front load washer
jus try to lubricate the lock n then try.... it wil work
Posted on Jun 17, 2008
SOURCE: code nf shows on my washer
unplug for 15 mins and plug again to rest
Posted on Sep 14, 2009
SOURCE: Crosley CW6000 Washing Machine. When my washing
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Posted on Dec 08, 2009
SOURCE: Washer wont drain and spin properly
whee is th drain filter on crosley front loader
Posted on Jan 09, 2010
Crosley front load error code LE
LE error code. The machine thinks the door is open. If it's not, then the switch or control board is faulty.
Jun 03, 2014 | Crosley CW6000 Front Load Washer
I HAVE A CROSLEY FRONT LOAD WASHER AND THE DOOR WONT UNLOCK, I HAVE TOWELS INSIDE, HAVE TRIED RUNNING ANOTHER CYCLE, PLEASE HELP
I have had that happen a couple of times and by hitting the pause or cancel button a couple of times it then opened.
Mar 05, 2014 | Crosley CW6000 Front Load Washer
Tub will not spin
check your belt remove back cover
Dec 09, 2013 | Crosley CW6000 Front Load Washer
My washer machine does not spin
You will need to replace the lid switch. Here is the part to order.
Below is a video to show you how to replace it. The model may be different but the repair process is the same.
Nov 27, 2012 | Crosley CW6000 Front Load Washer
Crosley washing machine codes
Hello protocolu898 - Do you want to know how to display an error code on the washer? Or do you have an error code do you need assistance with?
Nov 26, 2012 | Crosley CW6000 Front Load Washer
Crosley front load washer L7 code
Hi - Are you certain the error code is L7? This manufacturer does not have any L7 error codes for any washer or other units. I understand that it will not spin either; does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly.
Oct 18, 2012 | Crosley CW6000 Front Load Washer
How do I get the outside cover of my Crosley CW6000W to replace the belt?
The belt is accessible from the bottom. Tilt the machine with a dolly [or something] and stack some 2x4's to hold it in a propped position, or lay it on it's side [get help if you can]. Good Luck.
Aug 30, 2010 | Crosley CW6000 Front Load Washer
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
Sep 02, 2009 | Crosley CW6000 Front Load Washer
Will not agitate
Motor belt cut Please check .
Mar 10, 2008 | Crosley CW6000 Front Load Washer
My washer won't drain the water
Can you check the motor pump with supply or with ohms meter if it is good the timer not giving signal during the washing cycle.
May 08, 2007 | Crosley CW6000 Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
