Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Cold water intake valve is dripping - Bosch Nexxt Premium WFMC6400UC Front Load Washer
  • Bosch Master
  • 17,129 Answers
Possible that the valve is faulty, or that the bandage or hose connection is not tight . You can remove and use some tape to reset the connection, if the water drips further from the valve then it can be due to faulty inlet valve. If so replace the valve.
Posted on Jan 15, 2013
Why does the rinse cold water drip in so slowly?
check filter (screen) in water valve intake and hoses to do so you need to take the water hoses off
Oct 07, 2014 | Whirlpool Washing Machines
Water intake valve
CHECK THE HOSE RUBBER SEALS GASKETS
Apr 13, 2014 | Frigidaire Affinity ATF7000E Front Load...
When washer finishes cycle and spins out water will start dripping into the washer and will get the clothes wet if not taken out
You have a faulty water inlet valve which needs to be replaced. If it's cold water dripping into the machine then it's the cold water inlet valve.
Oct 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Cold water filter is clogged - how to clean?
the water solenoid valve is cheap enough you could just buy new and put in. wouldnt waste my time trying to clean it just replace it.
Aug 01, 2010 | Estate TAWX700JQ Top Load Washer
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water dripping out of water dispenser tube
SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
Jan 12, 2010 | Kenmore Refrigerators
Top load washer- drips water into tub (where hot and cold water enter tub) when machine isnot in use
Sounds like the screen that is at the hot and cold water intake has moved into the selenoid valve.
You may want to remove the valve and inspect it for pieces of screening. You should be able to run it under the sink faucet to clean it.
If that is not the problem, then order a replacement (they are fairly cheap and VERY easy to replace)
Jan 08, 2010 | Washing Machines
Water keeps dripping after machine is turned off.
turn hot water tap off if it still drips replace cold water inlet valve if it stops replace hot water valve
Aug 14, 2009 | Maytag PAV2300 Top Load Washer
Water intake and wash cycle
change the water intake valve, that is the only answer i think
Oct 10, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
197 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
