How doI access the hard drive in a Packard Bell 422 CDT
  • 7,627 Answers
The hardware HDD? Open the case. Try PB Support for details: http://www.packardbell.co.uk/pb/en/GB/content/download
Posted on Jan 16, 2013
pagebor
  • 2785 Answers
SOURCE: Packard Bell EasyNote H5 Laptop,
please check your power supply unit.
Posted on Apr 04, 2008
  • 3 Answers
SOURCE: packard bell easynote laptop model
1. with the laptop off and battery removed, remove the hard drive. Check the contacts for corrosion and if present, clean off with a pencil eraser, then reinsert hard drive, then battery and try again.
Sorry, before inserting the hard drive write down the model name and number, number of heads and cylinders, etc.
2. If the above doesn't work let's hope it's the bios. Invoke bios at startup and manually enter hd model
let me know how you fare, good luck.
Posted on Apr 27, 2008
voodoomox
  • 1689 Answers
SOURCE: How do I get the
the enclosure is locked but clickers, the only way to oepn it is by force since PBell has a specific pressure point on the enclosure to open it.
the ratling sound means that the disk in your HDD is not alligned, it could just be a matter of time before it completely looses railing and be unusable.
best move you can do is contact PCBell and have them informed about your issue.
good luck
Posted on Jul 23, 2008
steve6375
  • 395 Answers
SOURCE: How can i remove the
If you have a router with two thernet ports you can connect them together using this.
Otherwise you can take the hard drive out and connect it to your new computer but this can be tricky to do.
The other thing you could do is buy a USB hard disk caddy. Fit you hard drive into this and then connect it to the USB port of your new computer. Make sure the caddy will take your size and type of hard disk.
Posted on Aug 17, 2008
  • 468 Answers
SOURCE: Packard Bell Imedia X2414 running Vista home
Sure just must bee SATA II
Posted on Nov 28, 2009
Why did packard bell recovery not working
Could be all sorts of reasons from corrupt files to errors on the hdd.
Feb 06, 2015 | Packard Bell Computers & Internet
Will the hard-drive from PACKARD-BELL IMEDIA X2414 go into DELL GX150LINUX
Yes if the data connections are compatible. SATA data interface and SATA power connector, it's a thin black connector.
It is not reccommend to switch drives across operating systems unless you are abolutely sure that you know how to access the drive without damaging/erasing the information that is currently on the drive.
The current Windows hard drive will not boot in a different pc system.
I would suggest getting the orginal pc working again, it may be a simple case of loose connection/contacts. Unless you had a friend that would be willing to help, by attaching your hard drive to his pc as a slave and then copying your data to DVD's.
See my published guide entitled: My Computer is not turning on!!! Is it dead!!! No POST!!!
Take care!
damnor01
Jun 07, 2012 | Dell OptiPlex GX150 PC Desktop
I want to reformat PB MS2303
Packard Bell is a computer manufacturer, now owned by Acer. Restoring your computer will erase the hard drive and install a fresh copy of Microsoft Windows. This is beneficial if the Packard Bell is showing its age and running extremely slow or has been hit with an incurable virus infection. Before attempting to restore the system, be sure to back up any data you wish to save.
1.Insert the Windows Setup CD/DVD into the computer's optical drive. The disc will have been included with the Packard Bell computer.
2.Restart the computer with the disc inserted. A black screen will appear when the disc is detected, displaying "Press any key to boot from CD or DVD..." Press any key on the keyboard to launch the Windows installer. The "Install Windows" screen will appear.
3.Click "Next."
4.Select "I accept the license terms" and click "Next."
5.Click "Custom" when asked what type of installation you'd like. The other option is "Upgrade," but in order to restore your Packard Bell system to its factory settings, you must reformat the hard drive.
6.Click "Drive Options" when asked where to install Windows. Select the C: drive and click "Erase." Select the unallocated space after it has been erased, and click "Format." Format the space using the "NTFS" file system.
7.Click "Next" and Windows will begin reinstalling on the Packard Bell's hard drive. The system will reboot when finished and launch into your newly restored Packard Bell.
Sep 09, 2011 | Packard Bell W3301 Notebook
Bonjour, quand je vais sur internet et que je dois accéder au disqu dur, je ne peux plus rien faire. "ne repond pas " s'affiche. que faire ?
Windows a ete corrompu par virii - il est trop tard pour le desinfecter. Tu dois reinstaller Windows Tout de suite.
Nov 24, 2010 | Packard Bell Computers & Internet
Easynote will not go past packard bell screen
You may need BIOS update. Check your CMOS time at bios page.
If time is wrong, set it up and try again. If this is solved the problem, change the CMOS battery.
JMC
Aug 15, 2009 | Computers & Internet
I dont know where the hard drive is located on the Packard Bell easy one 1550 notebook
Uner the keyboard is what my diagram says. it also can be mounted just beside the battery so check both locations. wow packard bell is a old computer.. But still good i guess. Rate me I appricate anything above thanks for trying!!
May 14, 2009 | Packard Bell Easy One Silver 2120 Notebook
How can i remove the hard drive from my packard bell club 79 computer?I have some pics on there i would like to put on my new pc but the old packard bell no longer connects to the net and as it had win98...
Aug 17, 2008 | Packard Bell Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
