Question about Orion EZ Finder II Telescope Reflex Sight
Ez finder 11
Led does not function
N68s3+ panel connection
PANEL1: Front Panel Header for Biostar N68S3+ from
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dl
This 16-pin connector includes Power-on, Reset, HDD LED, Power LED, and speaker connection. It allows user to connect the PC case's front panel switch functions. Pin #1 has a black square on the motherboard and the pins are oriented from 1-8, left to right, bottom row and 9-16, left to right, top row. You will notice that there is no #11 pin.
pin #'s
1-2-3-4 Speaker (1+, 4-)
5-6 hard drive LED (5+, 6-)
7-8 reset switch (7-, 8+)
9-10-11 N/A (not used)
12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **
13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **
15-16 power button (15+, 16-)
Did this solve your problem?
Dec 22, 2012 | PC Chips Computers & Internet
How to connect panel 1 of n68s3+
pin #'s
Dec 22, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
No software for EZ-DUB eZAU422; help?
Sorry we have no drivers or software here.
Jun 26, 2017 | Cameras
I have a Roland E-70 Intelligent Synthesizer, buit the manual does not give instructions on how do transposition. I need to transpose the instrument to play a music in a lower key. For example, when I...
section 7 page 89 of the E-70 manual I downloaded from http://www.rolandus.com/support/owners_manuals/?group=2
describes the use of the transpose button.
In short, you set the value for the transpose function in the parameter menu (section 9 in the manual) ranging from -11 to +11 semitones.
In your case I would set the value for the tranpose button in the menu to minus 2 as you want a full note (= 2 semitones) down from C to B-flat and G to F etc.
And you activate or deactivate the transpose function itself by hitting the transpose button. The little red led next to the button shows whether the function is on (led is lit) or off (led is not lit).
Hope this helps
Mar 12, 2012 | Music
On my hp 6710b running windows 7, im trying to get wirless to work and it tells me it is not on and that I have to turn on switch on front or side , or use function keys . I have looked everywhere and I...
Here you go. . .(#18 is the button location)
439c6ce.gif 1. Volume mute button with LED indicator
2. Volume scroll zone with up/down LED indicators
3. Integrated microphone
4. RJ-11/modem port
5. Optical drive
6. Media Card Reader
7. 2 USB 2.0 ports
8. HP Fingerprint Sensor
9. Integrated stereo speakers
10. Touchpad with scroll zone
11. Touchpad buttons
12. Hard drive activity / HP 3D DriveGuard LED
13. Battery charging LED
14. Power/standby LED
15. Wireless on/off LED
16. Power button with LED
17. HP Info / HP QuickLook button with LED indicator
18. Wireless on/off button with LED indicator
19. HP Presentation button with LED indicator
20. WLAN antennas (with WLAN option)
21. WWAN antennas (with WWAN option)
Aug 26, 2010 | HP Smart Buy Notebook
I was just given a telescope and I need a reliable place to purchase parts. The main piece i'm looking for is an adjustor ring on the aiming scope and some different eye pieces
Meade may have the part, but I doubt it. You can call them here:
http://www.meade.com/support/index.html
It might be easier just to replace the finder scope with one of these:
http://www.telescope.com/control/celestron/celestron-accessories/celestron-firstscope-accessory-kit
or this:
http://www.telescope.com/control/accessories/telescope-finder-scopes/orion-ez-finder-II-telescope-reflex-sight
Eyepieces can be purchased at many on-line retailers. Here are two:
http://www.telescope.com/control/telescope-eyepieces
or here:
http://www.agenaastro.com/
Aug 23, 2010 | Meade 155W (5 x 50mm) Telescope
The pointer don't works, don't turn on. Where
This has a battery inside -- replace the battery. If the actual ON OFF switch is broken it's not worth fixing. You can buy a new one here--
Mar 08, 2010 | Celestron NexStar 5 SE (300 x 44.45mm)...
Orion EZ Finder II Telescope Reflex Sight Logo
35 people viewed this question
Top Orion Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
deton8 von Splosion
Tony Parsons
Tony Parsons
Are you an Orion Optic Expert? Answer questions, earn points and help others
