Question about Sirius SUBX1 Universal Plug and Play Boom Box Boombox
Does the boombox have a fuse inside - Sirius SUBX1 Universal Plug and Play Boom Box Boombox
How can i open my sony xplod boombox radio to check the internal fuse
If there's no visible means to open it, there is no serviceable parts inside. btw, look for this note on your radio, to be sure.
Oct 01, 2015 | Sony Xplod CD/Cassette Boombox with AM/FM...
Hi is there an inline fuse inside my boombox? I have an 12v adapter in which i stupidly hooked up wrong to the battery on my vehicle?
No fuse inside your portable stereo! Only in the plug from the mains! Where are you plugging the adapter from your vehicle?
Oct 04, 2014 | Audio Players & Recorders
No power
Load it with batteries, and pullout the AC cord from its socket. Now check whether it works on batteries. If yes, make sure that the mains transformer or fuse inside has the fault.
Jun 06, 2012 | Supersonic SC703CD Radio Boombox
I have a bosch pb360 boombox that wont turn on with new batteries and the fuse is fine
There are two internal glass fuses inside the Bosch pb360sc.
If it won't power on, flip it upside down and remove the bottom section of the radio and four of the screws for the roll cage. Once inside you can figure out which fuse is dead and replace it. The Bosch manual is totally useless and does not tell you or indicate that there are any internal fuses. The fuse that runs the 12volt power supply / cigarette style outlet has nothing to do with your radio not being able to turn on/ power up. I guess they want their service partners to be able to jam you for .50 cent fuse....
Apr 07, 2011 | Bosch Audio Players & Recorders
The radio stopped getting power
If you remove the front face (radio side) you will see a black box. remove the screws and cover and inside upper left corner a little pcb, check the fuse.
Mar 14, 2011 | Bosch PB10-CD Radio/CD Boombox
My Emerson 5812 Boombox will not turn on all of a sudden. I just bought it a couple months ago and it will not power on.
If its still under guarantee then take it back to the shop if you have the receipt. If not then it could be something as simple as a little glass fuse inside the boombox.
May 21, 2010 | Emerson (PD5812) Radio/CD Boombox
Won't power on either plugged in or w/batteries.
Try changing the glass fuse on the inside of the unit.
May 20, 2010 | Sony S2 Sports ZS-XN30 Radio/CD Boombox
When I press the power button to turn the unit on,
Check your cord first, make sure it's in good shape. Sometimes the main transformer goes out, and you can use a DC adapter to bypass the 120 V source. Could be a fuse, or something else in the power supply inside the unit.
Mar 13, 2010 | Durabrand CD Boombox, Pink Boombox
When radio is plugged in only the gfi outlets work not the radio.
Mines similar, outlets work but radio will only work on battery. Radio will not work on mains only. Charger works at same time so ok. SORTED IT TONIGHT. Inside the charger inside the box there is a fuse (240v 2A) I think, tiny radio fuse. Changed that tonight and radio now works on mains only or battery. Very awkwark job but better than watching a load of cr** on tv. Hope this helps someone.
Aug 12, 2009 | Bosch PB10-CD Radio/CD Boombox
BOOMBOX WONT PLAY ON BATTERY OR ELECTRIC WHAT WRONG WITH IT
Dear kbusse:
Does the switch feel like it's broken( switch pushed too far in,switch too far out)?
If there is a remote does that turn the unit on? Inside the unit by the power cord connection to the transformer should be a fuse; check to see if the fuse has blown. I hope these suggestions help.
Good Luck
George
Mar 02, 2009 | Aiwa CSD-ED27 Boombox
Sirius SUBX1 Universal Plug and Play Boom Box Boombox Logo
59 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
