Question about NoiseHush N500-11399 - N500 Bluetooth Headset with 4
My NoiseHush N500 Wont Charge But The Red Indicator Is On Then It Turns Off To Show Its Charged. So When I Turn It On, It Blinks Red Showing Its Dead.. What Do I Do?
Blutooth codes for kyocera
Step 1 Charge the Bluetooth headset battery. The headset is fully charged when the indicator light turns off. Step 2 Unplug the charger and check the indicator light to ensure that the headset is turned off. If the indicator light is on, the headset is on. Turn off the headset by holding the multifunction button (the button in the middle of the headset) until the indicator light blinks red and shuts off. Step 3 Press and hold the multifunction button until the indicator light blinks red and blue to place the headset in pairing mode. Step 4 Turn on Bluetooth on your phone to start searching for available devices. When the search is complete, a list of available devices appears on the screen. On many phones, the Bluetooth options may be found in Settings. Step 5 Select the Kyocera Bluetooth headset name from the list. The phone prompts you to enter a passcode. Step 6 Enter "0000" using the phone's keypad to finish connecting the headset to your phone.
Aug 11, 2014 | Kyocera Cell Phones
Noisehush n500 bluetooth
you can check the battery life of the bluetooth,if ok then you need to back up your files and have a reset your phone into factory default and paired it again....
May 14, 2014 | Cell Phones
I have a Noisehush N500 bluetooth and I need help in making it work on my Android I1.
Follow the steps to make it work on Android:
1. Switch off your N500 bluetooth headset 2. Press and hold the power button on N500 bluetooth headset for 6 seconds. (Remember, down press and leave the power button as it will switch on. We have to put it in discovery mode so pres and hold for 6 sec.)
3. The led will flash from blue to red.
Now on your android phone, Go to settings, "Wireless & Network", Bluetooth Switch on the bluetooth and scan for devices You will see Noisehush N500. Click on the name and select pair
5. Enter "0000"as the passkey when phone when phone prompts. 6 Select the name again in phone and select connect.
The headset will be connected. If it asks to authorize, select always authorize.
May 31, 2011 | Cell Phones
When I plug my Motorola H710 bluetooth in to charge the light only blinks red and when I use it it never seems to turn on?!
Here's the instructions for charging.
Plug the Motorola charger into the end of
the headset.
The indicator light turns red when the battery is charging. It may take up to 1 minute for the indicator light to turn on. When the headset's battery is fully charged (about 2hours), the indicator light turns green.
From your information, it may very well be that the battery should be replaced if the red light doesn't go off as it should.
Here's a link to the full instructions. I hope this helps.
(Click here)
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H710%20QSG%20EN%20Generic.pdf
Feb 06, 2010 | Motorola Mobility H710 Bluetooth Headset
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
4 whhel strider won't run, batteries charged
the motor is not working perfectly and chnge motor or check the connection perfctly
Jul 13, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Battery indicator light blinks red
if it show fully battery also when u charge your battery it show from the red indicate only tht is not a problem... u need to charge the battery fully ... untill the msg shown as charge complet .. so need not to worry about the Red blinking battery indicator when you plug in charger.
Apr 28, 2007 | Motorola Mobility RAZR V3
NoiseHush N500-11399 - N500 Bluetooth Headset with 4 Logo
71 people viewed this question
Top NoiseHush Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a NoiseHush Radio Communication Expert? Answer questions, earn points and help others
