Question about Royal Procision 3050 Bagged Canister Vacuum
Royal 3050 power head does not run
Smoke came from the powerhead. The powerhead will not run. There is no voltage from the canister to the hose. Vacuum still has suction. How do you get the canister apart?
  • 2 more comments
  • fellis25 Jan 23, 2009
    The powerhead may be burned out, but there is still no power coming out of the canister to the hose cable.
    last link provided no help
    Again, there is no power going to the powerhead
  • fellis25 Jan 24, 2009
    Again, the powerhead motor may be burned out, but that is not the entire problem. There is no power out of the canister even with the cable to the powerhead disconnected.
    President:
  • 1,214 Answers
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Posted on Jan 23, 2009
  • Mark Egan Jan 23, 2009
    Your going to need to look inside the roll around vacuum to locate where the wires connect to the hose and check their connection. If there is power there, then it may be the wires are broken in the hose up to the point of connection with the head, at the handle. If not, then look deeper into the vacuum section for where there may be a fuse, circuit breaker, or broken wire/connection.
  • 19,396 Answers
"There is no voltage from the canister to the hose. Vacuum still has suction."
That means that the motor is good.
If there is no power to the powerhead, and you got smoke, then either the powerhead motor had gone, or there had been a short in wirings.
The schematics for your model are not available on the web, you can order them by contacting one of the two websites below:
Royal Repair Parts - Hesco, Inc.
Royal Vacuum Schematic and Part Lis
Posted on Jan 24, 2009
    Sergeant:
  • 221 Answers
Wow, that motor is one of the most complex in a vacuum and to repair it can be very difficult, if you want to replace it you can but it will be very expensive just for the part. the screws are hidden under that big rubber gasket on the bottom of the machine where the water tank sits. you should also replace that gasket two because it will get ruined when you tear it off.
    Sergeant:
  • 378 Answers
It indicates that the motor is burned out.open it and replace the powerhead motor and also change internal wirings as this shorttracking may have damaged other wiring too.
    Scholar:
  • 97 Answers
  • 45 Answers
1. No electricity is going to the unit
2. Burnt Motor
1. Make sure ALL electrical connections
are plugged and work correctly.
3. Replace power head’s motor
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
My powerhead shuts off on its own and then i must push the switch again.
Just had this with mine and I think it is the power wires embedded in the hose from the cleaner to the powerhead. Turn the cleaner on then work your way along the hose kinking it or moving it until the power head stops. Switch the power head on again and kink the hose in the same place, if it turns off every time like mine, that is where the break is. I haven't worked out if the cable cores can be replaced or repaired yet. Hope this helps. Chris.
Aug 18, 2010 | Dyson DC21 All Floors Stowaway HEPA...
Miele vacuum powerhead
My power head failed due to the handle switch. It comes apart with the Phillips screw under the vacuum kill slider. Check for continuity across the switch contact solder points.
Mar 01, 2010 | Miele S251i Plus Bagged Canister Vacuum
Vacuum head stopped working, unresponsive to on/off switch and light bulb is out. Canister otherwise works fine. Help!>?
Power head on/off switch could be faulty, Wires running through hose may be broken, electrical connections may be burnt.Motor in Powerhead could be dead.
Nov 17, 2009 | Vacuums
No power when its turned on
There was a (common cause) power arc during the swap (while running the vacuum).
The fuse located under the grey clipped-on plate of the canister is blown. The fuse is soldered-on the board and would need to be changed (board or fuse). Not "user friendly" zone. Warranty? Smart if they designed a breaker button instead of a fuse here...
Rick
Mar 13, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Short in wiring on hose
Hi vlpovey:
Sorry about that I clicked on the "post" button before I included the web page.
Here it is: www.govacuum.com/royalvacclean.
Hope this helps.. PS Please leave a rating if appropriate Thanks
Loringh
Nov 22, 2008 | Royal Procision 3050 Bagged Canister...
Broken belt
If you have the power head with the headlight, squeeze the sides of the upper part (almost like a superstructure,) where the headlight is located. It should lift off, allowing access to the screws to get the powerhead apart the rest of the way, and on most models it even has instructions on how to replace the belt molded into the plastic.
-R
Aug 03, 2008 | Vacuums
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Fantom Canister
It sounds like you have a hose problem. You should be aware that the Fantom company went bankrupt many years ago. I know that the Fantom name was bought by another company and there may be Chinese units sold under that name, but service and parts availability is an issue. There may be an issue with the power delivery to the powerhead. This is through the hose, from the canister connection and down the wand assy. You should check the continuity from the canister down to the powerhead.
Dec 12, 2007 | Fantom Vacums Lighting Canister Vacuum
Lack of Suction
There are actually several possibilities.
Check to make sure that the brushroll is spinning. The brushroll is responsible for virtually all of your pickup on carpet, and is the culprit for most complaints of "lack of suction."
If the brushroll is not spinning, listen at the head to see if the motor inside the power head is active. If you can hear it running but the brushroll is not turning, you have a broken belt. If the motor in the power head is not turning at all you may have an electrical short in the hose, the wands, or the main power outlet from the body of the canister; but before you get too involved check the power head for a thermal reset button. Some of the Electrolux powerheads are equipped with these, and some are not, so check your user's manual. If there isn't one, or if it isn't tripped, you'll need to look for electrical issues.
In this particular model it is fairly common for the electrical contacts on the wands to short out, so inspect the metal contacts to look for scorching, or melting of the plastic around them. If you have access to a VOM, check for voltage at the contacts on the end of the wand, and if it is not present, check all of the contacts sequentially back to the canister body to determine which part is not passing voltage. If you have voltage all the way through the wand, you either have a loose connection inside the power head, or the power head motor has burned out. If you have power from the canister body, but not through the end of the hose, either your hose has a short in it, or the circuit board in the handle assembly that controls the power head power has shorted out.
If your brushroll is turning, then you do, in fact, have a clog somewhere inside the power head, which a visual inspection behind the brushroll and into the elbow will confirm.
Best of luck,
-R
Apr 01, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Royal Procision 3050 Bagged Canister Vacuum Logo
324 people viewed this question
Top Royal Vacuums Experts
Electroboy
Electroboy
Are you a Royal Vacuum Expert? Answer questions, earn points and help others
