Question about Radio Communications
I NEED TO PURCHASE A CB68A MICROPHONE FOR A PA SYSTEM ON A SCHOOL BUSWHICH IS CONNECTED TO A PANOSONIC CQC1101AM/FM CD RECEIVER
TRANSDUCER PRINCIPLE:CONDENSER FREQUENCY RESPONSE:300HZ-6KHZ PICK UP PATTERN:OMNI SENSITIVITY:-45DB IMPEDANCE:LOW3 IMPEDANCE HOUSING:ABS POWER SUPPLY:DC9V[ 6P BATTERYX1,ANOT INCLUDED]
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
I know you have this pdonlem under control by now but here is what I would do.I would contact www.copperelectronics.com and tell them what you need and they will set you up.
Posted on Nov 04, 2013
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: I need to purchase a Executive series 100 cb68a microphone for a P. A. system on a school bus.
I would Google this as most repair places may not have this ==you may be able to find the microphone on Ebay also.
Posted on Dec 07, 2012
Galaxy dx 44hp, no am audio or mod ,fm & pa ok
Have you tried another mic. First guess microphone wire broke or broke solder for audio wire in mic jack at mic cord.
Mar 26, 2014 | Galaxy Radios DX-44HP Mobile Amateur Radio
Lavalier pdwm96 microphone
Well, 1st thing is you've bought one of the worst wireless mic's on the planet BUT if you insist on "hooking it up" here goes....
1. Mic connected and transmitter (with new battery) turned on.
2. With volume down, plug receiver directly into amplifier/PA 1/4" input.
3. Talk into mic and slowly raise volume of amplification system.
4. READ YOUR OWNERS MANUAL!!!
Feb 08, 2013 | Audio Players & Recorders
Dec 06, 2012 | Radio Communications
I need to replace the microphone on a school bus P.A. system, the system has the following-Executive series 100 cb68a-where can this microphone be purcched. Thanks Jim
Hi James,
You may try posting on the Cars & Trucks forum, if you haven't already done so, as the people there may be more helpful.
This is a 2-way radio forum.
Cheers,
Peter
Dec 06, 2012 | Garmin Rino 130 (14 Channels) 2-Way Radio
How can I connect a microphone to yamaha rx v692
If your trying to have a PA sytem with these unit, you need to have a
separate mic mixer.
But if your trying to setup a Videoke Sing-along System , just connect
the Mic to the player Mic Input.
But if you need and feel to DIY, there is another option
and only if you can.
Oct 20, 2012 | Yamaha RX-V692 Receiver
I need to buy a longer cord for my PA system system on my shuttle bus...the microphone has the following on it: Executive series 100 CB68A
Mike - it would probably help if you provide the name and model of the PA amplifier too... but even so:
It is doubtful that you'll be able to simply buy an "extension cord" to place between the end of the existing mic cord and the PA's mic jack. You could probably have a new, longer cord to replace the current short cord on your mic fairly easily. Since this would require soldering and use of special sheilded cables, you should probably have it done professionally. Just about any commercial or business radio shop should be able to swap the cord for one as long as you need.
I hope this helps.
Sep 23, 2010 | Garmin Rino 130 (14 Channels) 2-Way Radio
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
My school uses Sennheiser Mic's for it's PA system. Is there an adaptor that would let me connect my CD player to the PA sytem's mic jack via the CD player's 3.5 mm headphone outlet?
The CD is STEREO whereas the MIC is monaural.
One could make an adapter that merges the left and right channels before sending on the balanced XLR input. This involves using an audio transformer or direct input box for the balanced line and is not DIY unless you are elctronically skilled.
The best way to do this is to instead plug the output of the CD into the TAPE inputs that are usually available on the mixer.
One uses usually a 3.5mm stereo splitter cable with RCA plugs for most of them.
Sep 10, 2010 | Sennheiser Epack-835 Professional...
This is not syncing with my pgx4 receiver The batteries are fresh. The receiver is plugged in The channel automatically selected. The green ready light didn't turn on, on the receiver, but the microphone...
Look for a possible source of interference.
The unit is likely FM and an FM receiver will "capture" the strongest signal right one or not.
Key is to find which of the two components is faulty. The green LED's really mean very little... other than battery and carrier received.
If you can find another system to isolate which is failed, then progress can be made.
Feb 28, 2010 | Shure PGX-2 Wireless Handheld Microphone...
Transducer not connected
my 947 c says transducer not connected
Jun 14, 2008 | Humminbird 947C GPS Receiver
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
