Question about I Power In Box Honda Eu1000i Power Generator
Need service manual for Honda Generator EU1000i
Where do I get a new carburetor for my EU1000i Honda generator?
Either through your local Honda power equipment dealer, or online at a Honda power equipment distributor like boats.net or dealercostparts.com. I have had great service from all of these options.
Oct 16, 2014 | Honda Electrical Supplies
Engine runs but stalls when you put a load on it
As the load goes up on any gas engine, the governor is supposed to open the carburater as needed to keep the engine speed up. It is normally a vertical lever with a spring attaching it to the carburater throttle linkage. Look it over and you will see it. Is it working?
Nov 24, 2013 | Honda Eu1000i Eu1000 Generator Service...
My generator will run great and then all the sudden it will start to spit and sputter and die. After a few min you can restart it and it will run great again for a period of time and then start to spit and...
could be a ton of things. water in the gas will separate in the carb and effect it. restrictions in the fuel line/filter is another. I would look there first as it does not appear to be electrical or mechanical.
Jan 04, 2018 | Honda EU1000i Inverter Generator
It has been sitting up for a couple of months and now I can't start it.
drain gas from carb. clean spark plug. trying to start with old/bad gas will foul out the plug.
Aug 29, 2013 | I Power In Box Honda Eu1000i Power...
Eu1000i runs and cuts off.....pump is good
If you haven't had it started for a while and have left gas in it, you probably have old/bad gasoline. Drain it and put new gas in. It may have clogged the fuel filter with rust and sediment from the old gas. Next time, put "Sta-bil" in it when you store it for the season, it will stabilize your gas.
Jun 21, 2012 | Honda Generator Cover Eu1000i Camo
1985 Honda VT 500 C Shadow LOCATION OF PULSE GENERATOR
Hi, Sylvia for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1985 vt500 pulse generator
83 vt750 pulse generator
http://www.cycleterminal.com/Service-Manuals/Honda-VT500C-Shadow-Service-Manual-English.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-vt-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 02, 2012 | 1985 Honda VT 500 C Shadow
How can I shut my Honda eu1000i off from inside the cabin?
You should not have to cut any wires to install a remote kill switch. Most honda engines have an oil alert what will cut ignition if oil level is low. The switch actually shorts the itnition to ground just like the on / kill switch. Just unplug oil alert wire from harness and add a homemade connector with second lead and connect another wire to ground/frame of generator engine. When you short these two wires together it should kill engine. Solder these two wires to a female connector (Radio Shack) and just leave inside generator when you want remote switch. Attach switch to leads of desired length of male connector to mate with female connector at generator. Good Luck.
Jul 10, 2010 | Honda Electrical Supplies
2 year old honda eu1000i generator with new spark plug fresh oil fresh fuel clean air filter starts eazy runs for 2 mins then dies
SOUNDS LIKE TO ME YOU HAVE A PROBLEM IN THE OIL ALERT SYSTEM, IF YOU HAVE THE REPAIR MANUAL IT WILL TELL YOU HOW TO TROUBLE SHOOT IT!!!
Aug 30, 2009 | Electrical Supplies
I Power In Box Honda Eu1000i Power Generator Logo
53 people viewed this question
Top I Power Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an I Power Electrical Supply Expert? Answer questions, earn points and help others
