Question about Reebok Exercise & Fitness
Reebok ZR8 treadmill will not run
When I turn the treadmill on the system beeps and there is power in the machine. However, the LED system is showing _ _ _ _ across the 3 displays (as if the safety magnet has not been attached, but it has). I cannot get the machine to run any programs. Delivered yesterday and worked ok at first but then went into this state of paralysis.
SOURCE: help, my Reebok 8700 ES treadmill won't work...
I had the same problem happen today!! I called 188-999-3756, they are sending my a new panel for 5.95! Yes, I bet that many owners of this treadmill have had the same thing happen. Mine is only 8 months old! let me know if you get this message.
Posted on Mar 26, 2009
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
SOURCE: Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Posted on Jan 06, 2010
SOURCE: I have lost the safety key for my Weslo treadmill
Hi I folded up a piece of paper several times to make it into a small rectanguler shape and inserted into the slot for the key and it worked.
The replacement key doesn't need to be magnet just small enough to fit the shap of the slot is fine.Mine was a Weslo cadence 1000 (bought in 2002)
Posted on Jan 10, 2010
  • 103 Answers
SOURCE: My Proform 8.5 personal fitness trainer will no longer work
Hello there, It seems that you have a stuck button or a problem with the ifit card area. Yes I know you probably dont use it but just listen. If you have the demo card for the unit try putting the demo card into the ifit slot and press it in and out a couple of times. This will sometimes correct this problem. If that does not correct it then you will need to replace the console or possibly disconnect the ifit section from the console itself. Either way you will need to remove the console.
If more info is needed please leave me a note here and I will get back to you asap.
Good Luck! Tim
Posted on Jan 11, 2010
Testimonial: "Tim, Thank you very much for your help. I already had the console apart so I just unplugged the ifit section and it works perfect. Randy"
Healthstream Evo Treadmill. When I turn machine on, all I get is 3 Beeps. The screen display has 8 rows,The 6th row is fully on. The bottom the alpha numerals,the center led of each unit is also lit.
Sounds like a fault in in the treadmills computer system the beep3 are error alert sound meaning somethings has gone wrong inside or the motor is reporting jamb fault code etc and its displaying with the lights upon the display board an error code a treadmill enginer will understand
Jul 12, 2016 | Washing Machines
Hi my power first t960 treadmill stops working. it turn's on. startup beeps are ok. display turn's on and showing regular digits. but non of keys working and consul dos not response to any key. thanks
Check the cable from console to motor control board. It would be a detachable connector on both ends. Try removing and reconnecting it. Sometime such problems can occur because of the bad contacts of connectors.Please remember to remove the power before attempting any service inside treadmill.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 10, 2016 | Exercise & Fitness
My treadmill wont re-boot
follow this steps and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 11, 2013 | Epic A30T Treadmill
My new visions t9550 treadmill will not calibrate. it completes the speed calibration but treadmill will not elivate therefor fails calibration. what do i do?
Step 1:
follow this steps for troubleshooting and fix it. God bless you
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
Step 2:
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP for elevation Motor. You must clean contact of the Relay with Special Spray(Radio Schack).
With this you must fix it.
Step 3:
Try this again. and fix it.b) LUBE the gear motor, shaft and turn the POT a little and see if the motor get RPM.
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in).
Jan 07, 2013 | Vision Fitness T9550 Folding Treadmill
Initial calibration keeps failing. the treadmill will not elivate
Step 1:
please see this test and fix it. God bless you
Step 2:
LED.
This the board LED, who control the DC to +12vdc) then the +12V LED lights.
LED.
operating properly.
Step 3:
please lube the elevation motor, shaft, and gear, and adjust the POT for RPM, and see what happen. see the diagram + block diagram attached for troubleshooting and fix it.
God bless you
The motor does not turn on
Dear Sir:
This is probably a 1) faulty speed sensor or 2)the speed sensor is not plugged in properly. 3)ts also possibly a faulty motor control board or lower board.+ 4) main motor fault.
Adjust the sensor speed see the diagram.
Run the software calibration for easy diagnose and troubleshootin.
See my personal TIPS for Help and diagnose.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 11, 2012 | Epic View 550 Treadmill
My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Jun 11, 2010 | Tunturi T30 Programmable Treadmill
Treadmill Tunturi T 20 keeps inclining upward by itself
Testing Mode 1. Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then‘SPEED DOWN’ and hold buttons pressed simultaneously 2. LED scanning mode for verifying display functionality 3. Press ‘ENTER’ to scan DATA LINES to verify display functionality 4. Press ‘ENTER’ to scan SACN LINES to verify display functionality 5. Press ‘ENTER’ to scan LED’s to verify display functionality 6. After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) 7. Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ to decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
May 10, 2010 | Tunturi T20 Folding Programmable Treadmill
Exercise & Fitness Logo
677 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
