Question about Mitsubishi WS-65411 65" Rear Projection Television
Only turns on with remote and won't stay on
    New Friend:
  • 109 Answers
Power button on the television itself may be stuck - go to the unit and press the power button se if it engages. If it depresses and sticks there is your issue - if it does not check the remote take out the batteries and unscrew the unit take the rubber pad out of the casing and spray out with canned air. If that doesn't do it - try unplug the tv from the wall for 1 minute or 2 and replug-in and see if the problem persist if so you will need to contact a tv repair shop but it sounds like the button on the tv needs to be cleaned because something is holding the power position in a spot to turn the unit off
Posted on Jan 15, 2013
Why won't my subs turn off after i hooked it up to
ive seen that happen a couple times and i have a few solutions, but first whats the year and make of the car? and also did you splice the remote wire for the amp to the remote wire to the factory deck, or did you use a line out converter that picks up speaker current and sends a signal to turn the amp on? and last question is does just the amp stay on with no noise coming from the subs?
Mar 20, 2013 | Car Audio & Video
Fujitsu plasmavision won't turn on
How many times do the red light blinks at a time? Count it. It is fault indication. After counting it, click here for details.
Dec 24, 2012 | Televison & Video
Stereo remote wire won't power on amp sony mex
The easiest check is unhook the remote turn on wire from the amp and use a small jump wire to bridge the 12dvc input of the amp and the remote turn on connector of the amp. If the amp powers on there is an issue with the remote turn on connection either a bad wire or bad output. If the amp doesn't turn on there is an issue in the amp wiring or the amp itself.
Nov 26, 2012 | Car Audio & Video
I have a 1996 acura rl and my problem is my remote entry won't work and my cluster light won't shut off and the check engine light came on all at once don't have a clue as to why
remote entry wont work because either remote battery is dead or remote broken.cluster light will stay on if head light stay on could have faulty headlight relay or headlight control unit faulty let dealership check it out.
Sep 09, 2012 | Cars & Trucks
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
Mitsubishi WS-65411 65" Rear Projection Television Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
