Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Wireless router I want to secure my wireless signal so my neighbors cannot jack my signal. I go through a local cable/internet provider. The thing they sent me to secure it may as well have been in chinese. I have a Motorola SBG900 router/ I just want to secure the signal....how do I do that....in simple english lol/ Your help would be GREATLY appreciated
    President:
  • 1,214 Answers
1. Log into the router with your browser by entering 192,168.0.1 into the URL bar near the top of the screen.
2. Type admin in the user field
3. Type motorola into the password field.
This will get you into the router setup.
Go to the wireless tab and setup WEP encryption. Write down everything you do, because you'll need ti later if you don't remember it.
Once setup, you'll need to setup any wireless computers that you want to hook to the router.
Here's a link to the router manual. If you go through it page by page, starting at page 22, then you should be OK. Key things to setup are WEP encryption. A lot of the other stuff, you don't have to worry with. And, you can change the login user name and password, which is highly recommended.
http://www.fixya.com/PostAnswer.aspx?thid=1586831&prdid=496213
Posted on Jan 23, 2009
The signal from my router to my Samsung blu ray is not strong enough
There are several things you need to consider with wireless connection:
Distance - How far is the Netgear router from the Samsung Blu ray? Try changing the wireless channel on the Netgear router that can help boost the signal. Wireless Security- Have you enabled wireless security on the router? Is it WEP or WPA? Make sure that you input the wireless security key on the Blu Ray player and that you have setup wireless settings correctly.Number of wireless devices - Check the number of wireless devices(laptops, desktops, pda's, etc) connecting to the router as it also weakens the signal. And if wireless security is not enabled on your Netgear router, there's a chance that your neighbor might be connecting to your router via wireless.
You can also test how strong the signal is by placing a wireless laptop on the same location where the blu ray player is. If the laptop gets a weak signal as well, you can try placing the router closer to the blu ray player.
Oct 24, 2011 | NetGear WNR2000 Wireless Router
My wireless router keeps losing internet signal and kicking me off the internet. I have to reset the router at least once every 30 minutes. Is this a router problem or a problem with my internet provider?...
I suggest that you try a higher channel, like 11. The neighbors thing is the wireless security portion.
Here are the steps that I think are important:
Wireless Router settings:
It is usually easiest to run the install wizard, which you can get from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below:
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your Internet Browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit. Look under support, downloads, drivers or similar sounding areas.
Things to set:
(Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes. SAVE OFTEN.)
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is typically NOT the security issue.
2. Set a recognizable system ID (descriptive name is easier to find when you need to connect wirelessly).
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
5. Change the channel of the wireless to 11, and avoid conflict with landline cordless phones. (Big issue, even the neighbors can interrupt).
There are more secure settings available, all the way down to only allowing certain MAC addresses to have access. A MAC address is a digit unique to each and every network card. Like a fingerprint. Most users do not set mac address limits.
Jun 25, 2011 | Linksys Wireless-G WRT54G Router
My Belkin F5D7633-4A ADSL2+ modem with wireless router is disconnecting from the internet with increasing frequency. To reconnect I pull out the power cable feeding into the back of the router and after 10...
There could be a number of things going on. I'll list some of them that you might check:
  1. Your wireless network does not have security enabled, and your neighbors are using it to download files using P2P networks. These P2P network connections are crashing your router. In order to resolve this issue, enable WPA or WPA2 security on your router per the user manual.
  2. One of the filters on your phone line has been removed or is failing and needs to be replace. Remove each filter on each line one-by-one and run your Internet connection for a while to see if it fails. Do this one-by-one for each filter.
  3. You recently started using 2.4GHz cordless phones in your home. Get rid of these cordless phones and buy DECT 6.0 compliant cordless phones that use a different radio frequency.
  4. Check the wiring of your telephone jacks to make sure that the connections are solid and that there is no corrosion on the connection. Verify that all jacks and cords are undamaged
  5. Call your DSL provider and complain that their service drops-out on a regular basis.
Hopefully one of these suggestions will fix your issue.
Good Luck
Dec 30, 2010 | Belkin (F5D7230-4) Router (587009)
How to block neighbor's laptop from picking up my router signal and SSID?
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 07, 2010 | Belkin N1 Wireless-N Wireless Router
My wireless ADSL2+ Router is having a problem, The ADSL Blink is going off within a few minutes of Internet use, Could you suggest me a solution?
Please check the following
1) secure cable between modem and router. it must not be loose.
2) secure cable between modem and phone jack. it must not be loose.
3) modem and router must not be near to any electromagnetic devices such as halogen lamps, computer speakers
4) cables must not be intersecting to electrical cable which sometimes cause static signals that interrupts internet signals going to modem or router
Feb 15, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
My rangemax router keeps reverting back to no signal, I unplug it from the cord that goes to my internet service for a few minutes plug it back in works for about 10 minutes then goes back to no signal...
For that you need to reset your router to factory defaults.
Then reconfigure fix this problem.
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Also change channel type in wireless option 4,6 and 11 channel are best.
Try 1 by 1 then save settings and restart router.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | NetGear RangeMax WPN824 Wireless Router...
Definition of the sound card, internet lan & wireless lan
The definition of the sound card, is a chipset integrated into the main board of your laptop, in order to provide sound to your built-in speakers, or to the headphone jack on your laptop. Internet LAN (or Local Area Network) is a port located either on the side or the rear of your computer, where you would plug in a Cable/DSL High-Speed Internet connection, using an Ethernet cable (also called RJ-45). Wireless LAN is the same idea, only instead of using an ethernet cable to provide you access to the internet, it uses a wireless signal or radio frequency, to connect to a wireless access point (usually provided by a wireless router in the area). More in-depth information can be found at the following links:
Sound Cards: http://en.wikipedia.org/wiki/Sound_card
Internet LAN: http://en.wikipedia.org/wiki/Ethernet
Wireless LAN: http://en.wikipedia.org/wiki/Wireless_LAN
May 06, 2009 | Acer 4220-2346 Notebook
Laptop internet
It's somewhat easy, somewhat complicated. Buying the wireless card is easy - you can buy one at any major electronics or computer store. What you need is a PCMCIA Wireless (802.11G) adapter. Most stores will have several models, any of them will be sufficient for surfing the internet. If you're not sure what features you want, just buy the cheapest one.
Here's the complicated part. You need to have an account with an internet service provider (such as Comcast, or Roadrunner, your local phone or cable company). You will also need a wireless router or wireless access point, which you will then connect to your cablemodem or DSL modem (however the internet service provider serves you the internet access). They will help you with the setup and installation.
If you only want to use it away from home, you can usually get a good signal in most major cities around businesses like coffee shops and things like Kinko's - although some businesses will require you to pay to use this service.
Wireless internet access assumes there is a wireless access point (WAP) nearby (usually less than 100 feet away for a good signal). Sometimes you can access your neighbors' wireless access points, but they are usually (and should be) secured against unknown access, or require a key. If you ask nicely they might let you use them.
Good luck, hope this helps!
Jun 02, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
Router
I prefer to test these problems in a step by step manner.
Have you tried to connect either the laptop or any other computer to the internet using an ethernet cable instead of wireless?
If so could the wired computer use the internet successfully?
If so skip down to Wireless Considerations
Can you provide a web link to your internet service providers (ISP) help or support web site? If necessary will you provide you location city and state if required to access the ISP's help/support site?
Can you confirm the make and model of your router as a Netgear WT624SC?
Can you provide the manufacturer and model of your wireless adapter or the model of the Mac Laptop if it has a built-in wireless adapter?
Given that you now have a wireless network are you interested in discussing security options to protect you from people accessing your wireless network from outside your home? (if the signal is strong enough -- from inside home I can see two of my neighbors wireless routers not to mention my own)
Dec 13, 2007 | NetGear Super G WGT624SC Router...
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
262 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
