Question about HP PSC 2210 All-In-One InkJet Printer
No print job is being started
I've been sending print jobs to the machine and they are not being done. The machine howevr can print test page(s)
  • jpriverside Mar 06, 2009
    My mac laptop recognizes the printer, but when I send print job nothing happens.  I have tried a different cord but still the same problem, any suggestions would be appreciated.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 544 Answers
You could try to do a complete uninstall of the printer.
Then do a new installation.
Posted on Jan 24, 2009
Test pgs print ok, jobs= no black only blue faintly appears.
Hi, check if the black toner is properly inserted and check the printing configuration
Dec 09, 2013 | HP PhotoSmart Office Equipment & Supplies
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
'check paper size' error has come up and nothing can now be printed. If turned off and on the last print which had caused the error prints out then the error message appears again. How can i clear this
This is usually caused by data within the print job. Microsoft Office sends paper size and job data with each job. Clear all print jobs in the computer sending the job.(Start/Printers/double click the canon printer and delete all jobs in the print que. Clear the Canon by off/on. Open a program and print a standard letter size document to test. This can be corrected by going to the page/document setup choices under "File" or the Ball in MS Office. Usually this is set to A4 or Bypass by mistake within the application.
Thanks
Jan 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
I print to a printer connected to the company network. I started to print a 40-page document, but realized immediately that the document needed one more change, so i cancelled the print job. After making...
the data send from printer was quered up in the machine memory and was corrupted. reset the print jobs from both the computer and copier. off the machine and on it again to reset the machine memory.
Sep 27, 2010 | Office Equipment & Supplies
Have a print job in the printer that i want to cancel. have unplugged the machine from the network, unplugged the machine from power. when i turn power back on, it start printing 500 page job that i do not...
Press the [PRINT MONITOR] key in the lower right corner of display. If fascimile option is also installed, it would say [SYSTEM MONITOR] key in same location. Anyways, after in print monitor screen, select the job that you want to cancel and press [CANCEL] key. Press [YES] to cancel. Press [DONE]. You might want to pull out all of the paper trays so the machine can't print while cancelling documents. Let me know.
Nov 02, 2009 | Canon ImageRUNNER 330s Copier
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Canon c3220: delete print job from memory
go into system monitor on the main screen and click on the print jobs recieve and clear them,
Canon Technician
Mar 05, 2009 | Canon imageRUNNER C3200 Copier
Dell 948 printer printing not finishing print jobs
Your printer loose documents:try to reset it ,unplug for an hour.
Or you might have interferences on your wireless :DECT phone, cell phone, or even an electric device who doesn't work propely, like tv, stove, speakers many things can parasites your connection...
If nothing does your printer as issues, think replacement...
cheers
Dec 19, 2008 | Dell 948 All-In-One InkJet Printer
Printer only works after test page is printed
possible causes:
1. printer driver conflict to other program. Try reinstallation.
2. virus or spyware. check and clean
3. remove all other printers in the list.
Sep 24, 2008 | HP DeskJet 670c InkJet Printer
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
May 23, 2008 | HP LaserJet 5550 Printer
HP PSC 2210 All-In-One InkJet Printer Logo
Ben Johnson
