Question about Dyson 909592-05 DC-15 Roller Brush Beater Bar
My dc-15 bush bar will not work - Dyson 909592-05 DC-15 Roller Brush Beater Bar
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 88 Answers
Head motor blown, will have to take it to your nearest good hoover repair centre should cost around 49 dyson will charge 73
Posted on Jan 15, 2013
Roller doesnt spin on my dc15
Hi there, it's Jack at Dyson.
If your DC15's brush bar won't rotate, it may need resetting. In order to do this, please follow the steps shown in our Support video:
If you'd like further advice after giving this a try, you can reach our experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 10, 2014 | Dyson 909592-05 DC-15 Roller Brush Beater...
The brushbar stops when the vacuum is pulled back -- works some, doesn't some. DC 15 4 yrs old,on 6th brushbar.
This can happen if two tiny wires that are connected to the circuit board and lead to the beater bar are broken. These wires brake where they go through a black rubber grommet. You need a torx screwdriver (No: 15) to remove two plastic covers to access these wires . When looking from the front of the vacuum, the circuit board is located under the gray covers on the right side of the vacuum. There is one big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
See full details with photos at: http://www.bajwa.net/?q=node/3
Jul 09, 2011 | Dyson DC15 All Floors - The Ball Bagless...
Beater bar not working on newer ball pet unit
HighnTools posted this solution some time ago. I think it can help you solve your issue.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
Aug 29, 2010 | Dyson DC15 All Floors - The Ball Bagless...
DC15 Vac comes on but the head will nmot come on. Local Vac shop said circuit board was burn up,can I repair myself. where do I get parts
HighnTools had posted this solution - try it.
I hope this solves your problem.
Aug 16, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
The Beater Bar keeps Shorting out, we had to replace it a while back and it was working really good, then it started shorting out, do you know what the problem is?
HighnTools posted this solution a while ago. There are so many people having similar issues. This might be related to your problem: I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
The above by highntools.
May 11, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Bought clearance item Sunday just found out the brush bar was motorized it turms only when i move the vacum back and fourth it should turn on its own right ? I have very little suction from the bottom the...
This appears to be a loose connection. The below post was answered by highntools a while ago. It probably is related to you problem. That is why moving it back and forth makes it go on.
There have been several people who reported loose or burnt wires to be the culprit for the brush bar not working. The DC15 does not use a belt, but a motor that is control by the circuit board. And I really believe that in your instance, the problem is a loose wire between the circuit board and the brush motor.
Mar 09, 2010 | Dyson DC15 All Floors - The Ball Bagless...
When I vacuum the carpet it won't engage into the brush mode, or it does intermittenly. It stays in the brushless mode for the most part
Aug 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beater brushes don't work, what to do? They only work when the canister is in about an 85 degree up position.
Jul 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beater bar on Dyson upright won't turn when handle is lowered
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Dyson 909592-05 DC-15 Roller Brush Beater Bar Logo
115 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
