Question about HP DesignJet 130NR InkJet Printer
Print head failure
Had a failure on light cyan.... replaced the cartridge and let it do its business and then says failure again when i turned it on today. Then when I looked in the print head compartment. The magenta box then flashed up to say it had failed too. I hadn't touched it. it just seems to decide which one is going to fail when it likes to. Any suggestions to why this printer keep doing this?
Hi Peter, there are so so many possible causes for this problem. Add me on Skype and I'll talk you through fixing it if you haven't done so already. Skype: waglet2012
Regards
George
Posted on Apr 06, 2014
SOURCE: hp c5180 printer: While printing a job, the
switch off the power, press and hold the ok and help buttons then restore power this will do a reset on the printer and cure this problem
Posted on Jul 12, 2009
ctf1800
  • 4402 Answers
SOURCE: cartridge failed after replacing it wtwice
unplug and plug back in?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035736&cc=us&lc=en&dlc=en&product=305375&dlc=en&lang=en
are you sure you have the correct one in the correct slot?
Posted on Dec 21, 2007
Roynice152
  • 88 Answers
SOURCE: Printer Error
Go to control panel>printers & faxes. Open the printer, go to the top of the tool bar>printer>properties>align cartridge.
Posted on Jan 09, 2009
cene765
  • 787 Answers
SOURCE: My HP Business Inkjet 1200 printer always prints
Some of print heads may be failed.First clean very well the contacts on the print heads and printer using piece of cotton and some alcohol.If not help look which color don't print and replace that print head.
Posted on Nov 16, 2009
jim4984
  • 797 Answers
SOURCE: Printer has new ink cartridges, no apparent
The print heads are probably clogged :^(
Has the printer been unused for some time? Does the printer show that the cartridges are full?
Does the printer show any errors? It could be that he waste reservoir is full (or thinks it is full) I would suspect that it would report an error though.
If the printer was not used for a while, the ink could be dried on the print heads. Print heads are kind a like paint spray cans. You can try cleaning the print head nozzles with alcohol and or water. The best way to do this is to put a moist (you do not want liquid to drip into the system though) cloth or paper towel under the nozzles. Make sure the printer is unplugged though so any liquid does not fry the electronics. Make sure the printer is completely dry before plugging in again.
Hope this helps, Jim
Posted on Feb 10, 2011
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
Cyan ink worked until needed to replace that empty cartridge. Now, all colors print but Cyan. I have cleaned inks, blocked eye with tape, cleaned where cartridge goes with warm water (in those holes),...
First do not use cartrigde compatible or refill because you clogged the print head,is verry sensitive.If you try to clean the print head and nothing you need to replace the print head is the only solution,after replace the print head you print all the colors.
NOTE!!! After you replace the print head use only original cartridge brother !!!!
Apr 07, 2011 | Brother MFC-230c Printer
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Cyan is not printing in EPSON-R230
Nothing at all of cyan and light-cyan?. It might be damage/broken micro pump at head or short circuit. Replace head or buy new printer.
Jun 30, 2010 | Epson STYLUS R230 InkJet Photo Printer
When my screen shows that some items are to print in blue they actually print in red.
Sounds like you are missing cyan. Change the cyan cartridge. If you have not used color on the printer recently, the head may be blocked.
If the head is blocked, try putting the color cartridge on a piece of * slightly * damp piece of paper towel. This should draw color out of the head onto the paper. Once you get blue (cyan), you should try printing again.
Jun 12, 2010 | HP OfficeJet K80 All-In-One InkJet Printer
Nov 16, 2009 | HP Inkjet 1200dn Printer
Hp business inkjet 2800 will not print cyan although have replaced cartridge and run all onboard diagnostics. hp troubleshoot shows no problem yet printer will not print
You say you replaced the cartridge but did you replace the print head. If you fully lift the cartridge cover you will see a row of print heads. The Cyan print head is C4811A. Try replacing this.
or
If you feel lucky you can run the print head cleaner diagnostics. The print head may simply be dirty or clogged.
Apr 04, 2009 | HP Business InkJet 2800 Printer
The new light cyan cartridge was not printing...I thought it may be faulty so purchased another which also did not work. I did 'clean print head ' several times followed by nozzle check. All other colours...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Epson Stylus Photo R300 InkJet Printer
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
HP DesignJet 130NR InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
