Robertshaw sp735a ignition control terminal id.
2 Suggested Answers
  • 5245 Answers
SOURCE: pilot doesn't stay lit
1) Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Replace gas control valve.
Posted on Mar 03, 2013
How do you use a hayward sp735a pool valve
to open for waterflow and close to shut off waterflow
Aug 21, 2014 | Pool & Spa
Pilot doesn't stay lit
Mar 02, 2013 | Rheem Water Heaters
Forsaire by Williams Model 455 FEI, will spark but does not light
i had this problem a couple years ago and I had to scape where the flame lights and reset at the fuse box and it worked good luck
Jan 08, 2010 | Williams 2509612 Ceramic Mid-Size Heater
How to install maple chase 9600 thermostat
The manual is very specific.  http://www.icca.invensys.com/manuals/robertshaw/110-653B.pdf    The Robertshaw 9600 is the same unit. The terminals marked RH, RC, W, Y, G are where you put the wires, just loosen the set screws with a small flat head screwdriver, insert the bare wire into the hole and tighten the screw. Leave the jumper between RH and RC for most installations. The red wire goes to the RH. Please come back and comment if you need more specific help. Good luck
Jan 08, 2010 | Heating & Cooling
Have a Wolf Range Model A-6-9 half the burneres don't light.
I have the same model Wolf Range and need 2 of the Robertshaw SM4 spark modules for it. Robertshaw says they are discontnued. Where can I locate 2 spark modules?
Jul 10, 2009 | Wolf Range Kitchen Ranges
Wiring Amana Heat pump to inside unit and 9520 robertshaw
colors can vary. you should be able to locate a wiring diagram inside the airhandler and out door unit. you will have to remove the panels. generally though Green is fan RED is power WHITE is reversing valve Blue is common YELLOW is the contactor (usually have to jump w and y terminals at robertshaw tstats. PLEASE DOUBLE CHECK AT SYSTEM DIAGRAMS!!
Apr 20, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
