Question about LG WM-2277HW Front Load Washer
My LG WM 1812CW turns off soon after the first spin. No error message.
At first, the washer seems to be working. It lights up, doors lock, water begins to fill the tank and the drum begins to spin. Then, about 1 minute into the cycle, the lights turn off, door unlocks and it turns off. I have tried various wash cycles, but that doesn't seem to matter.
  • LG Master
  • 17,129 Answers
Seems that the main panel is defective. The fault suggests that the program controller or the processor is malfunctioning specially when it works for some time. If you can check on the +5 volt to the processor , the power supply factor can be established as a faulty supply or a blown mains capacitor can also shown this fault .
So remove the panel and check the components for any visible signs.
Posted on Jan 15, 2013
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
  • 4 Answers
SOURCE: LE ERROR CODE ON LG WM-2277HW
Don't call service, they will rip you off!
See posted titled "LG Tromm WM2277HW will not spin"
Posted on Jul 16, 2008
MNTECH
  • 1543 Answers
SOURCE: my lg intellowasher wd1290 error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Posted on Sep 23, 2008
onthejob5130
  • 640 Answers
SOURCE: LG Tromm WM2277HW OE error message
unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
Posted on Jan 30, 2009
  • 22 Answers
SOURCE: Error Message and Tub not spinning
Depending on how many clothes are in the washer you may a unbalance error
Posted on Jul 31, 2009
Tub will not drain water
Open the small door at the bottom of the machine, left. pull plug from hose, it will drain about a cup of water. Then unscrew the filter and clean debris.
Sep 03, 2012 | LG WM-0532HW Front Load Washer
Machine won't start, lights are all on and ready to wash
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Goodluck.
Jun 06, 2008 | LG WM-1832C Front Load Washer
I have a LG WM2277HW front loader washer . The door doesn't close all the way. It locks, but is kind of loose. I don't get any error messages, and it cycles fine(washes fine), but as soon as it starts...
If it is physically possible on your machine I would suggest that the door catch need adjusting, either that or it's broken but the door sensor still thinks it's OK ;-0)
Suggest a service call required ;-0)
Sorry,
John C
Mar 02, 2011 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
Was washing my kitchen rug and on the rinse and spin cycle I got an error message, perhaps because the rug was too heavy when wet to spin. I took rug out, water standing in washer, tried to clear error and...
With the Door Lock display on (which is what the red key indicates), are you able to open and close the door?
If so, you probably have a defective door lock assembly. Try unplugging your machine for a couple of minutes and plug it back in to see if it resets itself.
Oct 10, 2009 | LG WM-2277HW Front Load Washer
UE is likely an unbalanced load or load is too large. Reduce the size of the load and your issue should be resolved.
Jul 21, 2009 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer CE error message
Hi
The CE is for Child lock system error. i just had one on my WD-1049C. It is a system used to prevent children from pressing the buttons.
the way I fixed it on mine is by holding the temp button and the option button at the same time.
Jun 28, 2009 | LG WM-2277HW Front Load Washer
LG WM0642HW washer gives error during spin cycle and stops.
I have this problem and you can find the solution on this same web page by searching. It is likely the Hall Sensor that needs to be replaced (see proflevy posting on Jul 16, 2008). According to the postings, it is from soap build up on the sensor and replacing it costs $18 for the part and is easy (many responses on this). I am waiting for the part and will try to fix mine soon.
Mar 06, 2009 | LG WM-2277HW Front Load Washer
Lg washer
HERE is your servive manual.
Jul 07, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
