Question about GE Dryers
Not hot wind - GE Dryers
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Replace glo bar ;if you see the glo bar coming on then your vent to the outside may be clogged,clean that whole hose or pipe
Posted on Jan 16, 2013
Kenmore 106.56534400. I have click compressor will start. compressor will run for about 15 sec and shut off. Does this sound like relay, capacitor or bad compressor . Compressor is also very warm
Bad compressor!!!!!!!!!
The click you hear is the clixon (self resetting breaker) opening when it gets hot due to excessive current. Then when it cools it will turn the compressor back on but almost immediately it gets hot and shuts down the compressor again. And so on.
Meanwhile the compressor is very hot due to all of the excessive current going thru its windings. If you hook up an ammeter to unit you will be blown away when you compare the reading with what it is supposed to be under normal conditions.
The fact that the compressor starts tells you the start cap is good. And if you have a start relay in lieu you might want to take it out and shake it to see if makes any noise - if so it is no good. If the relay is broken and stuck on the start winding that could also cause your hassle because the start winding uses tons of juice and is designed only to get the motor started - then it is disconnected and the run winding takes over. Motor not designed to run on start winding!
Sep 21, 2015 | Kenmore Refrigerators
Hi my vulcan gas hot water service isn't getting hot enough anymore? please help me?
check first if you have good water flow to and from heater. lift pressure release valve on inlet and allow few sec to flow, same with outlet hot water safety valve.
remove front cover from the heater, you should see your gas connection and thermostat knob.
check if gas is burning evenly and on whole surface, check for leaks on the heater and on the lines to and from the heater.
if you did not find any faults, no leaks, safety valves work correctly, check thermostats settings,
wind it down to minimal, then turn it to about 1/4 value (you did not specify model but this should do, widening arrow or numerical values ar self explanatory), lift hot water safety valve for few seconds, then open any hot water tap (faucet if you are an american...) and check if gas ignites and burns.
set thermostat to about 2/3 value and again, lift hot water safety valve for few seconds, then open any hot water tap. check if gas ignites and if water is sufficiently hot, if too hot - wind it down to say 1/2 way, if too cold, wind it till resistant and then back off a bit, DO NOT EVER LEAVE VALVE OR THERMOSTAT ON MAX!.
if none of these help - you need either, change the thermostat or heater itself.
if works - you solved the problem, close the tap, close the cover and use the system as you normally do.
i am always recommending use of insulation on the hot water system, it saves heaps of money over the life of the system.
hope this will help you - do not forget to vote... :-)
Apr 09, 2015 | Water Water Heaters
How to check ignition coil?
If you suspect a malfunctioning ignition coil, check the resistance of primary and secondary windings. Do this when the coil is hot, and again when it is cold. Also measure from the case to each connector. The primary windings should have a very low resistance, typically from a few tenths of an ohm to a few ohms. The secondary windings have a higher resistance, typically in the 10,000 to 13,000 ohm range. To get the actual figures for a specific coil, check the manufacturer's specs. But as a rule of thumb, primary windings range from a few tenths of an ohm to a few ohms, and secondary winding may be 10 ohms or more.
Oct 29, 2010 | 1993 Honda Accord
650 raptor coil testing
Oct 28, 2010 | Yamaha XS 650 B Motorcycles
I am installing a intilitech 7 day in wall timer replacing an old mechanical 12 hr timer. The load is a 1/4hp 2 speed attic fan. The original wiring had hot in hot out of the timer. This has hot in, hot...
Utilitec does not make a 2 speed timer.
http://waterheatertimer.org/Program-wire-Utilitech-LW60419.html
1) One possible option is a timer with NO and NC terminals like Intermatic-Grasslin FM1 series rated 1 HP. This example timer would have the motor running continually on either one speed or the other.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/grasslin/fm1%20series%20time%20switches.ashx
2) Inside a 2-speed motor are two separate windings.
Windings are loops of copper wire that cause the fan motor to rotate.
For 2-speed, each winding has to be connected to a different 'switch.'
For example, like a ceiling fan. You pull the chain once, and electricity flows to one winding. Pull the chain again, and the switch sends electricity to another winding.
3) The following wiring diagram shows ordinary on-off timer connected to 2-speed switch: This is the basic plan for Broan Nutone 2-speed switch timer, which might be the product you are replacing
http://blog.airscapefans.com/wp-content/uploads//timer_option1_1-1024x768.jpg
4) Nutone makes a 2-speed whole house fan timer.
http://www.nutone.com/PDF/InstallGuides/CFS2WHins89777.pdf
5) And open following Broan Nutone manual that show the two spped timer wiring
http://www.nutone.com/PDF/InstallGuides/CFS2ins57169.pdf
Jul 01, 2010 | Intermatic Inc. ST01C Digital In-Wall...
The hot air won't circulate to upperstairs
2 possible causes. 1 there is a blockage in the ventilation system (possible collasped ductwork) or 2 the fan motor is going out. The motor could be going out due to the winding swelling as the motor is run heating the winding causing the windings to swell slowing the motors rpms.
Dave
Feb 22, 2010 | Bryant 463AAC005BA Air Conditioner
I have an old circular saw that is all metal housing and was a two wire cord. It looks like there should've been a wire going to the switch and the other to the motor winding?
the 2 wires black [power/hot] white[ground/neutral] black should connect to one side of switch other side of switch should continue to one side of winding and other side of winding to white
Oct 05, 2009 | Saws
The cold/hot gauge is wavering to hot and has a good radiator-with no leaks. But when accellerating goes back to normal. It has to cool down after city driving. light & traffic. The thermostat is good...
fans working sound like a fan problem when in town ur not getting wind thruogh the radiator,on freeway u get speeds and wind going whichv will keep a good temp depending where u live,check ur fans fuses,ans make sure they turn on
Aug 25, 2009 | 1997 BMW 328
Treadmill smells HOT HOT HOT
Start by lubing your deck with a silicone oil or slipcoat
Apr 06, 2009 | Exercise & Fitness
Delta gr150 runs slow and hot
Sounds like it's time to buy a new one. Seems like the windings are burned up. Check voltage at outlet and inspect cord for cuts and such, but i would bet the windings are shot. Sorry
Mar 31, 2009 | Grinders
Dryers Logo
29 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
