Question about Denon Audio Players & Recorders
Looking for denon dcd 510ae service manual
Banging when reading cd
5 Suggested Answers
cdj repairs
  • 68 Answers
SOURCE: Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
SOURCE: Denon CD player DCD 920. When using the
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
Posted on Oct 14, 2009
  • 11 Answers
SOURCE: I have a denon DCD-625
Maybe it is dirty. try a cd lens cleaner. you can get them from local electronic stores. and if that's the problem then keep your cds clean. put them back in their case and only handle them by putting your finger through the hole and gently supporting the outside edge. never touch the face (other side to label) and if you do get dirt or bogies on em then clean from the center outwards in straight line. Good luck!
Posted on Jan 05, 2011
SOURCE: have a Denon DCD-520 and it skips forward and back while playing
I have had a similar problem with my Denon DCD-520, the laser current needed adjusting with a watchmakers screw driver, try turning it a quarter clockwise turn and see if the problem is fixed.
Posted on Aug 17, 2012
I have a dcd 1650 and it won't read discs, but sometimes it does, I have checked and cleaned lens
A Laser Lens malfunction will cause this to happen and is a common problem. This can be fixed at home if a new Laser Lens or Laser Lens w/ transport can be found for your unit. I used ebay to purchase a new Laser Lens for my Denon DVD 5900. The part is also sometimes available from parts stores like Parts Express for a premium, $100+ Parts Express vs $17 ebay in my case. I would recommend purchasing a FACTORY SERVICE MANUAL from an online vendor. The manual will cost between $10 - $20 and is downloadable. The installation is very straight forward. The part that might not be clear would be the grounding shorts on the new Laser Lens. THE NEW LENS COMES SHORTED AND AFTER THE PART IS INSTALLED IN THE PLAYER THE GROUND SHORTS MUST BE UNSOLDERD FOR IT TO WORK CORECTLY. The part comes this way to protect the Laser from static shock damage.
The repair on a Denon DVD 5900 cost $30 and took about an hour to complete.
Jan 07, 2013 | Denon DCD-1650 CD Player
I have a Denon dcd 600 cd player. Old but little used and in good condition. Used to put in a cd, close the drawer and the entire display would light up, the disc having not been read at all. After...
it's most likely the belt that drives the cd tray has perished over time and certainly if you tilt the player to help it, that's just gravity giving it a push. replace the belt and all should be ok. hope this helps?
Jan 06, 2010 | Denon DCD-425 CD Player
Denon Amp (PMA-700AE) ignores the signal from CD Player DCD-700
If you can follow the circuit from the input of the cd play socket inside the amp itself you might come accross a Memory Retention Capacitor that supplies an IC. If you do. I can't for certain say one will be there, I would replace it, it might be the cause of the lost memory of your device.
If you don't know what a M R C looks like, they are like electrolytic types, but haven the appearance of being squashed. The value will be low only 0.22uf etc and the volts very low say 5.5. The PC board marking will be different to a normal capictor.
Nov 14, 2009 | Audio Players & Recorders
Have a Denon DCD-520 and it skips forward and back while playing
Hopefully, it may just need cleaning and lube.
I have a Denon DCM-460 purchased from Goodwill a couple days ago and had problem with one CD-R skipping and stuttering toward the end.
Cleaned the CD which helped a little but still started skipping and stuttering.
Noticed a scratch toward the outer end which I suspect is where the problems occurred.
Anyway, last night I cleaned laser, rails, lubed spindles and moving parts. I used 99.9% alcohol to clean. I used a light teflon oil (Tri-Flow) to lube spindles and rails. And white electronic grease where you see remnants of white grease.
Today, I now played through the problem CD-R with no problems.
Assuming placement is level and stable, certainly worth a try and the effort.
Feb 01, 2009 | Audio Players & Recorders
61 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
