Question about Fisher and Paykel SMARTLOAD DE62TG1 Electric Dryer
Dryer will not run message says drum rubbing,. how do i fix?
Message says durm rubbes
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
If it sounds grindy while its running it may be a tub wheel is bad that the tub rides on take off the front and look
Posted on Jan 16, 2013
LG WM 0642 HW Direct Drive Making a thumping sound when spinning and smells like burned rubber. Smoke coming out of durm when front load door was opened.
Hi Paul.
What you're describing is probably the inner drum rubbing on the door seal.
It could be because the rear bearing assembly has collapsed or because the drum is distorted.
Turn the drum slowly by hand and see if the gap between the rim of the drum and the rubber seal stays the same. This will tell you if the drum is 'round' or bent out of shape.
Alternatively, if the drum flops up and down inside the outer drum it would be because of bearing collapse
Either of these situations would require a service visit and parts.
Get a quote...
Good luck.
Nomess
Jan 11, 2015 | LG Washing Machines
DRYER MODEL DE7400P FRIGIDAIRE IS MAKE NOISE LIKE RUBBING METAL HOW DO I FIX?
Hi martyski39...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your dryer drum is mounted in the rear with a bearing, most likely the bearing is faulty and making the grinding noise, or maybe two conditions exist.
1...Bad drum bearing noisy
2...Bad drum bearing noisy, and with play in the bearing allowing the drum to rub the felt seal away at the door making metal to metal contact.Check your door for obvious rub signs...
I will include a parts house webpage link where you can look at you "exploded" view of your dryer and order parts also.
Please take time to rate me
http://www.partselect.com/MultiModels.aspx?ModelNum=de7400p&searchTerm=&RefineSearch=0
Aug 30, 2011 | Frigidaire Dryers
Dryer heats but fan or drum does not work
Check the belt that turns the durm, it may also turn the fan.
Apr 08, 2011 | Maytag Dryers
Where are the 4 teflon bearing pads fitted to support the drum
in the back and the side inside dryer should be around wear the durm at
Oct 15, 2010 | Dryers
My dryer is making a funny noise, like there is friction on the drum and the back is unusually hot.
GE has some gliders the drum turns on they are teflon and wear out. When they do it will start rubbing and making noise. The drum don't turn as easy as it should. G E is very bad about this sometimes it will wear into the plastic that holds the durm up and the whole thing has to be replaced. I wouldn't buy a G E old ones are ok.
Jul 16, 2010 | GE DWSR483EBWW Electric Dryer
I have a rubbing sound coming from the gas dryer drum
The rubbing sound is probably due to worn or missing glides around the dryer opening that the drum rides on. These are usually mounted on a felt strip that is glued to the front panel of the dryer. Remove the front panel and you will see this strip. It is easy to replace and comes in a kit with the glue. Make sure you clean the area after removing the old strip so the glue will adhere properly. If this strip and glides are in good shape, I would look at the bearing or rollers at the back of the drum and check clearance around the drum for rubbing. Hope this will fix ya.
May 06, 2010 | GE Dryers
Noise in dryer Frigidaire model fde336res1 when running
Could be the drum bearings are worn. These are what the dryer drum turns on and when they wear out the drum and frame rub together (metal to metal). Also could be the belt idler which keps the belt tight around the drum. In either case the dryer would have to be internally accessed to determine failure.
Feb 17, 2010 | Dryers
LCD Displays "Call Service 7410:0089745"
This is a Drum unit non-installing error: drum is not installed or not installed properly. The durm PWB EEPROM does not communicate nor mally. Defective connection drum PWB(YC1) and Connect-L PWB(YC3). Maybe defective drum PWB EEPROM or defective engine PWB or itis just the drum unit itself is defective.
May 22, 2009 | Kyocera FS-4000DN Laser Printer
Stuck clothes
There are durm glides that support the front part # 5303937139
you can look up and order at www.apdepot.com
Hope this helps
Jul 18, 2008 | Kenmore 62722 Electric Dryer
Fisher and Paykel SMARTLOAD DE62TG1 Electric Dryer Logo
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
