Question about Cell Phones
Dynex 32l150a11 tcon board testing - Cell Phones
  • robert sugita Jan 16, 2013
    Need in/out voltage test points.Also test points for inverter board
2 Suggested Answers
  • 474 Answers
SOURCE: My Dynex TV model DX-LCD32-09 HAS FAILED AGAIN. I
Make sure when you relace it you have an antistatic inviroment, and grounded braclett on.
Posted on Feb 22, 2011
Dynex tv shows picture but kinda faded an different colors one side has lines up an down. Is this the t-com board
I'd start with a new tcon board and if it doesn't fix it chances are its a bad panel
Apr 23, 2018 | Dynex Televison & Video
Dynex 42. Screen has4 vertical bars and no picture
You can try removing the LVDS cable that goes from the main board to the Tcon board and make sure its seated correctly, also remove the 2 flat connectors that go from the Tcon board to the panel and make sure they are all the way in when you close the flap that holds them in but chances are your going to need a new Tcon board
Oct 26, 2017 | Dynex Televison & Video
Have a dynex 32 in. and not getting full picture on screen. theres about an inch of black on top and bottom of screen
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board .
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 14, 2017 | Dynex Televison & Video
DYNEX MODEL DX-32L150A11 - when trying to turn off CCD choice is "greyed" out so it cannot be chosen. Tried to reset TV, unplugged it, etc.
If you are connected to a cable box the CCD is enabled by the cable box using the cable box remote or in the cable box settings,
Jan 18, 2016 | Dynex Televison & Video
Turn on tv ad see vertical colored lines with thick black line i middle
If you are a tech or know something about lcd tvs, lvds connector from main board to Tcon board needs to be cleaned. Connector and flat cables from Tcon to lcd panel are also to be cleaned. Good luck
Feb 10, 2015 | Dynex 32 in. LCD Flat-Panel HDTV
Half of the tv screen is darker than the other
Tcon board either has an issue or the LVDS cable may have a connection issue. try replugging the cables into the tcon if that doesnt help the Tcon will most likely need to be replaced.
Dec 08, 2012 | Dynex DX-LCD32-09 LCD TV
I have a Dynex 32"
Take the back off of your set and look for 1 or 2 cables that run from your main board ( the one with all the inputs ) to the TCon board. It is the board on the top of the set. Pull the cable or cables out and put them back in. Make sure they are in straight and tight. Do this on both ends and make sure the TV is unplugged. When the cables are back in, plug in the set and see if the problem is resolved. If not, then your TCon board is most likely at fault.
Apr 19, 2011 | Dynex DX-LCD32-09 LCD TV
I need the remote control codes for a Direct-TV remote: Models: DX-L22-10A and DX-32L150A11 Rev B Thank you
10463 should work for both sets.
  1. Pressand hold the "Mute" button and the "Select" button untilthe visible LED blinks twice. Enter the 5 digit code above.
Good luck,
Robert
Feb 26, 2011 | Dynex Televison & Video
VESA Screws
I went to Lowes and found some 4mm .7 screws, 25mm long, and they worked like a champ. (get the lock washers too)
Apparently, most mounts include only 5mm and larger screws
Mar 29, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
