Question about Frigidaire GLER331A Electric Dryer
Where is the heating element in frigidaire dryer
  • Official Brand Answer
  • 4,342 Answers
Hello - Typically speaking the element is located towards the bottom of the drum area. However, to better address may I please have the model number?
Posted on Jan 17, 2013
  • 146 Answers
SOURCE: front load dryer
Remove the front panel to get to it. Once you get the front panel off it is easy to remove the drum and replace the element. First remove the top then the front then you have it.
Posted on Dec 22, 2007
SOURCE: Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Posted on Sep 15, 2008
TheMobilian
  • 8220 Answers
SOURCE: no heat
You gotta pop the top and remove the front which is very easy. Access the idler and remove the belt and get the tub out.. Here is a quick guide
Posted on Jun 09, 2009
  • 266 Answers
SOURCE: MY DRYER Frigidaire Model Number
Sounds like your heating element has broken. Unplug from electricity. On the front of the dryer there are two clips that hold the top of the dryer to the front they can be tripped by inserting a flat blade screwdriver between the top and front panel apx 2 inches in from the side in the seam where the top and front come together. These clips are sprung steel and you have to push hard. (I usually give the screwdriver a sharp rap with a hammer) When you trip them you can lift the top up and backwards. Then about 12 inches down the inside front you will see a 5/16 nut that holds the front to the sides take them out. Then you can pull forward and lift the front off the machine. You will need to remove the belt you can look under the drum the belt goes thru two pullys one is a tensioner pop the belt off the tensioner and pay attention how the tensioner looks it may fall down and you will have to rehook it to put the belt back. I believe this model also has an access door at the tensioner and motor that gives closer access to the belt. Then you just lift the drum up and out of the dryer pull forward slightly before lifting up. The heating element will be exsposed in the back and the wire that was arching will be here. Remove the wires to the element and the mounting screws on the element pan. Unhook the Hi limit sensor on the pan and put it on the new one. Reinstall the element ect in reverse. The only problems you may run into is where the wires hook to the element can be hard to remove and unhooking the belt pay close attention to the tensioner and how the belt is attached to the tensioner and motor. This should only take you about 40 minutes to complete. I hope this helps
Posted on Aug 23, 2010
hunter19_46m
  • 7482 Answers
SOURCE: How do I remove the drum of a Frigidaire Dryer,
Try this website:
appliancehelponline.com/servicemanual.html
Posted on Oct 03, 2010
Where are fuses located in Frigidaire front loading dryer?
No fuses. Probably Heating element or one of the thermal switches. Electric dryer I am assuming
May 24, 2015 | Frigidaire Dryers
How to replace the heating element in a AEQ6000CES2 frigidaire affinity dryer
Hello,This youtube video will show ya how to replace the heat element on your dryer.http://www.youtube.com/watch?v=JwMyoSa9ebw
GENE
Oct 21, 2011 | Frigidaire AEQ6000ES Electric Dryer
Trying to replace heating element in my frigidaire dryer model# fde336res2. where is the darn element? thanx kevin
Hi awc9859...
Your heating element is behind the drum where it is attached and case of the dryer
I have also attached a link so you could view the part in its location...double click on the drawing and look for part 15.
Please take time to rate me thumbs up
http://www.partselect.com/PS418120-Frigidaire-131553900-Heating-Element-Assembly.htm?SourceCode=5&ModelNum=fde336
Sep 10, 2011 | Frigidaire Dryers
WHERE IS THE HEATING ELEMENT FOR A FRIGIDAIRE FER341ACO
it is located on the back inside of the dryer, here is a step by step:
http://www.ehow.com/how_4866523_fix-frigidaire-dryer-heating-elements.html
I do not know why you want to replace the element but if the problem is no heat then here is another website that can help,Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Mar 19, 2011 | Frigidaire Electric Dryer
Frigidaire dryer will not heat
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse which is about an inch long is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Thank you !!
Jul 21, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Need to get to the heating element, how do you do that?
how do i get to the heating element on my frigidaire heavy duty dryer
Oct 03, 2009 | Frigidaire GLER341A Electric Dryer
Frigidaire dryer running but not heating
If it is electric, then the heating element is defective and must be replaced ($45).
It could also be the "over-heating" sensor. If the dryer ran too long on hot, the sensor shut it down, but also damaged the sensor ($20). If so, the heating element could be ok.
Hope this helps!
Sep 15, 2009 | Frigidaire Dryers
Frigidaire GLer642As3
A grounded element on an electric dryer is an element that has broken and the element heating wire has touched something metal, like the cage that is suppose to hold the element or the element metal housing around the element. What this does is, the element only heats on the section that is touching the metal part and usually this part of the element is only heating at about 1/2 heat output. An grounded element can also stay on even when the dryer is not in use!!
May 12, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire GLER331A Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
