Question about Intex 603 Krystal Clear Filter Pump 530 Gph 58603e
I am not getting electricity in my intex pump power cord what can i do
  • 717 Answers
Check the GFCI at the wall outlet where you plug the Intex Power cord in.
Rod
US Parts Center
Posted on Feb 06, 2013
Pure Spa. where can I get an owner's manual?
Support - Intex
www.intexcorp.com/support/
The leader in Above Ground Pools, Airbeds and Inflatable Spas. ... Manual Pumps · Electric Pumps · Parts & Accessories · Electric Pumps · Floats & Toys · Pool Toys... If you don't find what you're looking for, get in touch with Customer Service.
2500 Gal Filter Pump (120v) - Intex
www.intexcorp.com/28633eg.html
Review the Trouble Shooting Guide in your Owner's Manual. Are any tools ... Can we use the pool while the filter pump is operating? Is it safe? No, due to ...
Oct 28, 2015 | Intex Pool & Spa
How do you get a replacement cord .model SF 70110rd for sand filter pump.110-120,v 60hz 4.8a
take it to an electrical shop and they will fit the correct cord for you
Oct 17, 2015 | INTEX Sand Filter Pump
Intex spa has power but just makes a loud constant sound. Lights go on. Pump will not flow water. What happened? Was working just fine for 2 months. Is it fixable?
It looks it would be worth fixing, first I would check the power, the plugs and voltage. it has heat so it requires the proper power cords to supply it,
If all checks out I would contact intex, if there is not any warranty, I would search your area for a electric motor repair shop, tell them its a spa pump with a heater,
I would be happy to look at it for you at no charge to see whats it's fault is. I'm in central Florida.. here are the error CODES. best of luck.. Jay
Dec 31, 2014 | Intex Pool & Spa
How to take apart Intex 603 pump housing
You need to try 'security' bits. They come in sets with various sizes of star bits and hex bits.
Aug 18, 2014 | Intex 603 Krystal Clear Filter Pump 530...
Why won't the breaker on the power cord of my intex krystal clear saltwater system reset?
Defective breaker or shorting pump. Disconnect the appliance from the cord. Does it reset? yes means your appliance is bad. No means that the breaker is bad. A cord with a breaker is not the way to safely operate the pump. You should use a ground fault protected outlet or a cord with a GFCI built in. Either way if the safety device continues to trip, you have a problem with appliance.
Aug 03, 2014 | Intex Krystal Clear Saltwater System Pool...
How do you wire electrical line into filter?
Does the filter not have a power cord coming from the motor housing?
Jun 04, 2014 | Intex Krystal Clear 1600 GPH Model SF15110...
My intex pool pump want come on. Would air in the lines cause this?
No...Either the unit is not getting power or the motor pack has failed and will need to be replaced. Try another electrical device in the same outlet if you do not have a meter to measure voltage at the pump. If the device such as a lamp or radio works then the unit is getting power...unfortunately there is no repairing those pumps so you'll need a new one.
John
Mar 21, 2011 | Intex Pool & Spa
Pool pump shutting off/tripping the circuit breaker
What kind of pump are you using?
Sounds like the Intex is restricting water flow there by heating up your pump and shutting it down..
You may need to re plumb everything to handle the flow.
Intex hoses and fittings are different than the industry standards just so the can make you buy from them
Do what ever it takes to get good flow
Jul 01, 2010 | Intex Automatic Salt Water System for ...
Power cord has been cut
Yes you can replace the entire cord, or you can splice the cord back together. Get some crimp on wire connectors get a tube of heat shrink that will fit over the cord, cut back the insulation crimp, the wires back together (match color to color). heat the shrink or tape it up. Back in business.
Jul 04, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Intex 603 Krystal Clear Filter Pump 530 Gph 58603e Logo
290 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
